vecload_block_size
(Rebecca) Xuefei YUAN
xy2102 at columbia.edu
Sat Jul 25 13:20:33 CDT 2009
I am reading from a binary file of the previous solution and would
like it to be my initial guess.
However, I found that the "-vecload_block_size" is shown in the
PetscOptionsTable, I did not explicitly state this one in my options
file, why it shows up in it? And the block size has been assigned as
"4".
Thanks!
Rebecca
Here is this PetscOptionsTable:
(gdb) p *options
$21 = {N = 28, argc = 3, Naliases = 0, args = 0xbf8e9564, names = {
0x8867768 "da_grid_x", 0x8867788 "da_grid_y",
0x88678c8 "dmmg_iscoloring_type", 0x88678a8 "dmmg_levels",
0x8867a20 "ksp_converged_reason", 0x8867a00 "ksp_max_it",
0x8847bb8 "loadbin", 0x8847bd8 "mx_grid", 0x8867748 "my",
0x88677d0 "number_of_time_steps", 0x8867a60 "pc_asm_overlap",
0x8867a40 "pc_type", 0x8867910 "snes_converged_reason",
0x8867998 "snes_ksp_ew", 0x8867940 "snes_max_fail",
0x88679d8 "snes_max_funcs", 0x88679b8 "snes_max_it",
0x8867968 "snes_max_linear_solve_fail", 0x8867930 "snes_mf",
0x88678f8 "snes_monitor", 0x8867aa8 "sub_pc_factor_shift_nonzero",
0x8867a88 "sub_pc_type", 0x8867850 "time_accuracy_order",
0x8867800 "time_step_monitor", 0x88677a8 "time_step_size",
0x8867818 "time_step_to_save_solution_text",
0x8867878 "time_to_generate_grid", 0x8855890 "vecload_block_size",
0x0 <repeats 484 times>}, values = {0x8867778 "8", 0x8867798 "8",
0x88678e8 "global", 0x88678b8 "1", 0x0, 0x8867a10 "50", 0x8847bc8 "true",
0x8867738 "9", 0x8867758 "9", 0x88677f0 "1", 0x8867a78 "1",
0x8867a50 "asm", 0x0, 0x88679a8 "true", 0x8867958 "100",
0x88679f0 "1000000", 0x88679c8 "10", 0x8867988 "100", 0x0, 0x0, 0x0,
0x8867a98 "ilu", 0x8867868 "1", 0x0, 0x88677c0 "0.2", 0x8867840 "1",
0x8867898 "0.2", 0x8847ba8 "4", 0x0 <repeats 484 times>}, aliases1 = {
0x0 <repeats 25 times>}, aliases2 = {0x0 <repeats 25 times>}, used = {
PETSC_FALSE, PETSC_FALSE, PETSC_TRUE, PETSC_TRUE, PETSC_TRUE, PETSC_TRUE,
PETSC_FALSE, PETSC_TRUE, PETSC_TRUE, PETSC_FALSE, PETSC_TRUE, PETSC_TRUE,
PETSC_TRUE, PETSC_TRUE, PETSC_TRUE, PETSC_TRUE, PETSC_TRUE, PETSC_TRUE,
PETSC_FALSE, PETSC_TRUE, PETSC_FALSE, PETSC_FALSE, PETSC_FALSE,
---Type <return> to continue, or q <return> to quit---
PETSC_FALSE, PETSC_FALSE, PETSC_FALSE, PETSC_TRUE,
PETSC_FALSE <repeats 485 times>}, namegiven = PETSC_TRUE,
programname =
"/home/rebecca/linux/code/couple/twoway/twoway_oreggt/codes/tworeggt",
'\0' <repeats 4028 times>, monitor = {0, 0, 0, 0, 0}, monitordestroy = {
0, 0, 0, 0, 0}, monitorcontext = {0x0, 0x0, 0x0, 0x0, 0x0},
numbermonitors = 0}
Department of Applied Physics and Applied Mathematics
Columbia University
Tel:917-399-8032
www.columbia.edu/~xy2102
