Performance degradation after upgrade to 3.0.0
Billy Araújo billy at dem.uminho.pt
Mon Feb 2 03:59:33 CST 2009
I didn't send winmail.dat.
Maybe because was sent from outlook web access, I don't know... :)
Billy.
-----Original Message-----
From: petsc-users-bounces at mcs.anl.gov on behalf of Barry Smith
Sent: Sun 2/1/2009 11:24 PM
To: PETSc users list
Subject: Re: Performance degradation after upgrade to 3.0.0
    winmail.dat? Come on, be serious, we'd like to help you but not
all of us are chained to Bill Gates nightstand.
     Barry
On Feb 1, 2009, at 3:01 PM, Billy Araújo wrote:
> Hi,
> Here are the files that contain all the information below. You can
> see that the matrices are the same, unless I am missing something
> here. :)
> (I am resending them in compressed format).
> Regards,
> Billy.
> From: petsc-users-bounces at mcs.anl.gov on behalf of Matthew Knepley
> Sent: Sun 2/1/2009 6:07 PM
> In order to determine what is happening you first should:
>  1) Confirm that the solver setup is identical using -ksp_view for
> both versions
>  2) Determine that the matrices are identical. Output both matrices
> using
>      MatView() with a PetscBinaryViewer. You can diff the files, and
> you can also
>      solver both matrices using KSP ex10.
>  3) Look at the residuals using -ksp_monitor. If they are different,
> something
>      else has changed.
>  Matt
> On Sun, Feb 1, 2009 at 6:32 AM, Billy Araújo <billy at dem.uminho.pt>
> wrote:
>> Hi,
>> I have also verified that there has been a degradation of
>> performance using
>> the new 3.0 version:
>> This is my function calling PETSc:
>>  KSP ksp;
>>  PC pc;
>>  KSPCreate (PETSC_COMM_WORLD, &ksp);
>>  KSPSetOperators (ksp, *A, *A, DIFFERENT_NONZERO_PATTERN);
>>  KSPSetType (ksp, KSPFGMRES);
>>  KSPGetPC (ksp, &pc);
>>  PCSetType (pc, PrecondProc);
>>  KSPSetInitialGuessNonzero (ksp, PETSC_TRUE);
>>  KSPSetTolerances (ksp, 1E-50, maxtol, PETSC_DEFAULT, maxiter);
>>  KSPSetFromOptions (ksp);
>>  KSPSolve (ksp, *b, *x);
>>  KSPGetIterationNumber (ksp, iter);
>>  KSPGetResidualNorm (ksp, res);
>>  KSPDestroy (ksp);
>> with previous version 2.3.3-p6:
>> Number of iterations: 42 Residual: +7.073781E-13 Time: +8.615024E-03
>> now:
>> Number of iterations: 500 Residual: +2.746161E-05 Time: +1.026870E-01
>> It is reaching maximum number of iterations. The only thing I
>> changed was:
>> MatSetOption (*A, MAT_SYMMETRIC);
>> to
>> MatSetOption (*A, MAT_SYMMETRIC, PETSC_TRUE);
>> I think I didn't change anything else.
>> Regards,
>> Billy.
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <winmail.dat>
Name: not available
Type: application/ms-tnef
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090202/8a49c84b/attachment.bin>
