config-options
Mon Feb 16 16:50:01 CST 2009
On Mon, 16 Feb 2009, Andreas Grassl wrote:
> >>> When you run configure with any set of options - and the run is
> >>> successful - you get a $PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py
> >>> file - with all these options listed in it.
> >> Ok, I start from a script like this and wanted to have the default options,
> >> which were not set explicitly to appear in a script as well.
> > Why?
> To have an overview of the settings and to get the full control over the
> default-options, but maybe I'm thinking too paranoid and I don't have to change
> any default-options.
I think you are trying to fix a problem that doesn't exit [or
insignificant].  Anyway your model will not achieve what you want.
PETSc configure behaves differently based on some options.
For eg: if '--with-cc' is specified - it uses it. But if not specified
- it guesses it [and tries a bunch of things].
So there is no way to dump a default 'value' for such things for
reuse. [The default in this case - is the absence of this option on
the configure command line]
Satish
