output to matlab readable format
Khan, Irfan
irfan.khan at gatech.edu
Tue Feb 24 14:07:32 CST 2009
You will need to open a binary file to output the data. Try the following.
PetscViewer viewer;
ierr = PetscViewerBinaryOpen(PETSC_COMM_WORLD, "matrix", FILE_MODE_WRITE, &viewer);
ierr = MatView(Amat,viewer);
PetscViewerDestroy(viewer);
In order to load the file into matlab do the following
% $PETSC_DIR/bin/matlab/PetscBinaryRead("<path_to_file>")
Irfan
I use the following code to output matrix into file which can be read by
matlab,
PetscViewer aviewer;
PetscViewerCreate(PETSC_COMM_WORLD, &aviewer);
PetscViewerSetType(aviewer, PETSC_VIEWER_ASCII);
//PetscObjectSetName((PetscObject)sparseMechanicalStiffnessMatrix,
aname);
PetscViewerSetFormat(aviewer, PETSC_VIEWER_ASCII_MATLAB);
PetscViewerFileSetName(aviewer, aname);
MatView(sparseMechanicalStiffnessMatrix, aviewer);
PetscViewerDestroy(aviewer);
The error is ASCII format file doesn't allow the matrix exceeds 512
rows. So I change PETSC_VIEWER_ASCII to PETSC_VIEWER_BINARY, but it seem
that PETSc outputs to screen.
Thanks.
