how to get the MPIAIJ matrix information?
Yujie
recrusader at gmail.com
Fri Feb 13 11:57:54 CST 2009
thank you for your reply. Randy.
Actually, I have read the manual. In the manual, it just demonstrate how to
obtain this information from finite difference and finite element methods.
However, if I only have a MPIAIJ matrix, how to obtain this information? one
method is to use MatGetInfo() to my knolwedge, however, "info"'s structure
is as follows:
476: typedef struct {
477: PetscLogDouble block_size; /* block size */
478: PetscLogDouble nz_allocated,nz_used,nz_unneeded; /* number of nonzeros
479: PetscLogDouble memory; /* memory allocated */
480: PetscLogDouble assemblies; /* number of matrix assemblies called */
481: PetscLogDouble mallocs; /* number of mallocs during MatSetValues() */
482: PetscLogDouble fill_ratio_given,fill_ratio_needed; /* fill ratio for
LU/ILU */
483: PetscLogDouble factor_mallocs; /* number of mallocs during
factorization */
484: } MatInfo;
I am wondering what type PetscLogDouble is, double or int?
Yujie
On Fri, Feb 13, 2009 at 9:37 AM, Randall Mackie <rlmackie862 at gmail.com>wrote:
> Yujie,
> This is explained in the manual on page 59, under Preallocation of Memory
> for Parallel AIJ Sparse Matrices.
> Randy
> Yujie wrote:
>> Hi,
>> In MatCreateMPIAIJ() function, it needs d_nz, d_nnz[], o_nz, o_nnz[]. If
>> one has a MATAIJ matrix, how to obtian this information? thanks a lot.
>> PetscErrorCode PETSCMAT_DLLEXPORT MatCreateMPIAIJ(MPI_Comm comm,PetscInt
>> m,PetscInt n,PetscInt M,PetscInt N,PetscInt d_nz,const PetscInt
>> d_nnz[],PetscInt o_nz,const PetscInt o_nnz[],Mat *A)
>> Regards,
>> Yujie
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090213/ec014973/attachment.htm>
