KSP Tolerances
jarunan at ascomp.ch jarunan at ascomp.ch
Mon Dec 14 09:07:16 CST 2009
Thank you for your advice. With this mail I attach the output file run.log.
My grid is 2-level grid. The coarse grid is computed first then the
fine grid. The problem occur in the fine grid. You can see at lines
3098, 4552 and 6127 where it is diverged.
Jarunan
Quoting Matthew Knepley <knepley at gmail.com>:
> Run with -ksp_view -ksp_monitor -info and send us all the output.
>   Matt
> On Mon, Dec 14, 2009 at 8:36 AM, <jarunan at ascomp.ch> wrote:
>> Dear Petsc Team,
>> There is something not clear for me about divergence tolerance. Firstly, my
>> computation diverges with the reason of dtol (-4), which was set by default
>> (10000). When I increased dtol to 1.0e+8, it became converged. However, the
>> relative residual where it was diverged is less than the default dtol. I
>> would like to know, how it is exactly calculated.
>> ----------I describe my problem more in detail here.-------------------
>> As I set the tolerances for the solver as below, my problem diverges with
>> converged reason -4 (from divergence tolerance)
>> call KSPSetTolerances(ksp,1.0e-06,1.0e-20,
>> PETSC_DEFAULT_DOUBLE_PRECISION,10000,ierr)
>> I monitor the residual. it printed the information below and quit the
>> computation.(I delete the true residual norm and Ax/Ae. Please tell me if
>> you need them.)
>>   0 KSP preconditioned resid norm 5.139790011051e+02
>> With -ksp_view, it shows that default value of dtol is 10000. I increased
>> dtol to 1.0e+8, then the solver solved the problem. With
>> -ksp_monitor_true_residual, the first 5 iterations read:
>>  1 KSP preconditioned resid norm 1.840751662590e+01
>>  2 KSP preconditioned resid norm 3.653339750400e+00
>>  3 KSP preconditioned resid norm 2.538794826933e+00
>>  4 KSP preconditioned resid norm 2.299844715275e-01
>> Here, from iteration 0 to iteration 1,the relative residual is 0.03580,
>> much less than 1.0e+4 the default dtol value. So, why was it diverged at the
>> first time?
>> Regards,
>> Jarunan
>> Jarunan Panyasantisuk
>> Development Engineer
>> ASCOMP GmbH, Technoparkstr. 1
>> CH-8005 Zurich, Switzerland
>> Phone : +41 44 445 4072
>> Fax   : +41 44 445 4075
>> E-mail: jarunan at ascomp.ch
>> www.ascomp.ch
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
www.ascomp.ch
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091214/c7c259de/attachment-0001.bin>
