redistribution of vectors
Stephan Kramer stephan.kramer at imperial.ac.uk
Tue Feb 10 14:11:26 CST 2009
I'm trying to pick up a linear system (matrix and rhs) that I've written
out in a previous parallel run using MatView and VecView in binary mode.
Now when I've read the matrix and rhs vector the rows are evenly
distributed by PETSc over the processes. The partioning previously used
in the parallel run however doesn't in general correspond to this even
distribution (the global node numbering is the same, but number of rows
are not exactly equal per process due to other constraints). So what I'm
trying to do is redistribute the read in matrix and vector to match the
previously used partioning. I've found that for the matrix this is easy
to do using MatGetSubMatrix(), but I'm a little stuck on how to do this
for the vector. Is there a similar way of doing this for the vector?
There seems to be no way of extracting vector values not stored on this
processor.
I've tried to look at src/ksp/ksp/examples/tutorials/example10.c where
something similar is done for a repartioning created by MatPartioning.
It does the redistribution of the matrix with MatGetSubMatrix() as I
expected, but then seems to do nothing for the vector (there is only a
comment:  /* need to move the vector also */ ).
Does this mean I just have to extract the vector values locally and do
some redistributing with MPI myself?
Cheers
Stephan
