redistribution of vectors
Tue Feb 10 17:08:43 CST 2009
On Feb 10, 2009, at 5:01 PM, Stephan Kramer wrote:
>> You can certainly use a VecScatter to redistribute a vector. You
>> already have the
>> indices from MatGetSubMatrix() so it should be easy.
>> However, you can also use VecLoadIntoVector() and provide an initial
>> partitioning.
>>  Matt
> Ah brilliant, I must have overlooked these options (there are so
> many in PETSc!). In that case is there also something like
> VecLoadIntoVector for MatLoad, i.e. where I specify the distribution
> beforehand, otherwise I'll just go for the MatGetSubMatrix() +
> VecScatter().
    We don't currently have a MatLoadIntoVector(). The current plan is
to actually remove VecLoadIntoVector() and have both VecLoad() and
MatLoad() be essentially "load into" operations where one is free to
define the layout of the vector and matrix before or not thus getting
the full spectrum of possibilities in one clean interface. Sadly we
haven't done this reorganization due to having many other things to do.
> Just a small related question, for MatGetSubMatrix where I ask for
> the rows owned by each process but all columns, should I really
> assemble an index set ranging over all global indices? This seems a
> bit wasteful and non-scalable. Or should I put in the effort and,
> using information I have over my halo regions, work out which
> columns might have nonzeros for these rows. Or am I missing
> something and is there an easier short-cut?
    It is true that it is not totally scalable but then dumping some
huge honkying sparse matrix to a file and reading it in is not
scalable either. We've never had a problem with this yet for
reasonable matrix sizes. Rather than fixing this MatGetSubMatrix() ,
in your case, having a better MatLoad() merged with
MatLoadIntoMatrix() would be the thing I recommend optimizing. But
frankly until you get up to 1 billion unknowns what is there now is
probably good enough.
    Barry
> Thanks a lot
> Stephan
>>> Cheers
>>> Stephan
