[petsc-users] matrix visualization problem
hxie at umn.edu
hxie at umn.edu
Wed Dec 23 15:49:10 CST 2009
Thanks. When I try to run with the option "-ksp_xmonitor", no window pops
up. Do I need to reinstall the petsc with the option --with-x=1? BTW, if I
want to use some external packages, do I have to reinstall the petsc?
Happy holiday,
Hui
well if you need -mat_view_draw - then suggest editing
src/mat/impls/aij/mpi/mpiaij.c and increate this cut-off size.
[there is now a command-line option to over-ride this limit in petsc-dev]
For binary viewer - check mat/examples/tests/ex31.c
Satish
