[petsc-users] KSPBuildResidual
Wed Dec 23 08:04:30 CST 2009
    If you want to use the true residual norm then use GMRES with
right preconditioning. KSPSetPreconditionerSide()
     Barry
On Dec 23, 2009, at 5:01 AM, jarunan at ascomp.ch wrote:
> Dear Petsc-Team
> I am using KSPBuildResidual() to calculate true residual and use it
> as convergence criteria. It means the program will call
> KSPBuildResidual every iteration. I choose GMRES as a solver but I
> read in manual, it is written that this command is expensive for
> GMRES and some other solvers.
> Is it also expensive for BICGSTAB?
> Is there other possibility to calculate true residual without
> calling KSPBuildResidual() or KSPBuildSolution() ?
> Best regards,
> Jarunan
> Quoting Rob Ellis <Robert.G.Ellis at Shaw.ca>:
>> Hi Dave,
>> Thanks! That's what I needed to know.
>> Cheers,
>> Rob
>> From: petsc-users-bounces at mcs.anl.gov
>> [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Dave May
>> Sent: Tuesday, December 22, 2009 10:13 AM
>> To: PETSc users list
>> Subject: Re: [petsc-users] Two ways to set Vec values?
>> Hey Rob
>>    If you are sure that you only want to insert values locally into
>> x, then
>> option 1 will be faster.
>> Option 2 will communicate values if the inserted values live on
>> another
>> processor. If you don't need to send any data, use Option 1.
>> On Tue, Dec 22, 2009 at 7:04 PM, Rob Ellis <Robert.G.Ellis at shaw.ca>
>> wrote:
>> Hi Petsc'ers
>> Can someone please let me know if I can set MPI vector values using
>> either
>> of the following methods? I wish to set the values of 'x' from the
>> values in
>> 'work'. Both methods operate correctly, but I would like to know
>> which is
>> more efficient, and/or recommended and why.
>> 1. GetArray/RestoreArray Method:
>> call VecGetOwnershipRange(x,imin,imax,ierr)
>> call VecGetArray(x,x_local_v,x_local_i,ierr)
>> do i=imin,imax-1
>> x_local(i-imin)=work(i+1)
>> enddo
>> call VecRestoreArray(x,x_local_v,x_local_i,ierr)
>> 2. SetValues/VecAssembly Method:
>> nx_local = imax-imin
>> do i=imin,imax-1
>> icol(i-imin+1)=i
>> enddo
>> call VecSetValues(x,nx_local,icol,work(imin+1),INSERT_VALUES,ierr)
>> call VecAssemblyBegin(x,ierr)
>> call VecAssemblyEnd(x,ierr)
>> Method 1 is more compact and does not require the auxiliary column
>> number
>> vector, nor does it require the VecAssembly, however, it seems to
>> be what is
>> suggested by the examples. Also, is it recommended to use
>> VecGetArrayF90?
>> Thanks for your help,
>> Cheers,
>> Rob
> Jarunan Panyasantisuk
> Development Engineer
> ASCOMP GmbH, Technoparkstr. 1
> CH-8005 Zurich, Switzerland
> Phone : +41 44 445 4072
> Fax   : +41 44 445 4075
> E-mail: jarunan at ascomp.ch
> www.ascomp.ch
> Winter Training on TransAT: Zurich, 20 Feb. 2010.
> http://ascomp.ch/training.html
