ksp ex29.c B.C.s and Forcing terms.
Barry Smith
bsmith at mcs.anl.gov
Sat Dec 12 13:57:38 CST 2009
On Dec 12, 2009, at 12:31 PM, Tahar Amari wrote:
> Hello,
> SOrry. I took this very interesting discussion a bit late, but one
> of my major problem is to understand if all this is valid for node
> centered
> variables for u or cell centered.
> Usually the best way of solving Neuwman BC for this equation is
> having cell centered unknowns to have derivatives
> given on the domain boundary.
> This then have some impact on handling ghost values transfer between
> subdomains with MPI.Is all this transparent for
> us and PETSC handle it . I guess no, right ?
If you have only cell centered unknowns the ghost point updates are
the same. See src/ksp/ksp/examples/tutorials/ex32.c Having some
Neuman and some Dirichlet boundary conditions is then trickery with
cell centered.
If you have some cell-centered and some vertex centered unknowns
(staggered grid), DA does not handle this well, you have to "cheat" to
match up variables on the cells and vertices.
Barry
> Tahar
> Le 12 déc. 09 à 02:28, Barry Smith a écrit :
>> On Dec 11, 2009, at 7:18 PM, Ryan Yan wrote:
>>> Hi Matt,
>>> Thank you very much for the reply. Now, I got the Neumann part.
>>> But I am still a bit confused about the Dirichlet part. Please see
>>> the following quote.
>>> Yan
>>> For the Dirichlet B.C.s, I did not understand the coefficients
>>> given below. Isn't correct to set the v[0]=Hx*Hy here?
>>> if (i==0 || j==0 || i==mx-1 || j==my-1) {
>>> if (user->bcType == DIRICHLET) {
>>> v[0] = 2.0*rho*(HxdHy + HydHx);
>>> This is the proper scaling.
>>> the Dirichlet B.C.s:
>>> Which scaling do you think is proper, "v[0]=Hx*Hy" or
>>> 2.0*rho*(HxdHy + HydHx)?
>>> If it is 2.0*rho*(HxdHy + HydHx), can you say a little bit more
>>> about why is this one? I only see a factor of Hx*Hy when we set up
>>> the RHS. Did I miss something?
>> Ryan,
>> You can scale the equations for Dirichlet boundary conditions
>> anyway you want; you could multiply them by 1,000,000 if you want.
>> The answer in exact precision with direct solvers will be the same.
>> The reason we use the given scaling is to make the scaling work
>> well with multigrid. If you use a different scaling the Dirichlet
>> boundary conditions on the coarser grid matrices would have a
>> different scaling then the interior equations and this would slow
>> down MG's convergence rate. For toy problems people usually
>> eliminate the Dirichlet boundary conditions, then there is no
>> scaling issue for multigrid.
>> Barry
>>> Matt
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to
>>> which their experiments lead.
>>> -- Norbert Wiener
> T. Amari
> Centre de Physique Theorique
> Ecole Polytechnique
> 91128 Palaiseau Cedex France
> tel : 33 1 69 33 42 52
> fax: 33 1 69 33 49 49
> email: <mailto:amari at cpht.polytechnique.fr>
> URL : http://www.cpht.polytechnique.fr/cpht/amari
