How to copy global data to local ?
Tue Dec 1 08:23:17 CST 2009
On Nov 30, 2009, at 11:21 PM, ming zhu wrote:
> Hi
> I have a huge matrix U for all processors (PETSC_COMM_WORLD). I only
> want to copy only two rows (i,j) for each local processor. i,j is
> different for each processor and not related to rank.  I was trying
> to use a vector filter (like, 00000010000). However, if the vector
> is PETSC_COMM_WORLD, it will be changed by different processor. So,
> how to make it ?
    I do not understand what this means. To do the multiply you can
and should use a vector of PETSC_COMM_WORLD.
    Also multiplying by a vector will not give you back "rows" of a
matrix. Do you truly want the entire row of nonzeros of the matrix or
something else. If you want the entire row or part of a row then you
can use MatGetSubMatrix().
    Barry
> Thank you
> My original code is
> Vec filter
> VecCreate(PETSC_COMM_WORLD,&filter);
> VecSetsizes(filter,PETSC_DECIDE,m);
> VecSetFromOptions(filter);
> Vecset(filter,0);
> VecSetValue(filter,i,1,INSERT_VALUES);
> MatMult(U, filter,ui);
> If I create filter with PETSC_COMM_SELF, it is impossible for U and
> filter to multiply.
> 好玩贺卡等你发,邮箱贺卡全新上线!
