installation problems in mac machine
hxie at umn.edu
hxie at umn.edu
Mon Dec 21 15:04:59 CST 2009
My operation system is Mac OS X 10.6.2. I unzip the petsc under
/usr/local/petsc-3.0.0-p10.
I use the following to configure petsc.
sudo ./config/configure.py --CFLAGS=-O3 --FFLAGS=-O3
--with-mpi-dir=/usr/local/mpich2-1.2.1 --with-fortran --with-shared=0
--with-fc=gfortran
And I run the following commands:
export PETS_ARCH=darwin10.2.0-c-debug;
PETSC_DIR=/usr/local/petsc-3.0.0-p10; export PETSC_DIR
When I run " sudo make all", it gives some errors:
makefile:15: /conf/base: No such file or directory
makefile:16: /conf/test: No such file or directory
make: *** No rule to make target `/conf/test'. Stop.
It seems it cannot find the PETSC_DIR. (I use x11. "echo $SHELL" gets
"/bin/bash")
Do I need to add "PETSC_DIR = /usr/local/petsc-3.0.0-p10" in the makefile
file? Thanks.
Bests,
Hui
