rtol + initial guess nonzero
Thu Feb 19 15:18:41 CST 2009
    Yes, in fact it can be pretty complicated. The default convergence
test is KSPDefaultConverged() in src/ksp/ksp/interface/iterativ.c
    In the manual page for KSPDefaultConverged() you'll find the
cryptic When initial guess is non-zero you
           can call KSPDefaultConvergedSetUIRNorm() to use the norm of
(b - A*(initial guess))
           as the starting point for relative norm convergence testing.
    In the manual page for that function you'll see the option -
ksp_converged_use_initial_residual_norm you'll also see mention of the
manual
page for KSPDefaultConvergedSetUMIRNorm() and that manual page
mentions the option -ksp_converged_use_min_initial_residual_norm
    Thus there are basically three choices to use for the initial
residual norm.
    Barry
On Feb 19, 2009, at 2:58 PM, tribur at vision.ee.ethz.ch wrote:
> Dear petsc-people,
> can it be possible that the initial residuum norm used in rtol is
> always calculated by inserting zero, even if the initial guess is
> nonzero (using KSPSetInitialGuessNonzero)?
