external lib
Sun Feb 22 20:42:16 CST 2009
    When config/configure.py finishes it will print the various
libraries it is using. If successful ParMETIS will be listed.
    It is possible the capital letters in --with-ParMetis-dir you
wrote may cause it to be ignored. If so use --with-parmetis-dir
    In general it is better to have PETSc install ParMetis for you by
using --download-parmetis This will make sure the same compilers,
compiler options and version of ParMETIS that PETSc needs are used.
    Barry
On Feb 22, 2009, at 2:52 PM, enjoywm at cs.wm.edu wrote:
> Hi,
> I have installed ParMetis and then use the following commands to
> install
> PETSc
>> ./config/configure.py --with-ParMetis-dir=/home/ParMetis1.3/
>> make all
> How do I know PETSc has been installed with ParMetis successfully ?
> Thanks.
> Yixun
