How to declare an array of ksp object in fortran?
Mon Dec 7 15:08:45 CST 2009
    In Fortran you need to declare an array that is "big enough", so,
for example, if you know there are always less then 10 block per
process you can do
    KSP     subksp(10)
    less than 100 then use
    KSP  subksp(100)
    note that since this is just an array of pointers it takes very
little space.
    Barry
On Dec 7, 2009, at 2:02 PM, Matthew Knepley wrote:
> I realized you only wanted to know how to declare the array. It is
> just a normal F77 array.
>   Matt
> On Mon, Dec 7, 2009 at 2:00 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> 1) Always use options. It makes you code generic and process more
> flexible
> 2) If after thinking for a few hours, you still really want to do it
> in the code:
>   http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/PC/PCBJacobiGetSubKSP.html
>    Matt
> On Mon, Dec 7, 2009 at 11:52 AM, <hxie at umn.edu> wrote:
> Hi,
> I try to customize the subksp for block jacobi method. Does anybody
> have an fortran example for this?
> For c language, we can declare "ksp *subksp". Then how for fortran?
> Thanks.
> Bests,
> Hui
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> -- Norbert Wiener
