MatGetArrayF90 returns 2d array
Barry Smith
bsmith at mcs.anl.gov
Thu Jul 2 11:47:56 CDT 2009
MatGetArray() returns access to the nonzero values of the matrix in
a format that depends on the underlying class. It is a perfectly
reasonable method and has been there for decades just fine.
Barry
On Jul 1, 2009, at 5:54 PM, Matthew Knepley wrote:
> On Thu, Jul 2, 2009 at 2:36 AM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> Satish,
> Could you please convert these (both the stub code and the F90
> interface) to use a 1d array? In both 3.0.0 and petsc-dev.
> I am still against this, since it seems much nicer to get a 2D array
> for the dense matrix, which is the ONLY matrix for which GetArray()
> makes any sense I think.
> Matt
> Thanks
> Barry
> I thought the idea was that MatGetArray() never applies to a sparse
> matrix. No other sparse format supports this, does it?
> That's not true at all, but the result is implementation-dependent.
> For
> example, the array for AIJ is different from the array for BAIJ. For
> this reason, you shouldn't be calling MatGetArray unless you know the
> matrix type, but of course the F90 interface should agree with the C
> interface.
> Jed
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
