non-local values being dropped in MatSetValues
Stephan Kramer s.kramer at imperial.ac.uk
Fri Jul 17 07:44:09 CDT 2009
Hello
We've spend sometime debugging a problem were in the assembly of a
parallel MPIAIJ matrix, some values that were created on a process other
than the owner of the row seemed to disappear. I think I narrowed it
down to what I think is a bug in MatSetValues_MPIAIJ, but please tell me
if I'm wrong.
The situation is the following: I'm calling MatSetValues with the flag
ADD_VALUES and with matrix option MAT_IGNORE_ZERO_ENTRIES. I'm inserting
  multiple values at once, multiple columns and rows, so I provide a
rank-2 matrix of values. As I'm calling this from fortran I'm also using
MAT_COLUMN_ORIENTED. Now for provided rows that are not owned by the
process, it jumps to mpiaij.c:394 (line numbers as in petsc-dev). On
line 399, it checks for zero entries, but only checks the very first
entry of the (non-owned) row. If however other entries of that same row
are nonzero, the entire row is still dropped. Note that this is
independent of row_oriented/column_oriented as line 396 does exactly the
same.
If I don't set the option MAT_IGNORE_ZERO_ENTRIES the problem
disappears. In that case however we would either have to preallocate
substantially more nonzeros, or complicate the matrix assembly in our
code by taking out the zero entries ourselves and call MatSetValues for
each entry seperately.
Your help would be much appreciated,
Cheers
Stephan
Stephan Kramer  <s.kramer at imperial.ac.uk>
Applied Modelling and Computation Group,
Department of Earth Science and Engineering,
Imperial College London
