Petsc-3 MPIless
Collette Yann
ycollet at freesurf.fr
Thu Jul 16 14:54:53 CDT 2009
Hello,
I am currently interfacing petsc/snes to scilab (http://www.scilab.org).
I worked using petsc-2.3.3-p15 and everything is nearly fine (I had some
convergenge problem, but that's not really important).
My petsc-2.3.3 is configure without mpi: config/configure.py
--with-mpi=0 --enable-shared
Now, I would like to switch to petsc-3. So I configured petsc-3 using
the same command line as above.
The problem I meet is that petsc-3 still required mpi.
Is it possible to compilte petsc-3 without mpi ?
Cheers,
YC
