strange behaviour with PetscViewerBinary on MATIS
Andreas Grassl
Andreas.Grassl at student.uibk.ac.at
Thu Jul 23 10:08:26 CDT 2009
Jed Brown schrieb:
> You can put this in MatView_IS if you really need it, but I doubt it
> will actually be useful. Unfortunately, you cannot change the domain
> decomposition with Neumann preconditioners, hence they will have limited
> use for solving a system with a saved matrix. Why do you want to save
> the matrix, it's vastly slower and less useful than a function which
> assembles that matrix?
I assemble the Matrix by reading out from a data structure produced by a
proprietary program and just used this easy approach to compare the solvers on
different machines, where this program is not installed.
Since the implementation of the NN-preconditioner is suboptimal at all, I will
not waste much time on this issues and my post at the list was lead mostly by my
curiosity.
thanks for the explanation
cheers,
ando
/"\ Grassl Andreas
\ / ASCII Ribbon Campaign Uni Innsbruck Institut f. Mathematik
X against HTML email Technikerstr. 13 Zi 709
/ \ +43 (0)512 507 6091
