[petsc-users] create a matrix in C++ constructor
Umut Tabak
u.tabak at tudelft.nl
Mon Dec 21 17:01:31 CST 2009
Dear all,
I was trying to wrap around some Petsc code into a class, so that there
is a neat interface and implementation, I got into a problem at the very
beginning and did not understand the reason maybe some of you could help
me to understand this.
I have a Matrix A in the private section of my simple class.
And I would like to create this matrix inside the class ctor. Whenever I
call the MatCreate function I get a segmentation fault with
MatCreate(MPI_COMM_SELF, &A)
I checked the documentation that the Matrices in Petsc are also pointers.
The point I did not understand is that if there is a pointer member of a
class, say
private:
int* b
I can initialize that to null in the constructor and make the necessary
allocation with some member functions. With the same reasoning I thought
that If I do not apply similar null pointer assignment for the
matrix(there is not such thing I suppose) that I would like to
initialize in the ctor, I will get a segfault. I could not figure my way
out and wondered when you write the topdown code. I mean in the code below,
Mat A;
MatCreate(MPI_COMM_SELF, &A);
MatSetSizes(A, m, n, 0, 0);
MatSetType(A,MATSEQAIJ);
"Mat A" initializes the pointer to null internally, am I right? Is there
sth similar for the above class situation or am I mistaken at some other
point(which could be highly likely)?
Any pointers are appreciated.
Umut
