[petsc-users] Two ways to set Vec values?
Dave May dave.mayhem23 at gmail.com
Tue Dec 22 12:12:36 CST 2009
Hey Rob
    If you are sure that you only want to insert values locally into x, then
option 1 will be faster.
Option 2 will communicate values if the inserted values live on another
processor. If you don't need to send any data, use Option 1.
On Tue, Dec 22, 2009 at 7:04 PM, Rob Ellis <Robert.G.Ellis at shaw.ca> wrote:
> Hi Petsc'ers
> Can someone please let me know if I can set MPI vector values using either
> of the following methods? I wish to set the values of 'x' from the values
> in
> 'work'. Both methods operate correctly, but I would like to know which is
> more efficient, and/or recommended and why.
> 1. GetArray/RestoreArray Method:
> call VecGetOwnershipRange(x,imin,imax,ierr)
> call VecGetArray(x,x_local_v,x_local_i,ierr)
> do i=imin,imax-1
>  x_local(i-imin)=work(i+1)
> enddo
> call VecRestoreArray(x,x_local_v,x_local_i,ierr)
> 2. SetValues/VecAssembly Method:
> nx_local = imax-imin
> do i=imin,imax-1
>  icol(i-imin+1)=i
> enddo
> call VecSetValues(x,nx_local,icol,work(imin+1),INSERT_VALUES,ierr)
> call VecAssemblyBegin(x,ierr)
> call VecAssemblyEnd(x,ierr)
> Method 1 is more compact and does not require the auxiliary column number
> vector, nor does it require the VecAssembly, however, it seems to be what
> is
> suggested by the examples. Also, is it recommended to use VecGetArrayF90?
> Thanks for your help,
> Cheers,
> Rob
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091222/34287b6f/attachment.htm>
