VTK output from DA vectors
Saswata Hier-Majumder
saswata at umd.edu
Mon Jul 13 08:27:42 CDT 2009
OK, here's the c program and the vtk output. Thanks for your help.
Matthew Knepley wrote:
> On Sun, Jul 12, 2009 at 9:09 PM, Saswata Hier-Majumder <saswata at umd.edu>wrote:
>> 1) I did. It returns correct values for the x nodes, but fails to do so for
>> the y nodes. Here's a sample output generated from the driven cavity
>> problem. ( I suppressed printing the solutions for brevity).
> I did not realize you mean as fields (rather than as the mesh). Give me your
> exact calling sequence. I can output
> parallel fields fine, so something else must be going on. If you modified
> the code, send that too.
> Matt
>> 2) Thanks, I'll try that.
>>> 1) I believe the standard VTK viewer (ASCII Viewer with VTK format) gets
>>> the
>>> coordinates
>>> right. Can you verify this?
>>> 2) You should be able to split the 4- component field into 4 fields using
>>> the Split filter in VTK
>>> or whatever viewer you use (I do this in Mayavi2, but Paraview also
>>> works).
>>> Matt
>>> On Sun, Jul 12, 2009 at 10:34 AM, Saswata Hier-Majumder <saswata at umd.edu
>>>> wrote:
>>>> Hi,
>>>> I would like to generate a vtk output from a multicomponent problem. In
>>>> the vtk file, I would like the DA coordinates as well as all 4 components
>>>> stored separately as scalar point data.
>>>> I have been using the VecView_VTK routine from
>>>> /ksp/ksp/ksp/examples/tutorials/ex29.c. But the vtk output seems to
>>>> contain
>>>> only the local coordinates (may be because DAGetCoordinates is not
>>>> collective?). Is there a way to fix this?
>>>> Also, using the same routine, all components of the solution
>>>> corresponding
>>>> to a node are dumped together. Is there a way to extract each component
>>>> separately and ouput them separately as scalar point data?
>>>> Thanks
>>>> www.geol.umd.edu/~saswata <http://www.geol.umd.edu/%7Esaswata> <
>> # vtk DataFile Version 2.0
>> ASCII
>> DATASET STRUCTURED_POINTS
>> DIMENSIONS 49 49 1
>> ORIGIN 0 0 0
>> SPACING 1 1 1
>> POINT_DATA 2401
>> SCALARS scalars double 3
>> LOOKUP_TABLE default
>> X_COORDINATES 49 double
>> 0 0.0208333 0.0416667 0.0625 0.0833333 0.104167 0.125 0.145833 0.166667
>> 0.1875 0.208333 0.229167 0.25 0.270833 0.291667 0.3125 0.333333 0.354167
>> 0.375 0.395833 0.416667 0.4375 0.458333 0.479167 0.5 0 0.0208333 0.0416667
>> 0.0625 0.0833333 0.104167 0.125 0.145833 0.166667 0.1875 0.208333 0.229167
>> 0.25 0.270833 0.291667 0.3125 0.333333 0.354167 0.375 0.395833 0.416667
>> Y_COORDINATES 49 double
>> 0 0.0208333 0.0625 0.104167 0.145833 0.1875 0.229167 0.270833 0.3125
>> 0.354167 0.395833 0.4375 0.479167 5.27367e-317 5.23119e-317 0 5.31253e-317 0
>> 0 0 3.41641e-312 3.26575e-311 1.14376e-311 1.54269e-311 1.94163e-311
>> 2.34056e-311 5.29014e-311 5.27095e-317 0 0 0 1.82492e-312 1.01431e-311
>> 1.84614e-311 1.49455e-320 3.09811e-312 1.17559e-311 2.04136e-311 0 0 0
>> 5.23119e-317 0 0 8.06358e-313 5.3312e-317 5.33093e-317 0 5.27392e-317
>> Z_COORDINATES 1 double
>> 0
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090713/95666254/attachment-0001.c>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090713/95666254/attachment-0001.diff>
