PETSC debugger
    Ryan Yan
    vyan2000 at gmail.com
    Sun Jul 19 15:49:58 CDT 2009
Hi Barry,
I restarted x server many times(during turning off the option as ) -nolisten
tcp as Berend. And I also checked very carefully each time the bottom margin
of the window status panel. The gdb window did not function correctly on my
Linux box. Thanks in advance for any suggestions
On Sun, Jul 19, 2009 at 12:54 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  Are you sure the other window isn't lurking away somewhere off (or nearly)
> off the screen?
>  Maybe try shutting down the x server and restarting?
>  Barry
> On Jul 18, 2009, at 11:50 PM, Ryan Yan wrote:
>  Thank you very much, Barry.
>> After I use the vyan2000-linux:0.0, I got errors without any gdb window.
>> vyan2000 at vyan2000-linux:~/local/PPETSc/petsc-2.3.3-p15/src/ksp/ksp/examples/tutorials/ttt2$
>> mpirun -np 2 ./rpisolve -ksp_monitor_true_residual -start_in_debugger
>> -display vyan2000-linux:0.0
>> [0]PETSC ERROR: PETSC: Attaching gdb to ./rpisolve of pid 26518 on display
>> vyan2000-linux:0.0 on machine vyan2000-linux
>> [1]PETSC ERROR: PETSC: Attaching gdb to ./rpisolve of pid 26519 on display
>> xterm Xt error: Can't open display: vyan2000-linux:0.0
>> Then
>> I changed back,
>> -display :0.0
>> Same as before, error messages with only a single gdb window, (and the
>> window shows up at different place at different instances).
>> Yan
>> On Sun, Jul 19, 2009 at 12:30 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>  Try using -display vyan2000-linux:0.0
>>  Shouldn't make any difference but since it appears you are running
>> everything on the same machine what you have given should work.
>>  Barry
>> On Jul 18, 2009, at 11:24 PM, Ryan Yan wrote:
>> Hi All,
>> I am tring to use the PETSc runtime option -start_in_debugger.
>> However, when I attach the debugger at run time to each process, there are
>> error messages and I only get one gdb window(Am I suppose to get as many as
>> the number of the processes?)
>> -display :0.0
>> [1]PETSC ERROR: PETSC: Attaching gdb to ./rpisolve of pid 26307 on display
>> [0]PETSC ERROR: PETSC: Attaching gdb to ./rpisolve of pid 26306 on display
>> Then, only a *single* gdb window prompts out. When I run with 3 process,
>> there are only *two* gdb windows.
>> Thank you very much in advance,
>> Yan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090719/e7b3a788/attachment-0001.htm>
