call PetscOptionsSetValue in fortran
Klaij, Christiaan
C.Klaij at marin.nl
Fri Jul 17 04:52:48 CDT 2009
I'm trying to change the options of the Hypre preconditioner using PetscOptionsSetValue in a fortran program, but I must be doing something wrong, see the session below. It works fine from the command line, though. As an example, I took ex12f from src/ksp/ksp/examples/tests (petsc-2.3.3-p13) and modified it a little.
$ cat ex12f.F
program main
implicit none
#include "include/finclude/petsc.h"
#include "include/finclude/petscvec.h"
#include "include/finclude/petscmat.h"
#include "include/finclude/petscpc.h"
#include "include/finclude/petscksp.h"
#include "include/finclude/petscviewer.h"
! This example is the Fortran version of ex6.c. The program reads a PETSc matrix
! and vector from a file and solves a linear system. Input arguments are:
! -f <input_file> : file to load. For a 5X5 example of the 5-pt. stencil
! use the file petsc/src/mat/examples/matbinary.ex
PetscErrorCode ierr
PetscInt its
PetscTruth flg
PetscScalar norm,none
Vec x,b,u
Mat A
character*(128) f
PetscViewer fd
MatInfo info(MAT_INFO_SIZE)
KSP ksp
! cklaij: adding pc
PC pc
! cklaij: adding pc end
none = -1.0
call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
! Read in matrix and RHS
call PetscOptionsGetString(PETSC_NULL_CHARACTER,'-f',f,flg,ierr)
print *,f
call PetscViewerBinaryOpen(PETSC_COMM_WORLD,f,FILE_MODE_READ, &
& fd,ierr)
call MatLoad(fd,MATSEQAIJ,A,ierr)
! Get information about matrix
call MatGetInfo(A,MAT_GLOBAL_SUM,info,ierr)
write(*,100) info(MAT_INFO_ROWS_GLOBAL), &
& info(MAT_INFO_COLUMNS_GLOBAL), &
& info(MAT_INFO_ROWS_LOCAL),info(MAT_INFO_COLUMNS_LOCAL), &
& info(MAT_INFO_BLOCK_SIZE),info(MAT_INFO_NZ_ALLOCATED), &
& info(MAT_INFO_NZ_USED),info(MAT_INFO_NZ_UNNEEDED), &
& info(MAT_INFO_MEMORY),info(MAT_INFO_ASSEMBLIES), &
& info(MAT_INFO_MALLOCS)
100 format(11(g7.1,1x))
call VecLoad(fd,PETSC_NULL_CHARACTER,b,ierr)
call PetscViewerDestroy(fd,ierr)
! Set up solution
call VecDuplicate(b,x,ierr)
call VecDuplicate(b,u,ierr)
! Solve system
call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
call KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN,ierr)
call KSPSetFromOptions(ksp,ierr)
! cklaij: try boomeramg
call KSPGetPC(ksp,pc,ierr)
call PCSetType(pc,PCHYPRE,ierr)
call PCHYPRESetType(pc,"boomeramg",ierr)
& ("-pc_hypre_boomeramg_strong_threshold","0.5",ierr)
! cklaij: try boomeramg end
call KSPSolve(ksp,b,x,ierr)
! Show result
call MatMult(A,x,u,ierr)
call VecAXPY(u,none,b,ierr)
call VecNorm(u,NORM_2,norm,ierr)
call KSPGetIterationNumber(ksp,its,ierr)
print*, 'Number of iterations = ',its
print*, 'Residual norm = ',norm
! Cleanup
call KSPDestroy(ksp,ierr)
call VecDestroy(b,ierr)
call VecDestroy(x,ierr)
call VecDestroy(u,ierr)
call MatDestroy(A,ierr)
call PetscFinalize(ierr)
end
$ ./ex12f -f ../../../../mat/examples/matbinary.ex -ksp_view | grep Threshold
HYPRE BoomerAMG: Threshold for strong coupling 0.25
$ ./ex12f -f ../../../../mat/examples/matbinary.ex -pc_type hypre -pc_hypre_type boomeramg -pc_hypre_boomeramg_strong_threshold 0.5 -ksp_view | grep Threshold
HYPRE BoomerAMG: Threshold for strong coupling 0.5
dr. ir. Christiaan Klaij
CFD Researcher
Research & Development
mailto:C.Klaij at marin.nl
T +31 317 49 33 44
MARIN
2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
T +31 317 49 39 11, F +31 317 49 32 45, I http://www.marin.nl/
http://www.marin.nl/web/show/id=46836/contentid=2324 First AMT'09 conference, Nantes, France, September 1-2
This e-mail may be confidential, privileged and/or protected by copyright. If you are not the intended recipient, you should return it to the sender immediately and delete your copy from your system.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090717/98b35a0a/attachment.htm>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090717/98b35a0a/attachment.jpeg>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090717/98b35a0a/attachment-0001.jpeg>
