memory check of /snes/example/tutorials/ex29.c
Mon Jul 27 16:22:10 CDT 2009
On Mon, Jul 27, 2009 at 3:51 PM, (Rebecca) Xuefei YUAN
<xy2102 at columbia.edu>wrote:
> Hi,
> My own code has some left bytes still reachable according to valgrind, then
> I use two different version petsc (2.3.3-p15 and 3.0.0-p1) to compile and
> make the files, it gives me different number of bytes left still reachable.
> Moreover, I picked up the /snes/example/tutorials/ex29.c as another example,
> and found that some bytes are still reachable, what is the cause of it? It
> shows that it is from DACreate2D() and the I use -malloc_dump to get those
> unfreed informations.
> I understand that for those 5 loss record, the 2nd, 3rd and 4th are true
> for all examples, but where do 1st and 5th ones come from? Also, the
> -malloc_dump information shows that there are
> "[0]Total space allocated 37780 bytes",
> but valgrind gives the information as
> "==26628==    still reachable: 132,828 bytes in 323 blocks"
> Why there is a big difference?
1 is fine. It is from PMPI setup, which has some bytes not freed from
setting up the MPI
processes. The last one looks like an unfreed header for a DA, which is
strange.
  Matt
> Thanks very much!
> Rebecca
> Here is the message from valgrind of running ex29:
> ==26628== 32 bytes in 2 blocks are still reachable in loss record 1 of 5
> ==26628==    at 0x4022AB8: malloc (vg_replace_malloc.c:207)
> ==26628==    by 0x86F9A78: MPID_VCRT_Create (mpid_vc.c:62)
> ==26628==    by 0x86F743A: MPID_Init (mpid_init.c:116)
> ==26628==    by 0x86D040B: MPIR_Init_thread (initthread.c:288)
> ==26628==    by 0x86CFF2D: PMPI_Init (init.c:106)
> ==26628==    by 0x8613D69: PetscInitialize (pinit.c:503)
> ==26628==    by 0x804B796: main (ex29.c:139)
> ==26628==
> ==26628==
> ==26628== 156 (36 direct, 120 indirect) bytes in 1 blocks are definitely
> lost in loss record 2 of 5
> ==26628==    by 0x429B3E2: (within /lib/tls/i686/cmov/libc-2.7.so)
> ==26628==    by 0x429BC2D: __nss_database_lookup (in /lib/tls/i686/cmov/
> libc-2.7.so)
> ==26628==    by 0x4732FDB: ???
> ==26628==    by 0x473413C: ???
> ==26628==    by 0x4247D15: getpwuid_r (in /lib/tls/i686/cmov/libc-2.7.so)
> ==26628==    by 0x424765D: getpwuid (in /lib/tls/i686/cmov/libc-2.7.so)
> ==26628==    by 0x8623509: PetscGetUserName (fuser.c:68)
> ==26628==    by 0x85E0CF0: PetscErrorPrintfInitialize (errtrace.c:68)
> ==26628==    by 0x8613E23: PetscInitialize (pinit.c:518)
> ==26628==
> ==26628==
> ==26628== 40 bytes in 5 blocks are indirectly lost in loss record 3 of 5
> ==26628==    by 0x429AFBB: __nss_lookup_function (in /lib/tls/i686/cmov/
> libc-2.7.so)
> ==26628==    by 0x4732FFB: ???
> ==26628==
> ==26628==
> ==26628== 80 bytes in 5 blocks are indirectly lost in loss record 4 of 5
> ==26628==    by 0x428839B: tsearch (in /lib/tls/i686/cmov/libc-2.7.so)
> ==26628==    by 0x429AF7D: __nss_lookup_function (in /lib/tls/i686/cmov/
> libc-2.7.so)
> ==26628==
> ==26628==
> ==26628== 132,796 bytes in 321 blocks are still reachable in loss record 5
> of 5
> ==26628==    by 0x85EF3AC: PetscMallocAlign (mal.c:40)
> ==26628==    by 0x85F049B: PetscTrMallocDefault (mtr.c:194)
> ==26628==    by 0x81BCD3F: DACreate2d (da2.c:364)
> ==26628==    by 0x804BAFB: main (ex29.c:153)
> ==26628==
> ==26628== LEAK SUMMARY:
> ==26628==    definitely lost: 36 bytes in 1 blocks.
> ==26628==    indirectly lost: 120 bytes in 10 blocks.
> ==26628==      possibly lost: 0 bytes in 0 blocks.
> ==26628==    still reachable: 132,828 bytes in 323 blocks.
> ==26628==         suppressed: 0 bytes in 0 blocks.
> Department of Applied Physics and Applied Mathematics
> Columbia University
> Tel:917-399-8032
> www.columbia.edu/~xy2102 <http://www.columbia.edu/%7Exy2102>
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090727/441ebd43/attachment-0001.htm>
