ksp ex29.c B.C.s and Forcing terms.
Fri Dec 11 19:28:02 CST 2009
On Dec 11, 2009, at 7:18 PM, Ryan Yan wrote:
> Hi Matt,
> Thank you very much for the reply.  Now, I got the Neumann part. But
> I am still a bit confused about the Dirichlet part. Please see the
> following quote.
> Yan
> For the Dirichlet B.C.s, I did not understand the coefficients given
> below. Isn't correct to set the v[0]=Hx*Hy here?
> if (i==0 || j==0 || i==mx-1 || j==my-1) {
> if (user->bcType == DIRICHLET) {
>   v[0] = 2.0*rho*(HxdHy + HydHx);
> This is the proper scaling.
> the Dirichlet B.C.s:
> Which  scaling  do you think is proper, "v[0]=Hx*Hy" or
> 2.0*rho*(HxdHy + HydHx)?
> If it is 2.0*rho*(HxdHy + HydHx), can you say a little bit more
> about why is this one? I only see a factor of Hx*Hy when we set up
> the  RHS. Did I miss something?
    Ryan,
      You can scale the equations for Dirichlet boundary conditions
anyway you want; you could multiply them by 1,000,000 if you want. The
answer in exact precision with direct solvers will be the same. The
reason we use the given scaling is to make the scaling work well with
multigrid. If you use a different scaling the Dirichlet boundary
conditions on the coarser grid matrices would have a different scaling
then the interior equations and this would slow down MG's convergence
rate. For toy problems people usually eliminate the Dirichlet boundary
conditions, then there is no scaling issue for multigrid.
    Barry
>   Matt
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
