A question about parallel computation
Wed Jul 8 13:26:26 CDT 2009
Perhaps you are using the wrong mpiexec or mpirun. You'll have to use
the correspond mpiexec from MPI you've used to build PETSc.
Or if the MPI has special instruction on usage - you should follow
that [for ex: some clusters require extra options to mpiexec ]
Satish
On Wed, 8 Jul 2009, Yin Feng wrote:
> I am a beginner of PETSc.
> I tried the PETSC example 5(ex5) with 4 nodes,
> However, it seems every nodes doing the exactly the same things and
> output the same results again and again. is this the problem of petsc or
> MPI installation?
> Thank you in adcance!
> Sincerely,
> YIN
