How to use PETSc with sunf90?
Svend Tollak Munkejord stm-direct_reply at pvv.org
Thu Feb 12 08:28:27 CST 2009
I am trying to use petsc-3.0.0-p3 with the Sunstudio 12 Fortran
compiler. Everything worked until "make test". Then the linker
complained about unknown options. Does anyone know how to make this
work?
Here's my configure command (all on one line):
./config/configure.py --with-cc=gcc --with-fc=sunf90 --with-petsc-arch=sunf90-optim --with-debugging=no --download-mpich=1 --download-f-blas-lapack=1 --download-hypre=1
"make all" worked fine, but "make test" said:
--------------Error detected during compile or link!-----------------------
/home/vsl184/tmp/petsc/petsc-3.0.0-p3/sunf90-optim/bin/mpif90 -O  -o ex5f ex5f.o -Wl,-rpath,/home/vsl184/tmp/petsc/petsc-3.0.0-p3/sunf90-optim/lib -L/home/vsl184/tmp/petsc/petsc-3.0.0-p3/sunf90-optim/lib -lpetscsnes -lpetscksp -lpetscdm -lpetscmat -lpetscvec -lpetsc   -lX11 -Wl,-rpath,/home/vsl184/tmp/petsc/petsc-3.0.0-p3/sunf90-optim/lib -L/home/vsl184/tmp/petsc/petsc-3.0.0-p3/sunf90-optim/lib -lHYPRE -lmpichcxx -lstdc++ -lflapack -lfblas -lnsl -laio -lrt -L/home/vsl184/tmp/petsc/petsc-3.0.0-p3/sunf90-optim/lib -L/usr/lib64/gcc/x86_64-suse-linux/4.1.2 -L/usr/lib64 -L/lib64 -L/usr/x86_64-suse-linux/lib -ldl -lmpich -lpthread -lrt -lgcc_s -lmpichf90 -L/usr/local/linux/intel/fc_81_ia32/lib -L/usr/local/qwt/lib -L/home/vsl184/a/svendm/workdir/plot_on_runtime/lib -Wl,-rpath,/usr/local/sun/sunstudio12/lib/amd64:/opt/sun/sunstudio12/lib/amd64:/usr/local/sun/lib/rtlibs/amd64:/opt/sun/lib/rtlibs/amd64 -L/usr/local/sun/sunstudio12/lib/amd64 -L/usr/local/sun/sunstudio12/rtlibs/amd64 -L/usr/local/sun/sunstudio12/prod/lib/amd64 -lfui -lfai -lfsu -lmtsk -lm -Wl,-rpath,/usr/local/sun/sunstudio12/prod/lib/amd64 -lc_supp -lmpichcxx -lstdc++ -lmpichcxx -lstdc++ -ldl -lmpich -lpthread -lrt -lgcc_s -ldl
sunf90: Warning: Option -Wl,-rpath,/home/vsl184/tmp/petsc/petsc-3.0.0-p3/sunf90-optim/lib passed to ld, if ld is invoked, ignored otherwise
/usr/bin/ld: unrecognized option '-Wl,-rpath,/home/vsl184/tmp/petsc/petsc-3.0.0-p3/sunf90-optim/lib'
/usr/bin/ld: use the --help option for usage information
This is on an Opteron machine running Opensuse 10.2. I get the same
message on a Centrino laptop running Opensuse 11.1.
I can use gfortran, but I would also like to try sunf90, because in
some cases, sunf90 has produced faster-running code (i.e., when not
using PETSc).
