clarification about convergence
Matthew Knepley
knepley at gmail.com
Wed Dec 9 13:04:20 CST 2009
On Wed, Dec 9, 2009 at 12:49 PM, Dominik Szczerba <dominik at itis.ethz.ch>wrote:
> Excellent point. Where it broke the reason was:
> Starting KSPSolve
> 0 KSP Residual norm 7.841852910113e-04
> 1 KSP Residual norm 8.927576540999e-05
> 2 KSP Residual norm 1.694401713084e-05
> 3 KSP Residual norm 5.069425875318e-06
> Linear solve converged due to CONVERGED_RTOL iterations 3
> which I assume means that the norm became exactly 0
I don't think so. It would have printed that for the residual.
> HOWEVER: putting -ksp_rtol -1 still does not eliminate the problem. Any
> further suggestions?
You -ksp_view to see the tolerances used.
Matt
> Dominik
> Matthew Knepley wrote:
>> Did you use -ksp_converged_reason to determine why PETSc stopped
>> iterating?
>> Matt
>> On Wed, Dec 9, 2009 at 11:45 AM, Dominik Szczerba <dominik at itis.ethz.ch<mailto:
>> dominik at itis.ethz.ch>> wrote:
>> I am using
>> -ksp_rtol 0 -ksp_atol 1e-6 (defaults for all the rest)
>> and observe for most of the times convergence, as expected.
>> Starting KSPSolve
>> 0 KSP Residual norm 6.315132950112e-04
>> 1 KSP Residual norm 9.139539245601e-05
>> 2 KSP Residual norm 1.869750068013e-05
>> 3 KSP Residual norm 6.788145356909e-06
>> 4 KSP Residual norm 1.729115712274e-06
>> 5 KSP Residual norm 7.214445966641e-07
>> solved in 2.328146e+00/4.144644e+00 s
>> solution converged in 5 iterations
>> ||Ax-b|| = 7.21445e-07
>> with ||...|| being residue computed on my own for a check.
>> However, SOMETIMES, I do observe:
>> Starting KSPSolve
>> 0 KSP Residual norm 1.228562818225e-02
>> 1 KSP Residual norm 4.045833318123e-04
>> 2 KSP Residual norm 6.589999324657e-05
>> 3 KSP Residual norm 1.494849372638e-05
>> 4 KSP Residual norm 4.311592172896e-06
>> solved in 1.368086e+00/2.235830e+00 s
>> solution converged in 4 iterations
>> ||Ax-b|| = 4.31159e-06
>> which means that the iterations break sooner than they should.
>> Again, this is not often, but worries me why this should happen...
>> Using or not -ksp_converged_use_initial_residual_norm does not make
>> any difference to this behavior: the last output Residual norm is
>> sometimes higher than the requested atol.
>> Any clarifications are highly appreciated.
>> Dominik
>> experiments lead.
>> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091209/0b498838/attachment.htm>
