MATMPIAIJ vs MATMPIBAIJ
jarunan at ascomp.ch
Thu Dec 3 08:51:00 CST 2009
Thank you very much, Jed.
I understand it now.
Jarunan
Quoting Jed Brown <jed at 59A2.org>:
> On Thu, 03 Dec 2009 11:40:14 +0100, jarunan at ascomp.ch wrote:
>> Could I use BAIJ format if my block size is not the same in each
>> block?
> No, but AIJ uses Inodes when you have adjacent rows with the same
> nonzero pattern, this gives some advantages of BAIJ in sparse matrix
> kernels (MatMult, MatSolve, MatRelax).
>> At the end of the day, would these 2 structures of matrix affect
>> differently in solving performance such as speed up?
> This is very dependent on the preconditioner. BAIJ reduces memory usage
> from 12 bytes per nonzero to about 8 (assuming scalar=double, 32-bit
> indices), and makes memory access slightly more regular. Despite AIJ
> using Inodes, I frequently see BAIJ being faster by this ratio (8/12).
> BAIJ can reduce setup time (factorization) by a larger factor.
> Sometimes it is worth storing a small number of explicit zeros in order
> to have constant block size. Note that many third-party preconditioners
> can not use BAIJ, but if you insert values with MatSetValuesBlock, you
> can still always run with -mat_type aij.
> Jed
Jarunan Panyasantisuk
Development Engineer
ASCOMP GmbH, Technoparkstr. 1
CH-8005 Zurich, Switzerland
Phone : +41 44 445 4072
Fax : +41 44 445 4075
E-mail: jarunan at ascomp.ch
www.ascomp.ch
