zero'ing parts of blocks
Matthew Knepley
knepley at gmail.com
Fri Dec 4 13:53:31 CST 2009
On Fri, Dec 4, 2009 at 12:58 PM, Craig Tanis <craig-tanis at utc.edu> wrote:
> First of all, thanks for all the help on my recent questions! Here's a new
> one:
> I have multiple degrees of freedom per node in an unstructured mesh. I
> have set up an AO to get the PETSC ordering for these global nodes, and
> then a LocalToGlobalMapping to map local indices to these AO-renumbered
> global nodes. This appears to be working correctly.
> I create a Mat of type MATMPIBAIJ, and I use MatSetValuesBlockedLocal to
> add things to my matrix, as expected. I have some boundary conditions that
> require certain rows within certain blocks to be zeroed out. Conceptually,
> I would like to use MatZeroRowsLocal (which appears to operate on individual
> rows.. not on constituent blocks). The problem is that this call complains
> that I have not set a LocalToGlobalMapping (since I've only set the block
> one).
> Is it common (or even possible) to register a LocalToGlobalMapping a
> LocalToGlobalMappingBlock for a given Mat?
> Is there a way to extrapolate one from the other?
The easiest thing to do is take your block l2g mapping and produce a
row-wise l2g mapping by unrolling the
blocks. Set that in the matrix. Then the MatZeroRowsLocal will work.
Matt
> If there is no way to Zero these rows individually, am I forced to get the
> block values, zero out the rows manually and then INSERT them back in?
> thanks again,
> Craig
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091204/8b0dd249/attachment.htm>
