PCNN preconditioner
Andreas Grassl Andreas.Grassl at student.uibk.ac.at
Thu Feb 26 12:26:20 CST 2009
Ok, this would be easy. I didn't try it, because I was thinking, that I have to
mess around with more ISLocalToGlobal-stuff.
I'll try out and give a feedback.
cheers
ando
Barry Smith schrieb:
>     I'm sorry there is no example of the use of PCNN. Here is what you
> need to do.
> Use MatCreateIS() to create the matrix. Use MatSetValuesLocal() to put
> the values in the matrix
> then use PCSetType(pc,PCNN); to set the preconditioner to NN.
>    Barry
> Note: You cannot just use MatCreateMPIAIJ() to create the matrix because
> it needs the unassembled per processor parts to build the preconditioner.
> You cannot use MatSetValues() because then it could not have the
> unassembled matrix.
> On Feb 26, 2009, at 10:12 AM, Andreas Grassl wrote:
>> Hello,
>> I'm working with a FE-Software where I get out the element stiffness
>> matrices and the element-node correspondency to setup the stiffness
>> matrix for solving with PETSc.
>> Currently this is working fine for the seqaij matrix type and connected
>> solvers. Now I want to Implement the PCNN preconditioner.
>> Does anybody have any simple examples with this preconditioner?
>> Thank you in advance
>> ando
>> /"\                               Grassl Andreas
>> \ /    ASCII Ribbon Campaign      Uni Innsbruck Institut f. Mathematik
>>  X      against HTML email        Technikerstr. 13 Zi 709
>> / \                               +43 (0)512 507 6091
 \ /      ASCII Ribbon
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090226/109f2caa/attachment.pgp>
