clarification about convergence
Dominik Szczerba
dominik at itis.ethz.ch
Wed Dec 9 14:44:12 CST 2009
Barry Smith wrote:
> On Dec 9, 2009, at 2:06 PM, Dominik Szczerba wrote:
>> Great hint, I found the tolerances not as I was setting them...
>> Which brings me to the problem how to consistently set them. I am
>> calling first:
>> PetscOptionsInsertString()
>> where I obtain the string from a user config file, and then am
>> calling several times later:
>> KSPSetFromOptions()
>> I found experimentally that only the options ABSENT in the config
>> string are eventually accepted from the command line. Those that
>> were PRESENT will not be overwriten from the commandline - behavior
>> not quite intuitive. Or am I doing something wrong?
> You call PetscInitialize(args) then PetscOptionsInsertString().
> The args are processed before the string since it comes first. If you
> want to process the string first then the args you can do:
> PetscInitialize(args); PetscOptionsInsertString();
> PetscOptionsInsert(args); now the args will overwrite the string.
Great! Thanks a lot.
Dominik
> You can also pass PetscOptionsInsertFile() to pass options
> directly from a file
> Barry
>> Is there a way to completely disable processing of the options from
>> the command line? Or at least to specify what has higher priority? I
>> prefer to set the options only in one way not to confuse the users.
>> Many thanks,
>> Dominik
>> Matthew Knepley wrote:
>>> On Wed, Dec 9, 2009 at 12:49 PM, Dominik Szczerba <dominik at itis.ethz.ch
>>> <mailto:dominik at itis.ethz.ch>> wrote:
>>> Excellent point. Where it broke the reason was:
>>> Starting KSPSolve
>>> 0 KSP Residual norm 7.841852910113e-04
>>> 1 KSP Residual norm 8.927576540999e-05
>>> 2 KSP Residual norm 1.694401713084e-05
>>> 3 KSP Residual norm 5.069425875318e-06
>>> Linear solve converged due to CONVERGED_RTOL iterations 3
>>> which I assume means that the norm became exactly 0
>>> I don't think so. It would have printed that for the residual.
>>> HOWEVER: putting -ksp_rtol -1 still does not eliminate the
>>> problem.
>>> Any further suggestions?
>>> You -ksp_view to see the tolerances used.
>>> Matt
>>> Dominik
>>> Did you use -ksp_converged_reason to determine why PETSc
>>> stopped
>>> iterating?
>>> Matt
>>> On Wed, Dec 9, 2009 at 11:45 AM, Dominik Szczerba
>>> <dominik at itis.ethz.ch <mailto:dominik at itis.ethz.ch>
>>> <mailto:dominik at itis.ethz.ch <mailto:dominik at itis.ethz.ch>>>
>>> wrote:
>>> I am using
>>> -ksp_rtol 0 -ksp_atol 1e-6 (defaults for all the rest)
>>> and observe for most of the times convergence, as expected.
>>> Starting KSPSolve
>>> 0 KSP Residual norm 6.315132950112e-04
>>> 1 KSP Residual norm 9.139539245601e-05
>>> 2 KSP Residual norm 1.869750068013e-05
>>> 3 KSP Residual norm 6.788145356909e-06
>>> 4 KSP Residual norm 1.729115712274e-06
>>> 5 KSP Residual norm 7.214445966641e-07
>>> solved in 2.328146e+00/4.144644e+00 s
>>> solution converged in 5 iterations
>>> ||Ax-b|| = 7.21445e-07
>>> with ||...|| being residue computed on my own for a check.
>>> However, SOMETIMES, I do observe:
>>> Starting KSPSolve
>>> 0 KSP Residual norm 1.228562818225e-02
>>> 1 KSP Residual norm 4.045833318123e-04
>>> 2 KSP Residual norm 6.589999324657e-05
>>> 3 KSP Residual norm 1.494849372638e-05
>>> 4 KSP Residual norm 4.311592172896e-06
>>> solved in 1.368086e+00/2.235830e+00 s
>>> solution converged in 4 iterations
>>> ||Ax-b|| = 4.31159e-06
>>> which means that the iterations break sooner than they
>>> should.
>>> Again, this is not often, but worries me why this should
>>> happen...
>>> Using or not -ksp_converged_use_initial_residual_norm does
>>> not make
>>> any difference to this behavior: the last output Residual
>>> norm is
>>> sometimes higher than the requested atol.
>>> Any clarifications are highly appreciated.
>>> Dominik
>>> -- What most experimenters take for granted before
>>> they begin their
>>> experiments is infinitely more interesting than any results to
>>> which their experiments lead.
>>> -- Norbert Wiener
>>> What most experimenters take for granted before they begin their
>>> -- Norbert Wiener
