link error
    Jed Brown
    jed at 59A2.org
    Fri Feb 13 01:07:56 CST 2009
On Thu 2009-02-12 09:00, Yixun Liu wrote:
> Thanks. Satish's method works. I add X11 to CMakeList.txt and it is ok.
> I also want to try  Jed's method to simplify the configuration. I
> download FindPetsc.cmake and I think I need add something like,
> FIND_PACKAGE (PETSC)
> into CMakeList. Right?
You normally distribute any nonstandard Find* modules with your
software, for instance $MYPROJECT/CMake/FindPETSc.cmake.  The start of
$MYPROJECT/CMakeLists.txt should look something like:
  project (MyProject)
  cmake_minimum_required (VERSION 2.6.2)
  list (APPEND CMAKE_MODULE_PATH "${MyProject_SOURCE_DIR}/CMake")
  find_package (PETSc REQUIRED)
  include_directories (${PETSC_INCLUDES})
  add_definitions (${PETSC_DEFINITIONS})
and link with
  target_link_libraries (myexecutable ${PETSC_LIBRARIES})
This is all the same as with other Find* modules.
Jed
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090213/a0a80734/attachment.pgp>
