How to use PETSc with sunf90?
Svend Tollak Munkejord
stm-direct_reply at pvv.org
Thu Feb 12 09:41:32 CST 2009
Thanks for the quick answer
On 2009-02-12, Satish Balay wrote:
> For one -it looks like its just a warning - so it can be ignored.
The one from sunf90 is a warning, but I think the one from ld is an
error (even if it doesn't say "errror"); my program isn't linked.
> [or
> you can manually edit petsc-3.0.0-p3/sunf90-optim/conf/petscvariables
> - and remove the option causing this warning]
Ah, that worked. Thank you!
> But ideally - you should be using '--with-cc=suncc --wth-cxx=sunCC'
> with sunf90 [not gcc/g++].
I agree, but this gives:
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
C++ compiler you provided with -with-cxx=sunCC does not work
configure.log contains things like
Possible ERROR while running linker: /usr/lib64/libm.so: file not recognized: File format not recognized
and I don't know how to fix it. I could send you the configure.log if
you like.
