config-options
Barry Smith
bsmith at mcs.anl.gov
Mon Feb 16 16:16:03 CST 2009
On Feb 16, 2009, at 4:08 PM, Andreas Grassl wrote:
> Satish Balay schrieb:
>> On Mon, 16 Feb 2009, Andreas Grassl wrote:
>>> Hi,
>>> I played around with some configure options and adapted the python
>>> scripts from $PETSC_DIR/config/examples, but I didn't find an
>>> option to
>>> save the current standard options to such a script-file.
>> Not sure I understand the question.
>> When you run configure with any set of options - and the run is
>> successful - you get a $PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py
>> file - with all these options listed in it.
> Ok, I start from a script like this and wanted to have the default
> options,
> which were not set explicitly to appear in a script as well.
There are probably several hundred default options (of various
types) and they grow
weekly. This is probably why we never thought of providing a way to
have them all printed into the reconfigure-* file.
Barry
>>> Is there a possibility to get all the configure options?
>> Hmm - you can run configure with '--help' option - and it will list
>> all the options configure accepts.
> do I have to parse them out manually?
> cheers
> ando
> \ / ASCII Ribbon
> X against HTML email
