MPI-layout of PETSc
    Rolf Kuiper
    kuiper at mpia-hd.mpg.de
    Fri Jul  3 12:09:00 CDT 2009
Hi Barry,
I tried that already with:
First way by copying:
MPI_Comm_dup(PETSC_COMM_WORLD, &MyComm);
Second way by creating:
int dims[3] = {0,0,0};
int ndims=3;
MPI_Dims_create(NumberOfProcessors, ndims, dims);
int false = 0; int true = 1;
int periods[3] = { false, false, true };
int reorder = true;
MPI_Comm MyComm;
MPI_Cart_create(PETSC_COMM_WORLD, ndims, dims, periods, reorder,
&MyComm);
in the end then:
PETSC_COMM_WORLD = MyComm;
I test the MyComm with MPI_Topo_test(); and it is cartesian, yes.
I can the coordinates of the cpus with MPI_Cart_coords(MyComm,
LocalRank, ndims, coords); , but I found no way to set/rearrange these
coordinates.
Do you can help me in that case or have I to ask a MPI-support?
Thanks for all,
Rolf
Am 03.07.2009 um 17:56 schrieb Barry Smith:
>   In designing the PETSc DA I did not (by ignorance) follow the
> layout approach of the MPI cartesian MPI_Cart_create (that gives the
> first local cpus first in the y-direction).
> I had it put the first cpus in the x-direction.
>   What you need to do is create a new communicator that changes the
> order of the processors so that when used by the PETSc DA they lie
> out in the ordering that matches the other code. You will need to
> read up on the MPI_Cart stuff.
>   To change PETSC_COMM_WORLD you simply set PETSC_COMM_WORLD =
> yournewcom BEFORE calling PetscInitialize().
>   Barry
> On Jul 3, 2009, at 3:52 AM, Rolf Kuiper wrote:
>> Hi,
>> Am 30.06.2009 um 02:24 schrieb Barry Smith:
>>> On Jun 29, 2009, at 7:07 PM, Rolf Kuiper wrote:
>>>> Hi PETSc users,
>>>> I ran into trouble in combining my developed PETSc application
>>>> with another code (based on another library called "ArrayLib").
>>>> The problem is the parallel layout for MPI, e.g. in 2D with 6
>>>> cpus the ArrayLib code gives the names/ranks of the local cpus
>>>> first in y-direction, than in x (from last to first, in the same
>>>> way the MPI arrays are called, like 3Darray[z][y][x]):
>>>> y
>>>> | 2-4-6
>>>> | 1-3-5
>>>> |--------> x
>>>> If I call DACreate() from PETSc, it will assume an ordering
>>>> according to names/ranks first set in x-direction, than in y:
>>>> y
>>>> | 4-5-6
>>>> | 1-2-3
>>>> |--------> x
>>>> Of course, if I now communicate the boundary values, I mix up the
>>>> domain (build by the other program).
>>>> Is there a possibility / a flag to set the name of the ranks?
>>>> Due to the fact that my application is written and working in
>>>> curvilinear coordinates and not in cartesian, I cannot just
>>>> switch the directions.
>>> What we recommend in this case is to just change the meaning of x,
>>> y, and z when you use the PETSc DA.  This does mean changing your
>>> code that uses the PETSc DA.
>> The code is used as a module for many codes, so I would prefer to
>> not change the code (and the meaning of directions, that's not user-
>> friendly), but 'just' change the communicator.
>>> I do not understand why curvilinear coordinates has anything to do
>>> with it. Another choice is to create a new MPI communicator that
>>> has the different ordering of the ranks of the processors and then
>>> using that comm to create the PETSc DA objects; then you would not
>>> need to change your code that calls PETSc.
>> I tried some time before to use the PetscSetCommWorld() routine,
>> but I can't find it anymore, how can I set a new communicator in
>> PETSc3.0?
>> The communicator, I want to use, is the MPI_COMM_WORLD, which takes
>> the first described ordering.
>> Now I read that the MPI_COMM_WORLD is the default communicator for
>> PETSc. But why is the ordering than different?
>> Sorry for all this question, but (as you can see) I really don't
>> understand this comm problem at the moment,
>> Thanks for all,
>> Rolf
>>> Unfortunately PETSc doesn't have any way to flip how the DA
>>> handles the layout automatically.
>>>  Barry
>>>> Thanks a lot for your help,
>>>> Rolf
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090703/4e7a21e9/attachment.htm>
