MPI-layout of PETSc
    Barry Smith
    bsmith at mcs.anl.gov
    Sat Jul  4 12:24:43 CDT 2009
    Send us the code to do the conversion and we'll include as a
utility.
    Barry
On Jul 4, 2009, at 6:08 AM, Rolf Kuiper wrote:
> Thanks Barry!
> It's working. But by the way: You simply should offer such a second
> communicator inside the PETSc-library.
> Thanks for all your help, the support we got from this mailing list
> is amazing,
> Rolf
> Am 04.07.2009 um 01:44 schrieb Barry Smith:
>> Use MPI_Comm_split() with the same color for all processors, then
>> use the second integer argument to indicate the new rank you want
>> for the process.
>> Choice the new rank so its x,y coordinate in the logical grid will
>> match the y,x coordinate in the cartesian grid.
>>  Barry
>> On Jul 3, 2009, at 12:09 PM, Rolf Kuiper wrote:
>>> Hi Barry,
>>> I tried that already with:
>>> First way by copying:
>>> MPI_Comm_dup(PETSC_COMM_WORLD, &MyComm);
>>> Second way by creating:
>>> int dims[3] = {0,0,0};
>>> int ndims=3;
>>> MPI_Dims_create(NumberOfProcessors, ndims, dims);
>>> int false = 0; int true = 1;
>>> int periods[3] = { false, false, true };
>>> int reorder = true;
>>> MPI_Comm MyComm;
>>> MPI_Cart_create(PETSC_COMM_WORLD, ndims, dims, periods, reorder,
>>> &MyComm);
>>> in the end then:
>>> PETSC_COMM_WORLD = MyComm;
>>> I test the MyComm with MPI_Topo_test(); and it is cartesian, yes.
>>> I can the coordinates of the cpus with MPI_Cart_coords(MyComm,
>>> LocalRank, ndims, coords); , but I found no way to set/rearrange
>>> these coordinates.
>>> Do you can help me in that case or have I to ask a MPI-support?
>>> Thanks for all,
>>> Rolf
>>> Am 03.07.2009 um 17:56 schrieb Barry Smith:
>>>> In designing the PETSc DA I did not (by ignorance) follow the
>>>> layout approach of the MPI cartesian MPI_Cart_create (that gives
>>>> the first local cpus first in the y-direction).
>>>> I had it put the first cpus in the x-direction.
>>>> What you need to do is create a new communicator that changes the
>>>> order of the processors so that when used by the PETSc DA they
>>>> lie out in the ordering that matches the other code. You will
>>>> need to read up on the MPI_Cart stuff.
>>>> To change PETSC_COMM_WORLD you simply set PETSC_COMM_WORLD =
>>>> yournewcom BEFORE calling PetscInitialize().
>>>> Barry
>>>> On Jul 3, 2009, at 3:52 AM, Rolf Kuiper wrote:
>>>>> Hi,
>>>>> Am 30.06.2009 um 02:24 schrieb Barry Smith:
>>>>>> On Jun 29, 2009, at 7:07 PM, Rolf Kuiper wrote:
>>>>>>> Hi PETSc users,
>>>>>>> I ran into trouble in combining my developed PETSc application
>>>>>>> with another code (based on another library called "ArrayLib").
>>>>>>> The problem is the parallel layout for MPI, e.g. in 2D with 6
>>>>>>> cpus the ArrayLib code gives the names/ranks of the local cpus
>>>>>>> first in y-direction, than in x (from last to first, in the
>>>>>>> same way the MPI arrays are called, like 3Darray[z][y][x]):
>>>>>>> y
>>>>>>> | 2-4-6
>>>>>>> | 1-3-5
>>>>>>> |--------> x
>>>>>>> If I call DACreate() from PETSc, it will assume an ordering
>>>>>>> according to names/ranks first set in x-direction, than in y:
>>>>>>> y
>>>>>>> | 4-5-6
>>>>>>> | 1-2-3
>>>>>>> |--------> x
>>>>>>> Of course, if I now communicate the boundary values, I mix up
>>>>>>> the domain (build by the other program).
>>>>>>> Is there a possibility / a flag to set the name of the ranks?
>>>>>>> Due to the fact that my application is written and working in
>>>>>>> curvilinear coordinates and not in cartesian, I cannot just
>>>>>>> switch the directions.
>>>>>> What we recommend in this case is to just change the meaning of
>>>>>> x, y, and z when you use the PETSc DA.  This does mean changing
>>>>>> your code that uses the PETSc DA.
>>>>> The code is used as a module for many codes, so I would prefer
>>>>> to not change the code (and the meaning of directions, that's
>>>>> not user-friendly), but 'just' change the communicator.
>>>>>> I do not understand why curvilinear coordinates has anything to
>>>>>> do with it. Another choice is to create a new MPI communicator
>>>>>> that has the different ordering of the ranks of the processors
>>>>>> and then using that comm to create the PETSc DA objects; then
>>>>>> you would not need to change your code that calls PETSc.
>>>>> I tried some time before to use the PetscSetCommWorld() routine,
>>>>> but I can't find it anymore, how can I set a new communicator in
>>>>> PETSc3.0?
>>>>> The communicator, I want to use, is the MPI_COMM_WORLD, which
>>>>> takes the first described ordering.
>>>>> Now I read that the MPI_COMM_WORLD is the default communicator
>>>>> for PETSc. But why is the ordering than different?
>>>>> Sorry for all this question, but (as you can see) I really don't
>>>>> understand this comm problem at the moment,
>>>>> Thanks for all,
>>>>> Rolf
>>>>>> Unfortunately PETSc doesn't have any way to flip how the DA
>>>>>> handles the layout automatically.
>>>>>> Barry
>>>>>>> Thanks a lot for your help,
>>>>>>> Rolf
