KSP solver efficiency
Fri Feb 13 16:56:16 CST 2009
On Fri, Feb 13, 2009 at 4:37 PM, Yixun Liu <enjoywm at cs.wm.edu> wrote:
> Hi,
> Assume  Ku=F is  a linear system assembled from element stiffness
> matrix. I want to use KSP to solve Ku=F. Assume the size of K is 100x100
> and the number of processors is 4.
> The question is does the efficiency of KSP depend on the structure of K?
> For example if each process owns 25 rows does the efficiency of the
> solver depend on the structure of K?
1) Strictly, yes it does.
2) Practically, not very much. You want to have at least a decent partition,
but
    after that the communication load is small since its a PDE, and scales
well.
3) Everything depends on the type of PDE. Krylov solvers will not work well
for
    everything, but for elliptic things they are good.
  Matt
> Thanks.
> Yixun
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090213/b74e68b3/attachment-0001.htm>
