Multigrid Questions
Hal Finkel hal.finkel at yale.edu
Wed Aug 26 16:11:51 CDT 2009
Barry,
Because the solve never completes, you never see the -snes_view output.
Here is the 2-level case.
With -dmmg_grid_sequence (you actually do see the -snes_view output this
time, so maybe without this flag even the coarse solve never finishes?):
     0 SNES Function norm 5.473992351804e+03
         0 KSP preconditioned resid norm 2.533502558402e+01 true resid
norm 5.473992351804e+03 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.968743708214e-11 true resid
norm 1.324235124537e-11 ||Ae||/||Ax|| 2.419139522729e-15
     1 SNES Function norm 1.624916397041e-01
         0 KSP preconditioned resid norm 2.944703982502e-04 true resid
norm 1.624916397041e-01 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.360780048165e-06 true resid
norm 1.281855538252e-03 ||Ae||/||Ax|| 7.888747633945e-03
     2 SNES Function norm 1.281855487791e-03
         0 KSP preconditioned resid norm 3.360764482735e-06 true resid
norm 1.281855487791e-03 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 5.416556005968e-08 true resid
norm 2.978313158215e-05 ||Ae||/||Ax|| 2.323439097919e-02
     3 SNES Function norm 2.978313156388e-05
SNES Object:
   type: ls
     line search variant: SNESLineSearchCubic
     alpha=0.0001, maxstep=1e+08, minlambda=1e-12
   maximum iterations=50, maximum function evaluations=10000
   tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
   total number of linear solver iterations=3
   total number of function evaluations=4
   KSP Object:
     type: preonly
     maximum iterations=10000, initial guess is zero
     tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
     right preconditioning
   PC Object:
     type: mg
       MG: type is FULL, levels=1 cycles=v
     Coarse gride solver -- level 0 presmooths=1 postsmooths=1 -----
       KSP Object:(mg_levels_0_)
         type: gmres
           GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
           GMRES: happy breakdown tolerance 1e-30
         maximum iterations=1, initial guess is zero
         left preconditioning
       PC Object:(mg_levels_0_)
         type: lu
           LU: out-of-place factorization
             matrix ordering: nd
           LU: tolerance for zero pivot 1e-12
           LU: factor fill ratio needed 10.3934
                Factored matrix follows
               Matrix Object:
                 type=seqaij, rows=1458, cols=1458
                 package used to perform factorization: petsc
                 total: nonzeros=818292, allocated nonzeros=818292
                   using I-node routines: found 640 nodes, limit used is 5
         linear system matrix = precond matrix:
         Matrix Object:
           total: nonzeros=78732, allocated nonzeros=78732
             using I-node routines: found 729 nodes, limit used is 5
     Matrix Object:
   0 SNES Function norm 1.308698287351e+00
     0 KSP preconditioned resid norm 1.308698287351e+00 true resid norm
1.308698287351e+00 ||Ae||/||Ax|| 1.000000000000e+00
         0 KSP preconditioned resid norm 2.671892130808e-01 true resid
norm 1.866582511975e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.246743442682e-13 true resid
norm 1.380198967143e-12 ||Ae||/||Ax|| 7.394256392572e-13
       0 KSP preconditioned resid norm 4.951265543603e-01 true resid
norm 1.017496416000e+03 ||Ae||/||Ax|| 1.017496416000e+03
       1 KSP preconditioned resid norm 1.741881317500e-01 true resid
norm 2.697856264290e+02 ||Ae||/||Ax|| 2.697856264290e+02
         0 KSP preconditioned resid norm 1.855265388514e+03 true resid
norm 4.457571496212e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 5.522733286227e-10 true resid
norm 6.897121799185e-10 ||Ae||/||Ax|| 1.547282372262e-12
       0 KSP preconditioned resid norm 3.139459156768e+03 true resid
norm 6.178203349663e+06 ||Ae||/||Ax|| 6.178203349663e+06
     1 KSP preconditioned resid norm 1.307366779482e+00 true resid norm
1.307366779482e+00 ||Ae||/||Ax|| 9.989825707873e-01
         0 KSP preconditioned resid norm 9.126107408200e+00 true resid
norm 1.381216040059e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.550817052315e-12 true resid
norm 3.042123300613e-12 ||Ae||/||Ax|| 2.202496360008e-12
       0 KSP preconditioned resid norm 1.542594768751e+01 true resid
norm 3.049460348051e+04 ||Ae||/||Ax|| 3.049460348051e+04
         0 KSP preconditioned resid norm 2.793298665113e+05 true resid
norm 4.194826255177e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 8.370808612517e-08 true resid
norm 9.579338218581e-08 ||Ae||/||Ax|| 2.283607862604e-12
       0 KSP preconditioned resid norm 4.724281628181e+05 true resid
norm 9.357252729253e+08 ||Ae||/||Ax|| 9.357252729253e+08
     2 KSP preconditioned resid norm 1.286291199119e+00 true resid norm
1.286291199119e+00 ||Ae||/||Ax|| 9.828783391491e-01
         0 KSP preconditioned resid norm 4.853086257912e+00 true resid
norm 1.762407227405e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.188660535877e-12 true resid
norm 1.095897917516e-12 ||Ae||/||Ax|| 6.218187831250e-13
       0 KSP preconditioned resid norm 7.354250474791e+00 true resid
norm 5.806918120227e+03 ||Ae||/||Ax|| 5.806918120227e+03
         0 KSP preconditioned resid norm 9.507342745042e+04 true resid
norm 9.101379563722e+03 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.507856901997e-08 true resid
norm 1.203978211327e-08 ||Ae||/||Ax|| 1.322852434510e-12
       0 KSP preconditioned resid norm 1.424177612658e+05 true resid
norm 1.080775490793e+08 ||Ae||/||Ax|| 1.080775490793e+08
     3 KSP preconditioned resid norm 1.281076066870e+00 true resid norm
1.281076066870e+00 ||Ae||/||Ax|| 9.788933623990e-01
         0 KSP preconditioned resid norm 1.031612292550e+02 true resid
norm 1.605474040138e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.422227657515e-11 true resid
norm 1.826368840914e-12 ||Ae||/||Ax|| 1.137588522302e-12
       0 KSP preconditioned resid norm 1.516245422282e+02 true resid
norm 1.511985350228e+04 ||Ae||/||Ax|| 1.511985350228e+04
         0 KSP preconditioned resid norm 1.998524571466e+06 true resid
norm 2.114287680254e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 4.919571300159e-07 true resid
norm 3.379476213156e-08 ||Ae||/||Ax|| 1.598399425356e-12
       0 KSP preconditioned resid norm 2.937372721762e+06 true resid
norm 2.886115000780e+08 ||Ae||/||Ax|| 2.886115000780e+08
     4 KSP preconditioned resid norm 1.274608512034e+00 true resid norm
1.274608512034e+00 ||Ae||/||Ax|| 9.739513869267e-01
         0 KSP preconditioned resid norm 8.584999416955e+01 true resid
norm 1.676010194851e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.121159984852e-11 true resid
norm 1.647263991685e-12 ||Ae||/||Ax|| 9.828484317967e-13
       0 KSP preconditioned resid norm 1.261867401997e+02 true resid
norm 1.282997762347e+04 ||Ae||/||Ax|| 1.282997762347e+04
         0 KSP preconditioned resid norm 1.663127865840e+06 true resid
norm 1.809949324252e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.715693256069e-07 true resid
norm 2.797939280490e-08 ||Ae||/||Ax|| 1.545866087520e-12
       0 KSP preconditioned resid norm 2.444432338934e+06 true resid
norm 2.407335970627e+08 ||Ae||/||Ax|| 2.407335970627e+08
     5 KSP preconditioned resid norm 1.269640505517e+00 true resid norm
1.269640505517e+00 ||Ae||/||Ax|| 9.701552434119e-01
         0 KSP preconditioned resid norm 8.500173536946e+00 true resid
norm 1.474437012468e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.731992835726e-12 true resid
norm 3.130508679725e-12 ||Ae||/||Ax|| 2.123189158474e-12
       0 KSP preconditioned resid norm 1.445317443628e+01 true resid
norm 2.836860714321e+04 ||Ae||/||Ax|| 2.836860714321e+04
         0 KSP preconditioned resid norm 2.598079909146e+05 true resid
norm 3.904701021330e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 7.712159042515e-08 true resid
norm 9.430555275347e-08 ||Ae||/||Ax|| 2.415179862384e-12
       0 KSP preconditioned resid norm 4.422339903409e+05 true resid
norm 8.699841646170e+08 ||Ae||/||Ax|| 8.699841646170e+08
     6 KSP preconditioned resid norm 1.240293731529e+00 true resid norm
1.240293731529e+00 ||Ae||/||Ax|| 9.477308433251e-01
         0 KSP preconditioned resid norm 3.817329358402e+00 true resid
norm 1.878328844937e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.336488310399e-12 true resid
norm 1.968321178329e-12 ||Ae||/||Ax|| 1.047910850986e-12
       0 KSP preconditioned resid norm 6.496038663865e+00 true resid
norm 1.203945386556e+04 ||Ae||/||Ax|| 1.203945386556e+04
         0 KSP preconditioned resid norm 1.101956935839e+05 true resid
norm 1.690737730774e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.505687476217e-08 true resid
norm 3.868649531567e-08 ||Ae||/||Ax|| 2.288142898306e-12
       0 KSP preconditioned resid norm 1.866393633809e+05 true resid
norm 3.607809698759e+08 ||Ae||/||Ax|| 3.607809698759e+08
     7 KSP preconditioned resid norm 1.192185750133e+00 true resid norm
1.192185750133e+00 ||Ae||/||Ax|| 9.109706657799e-01
         0 KSP preconditioned resid norm 1.103198681366e+00 true resid
norm 2.016429497095e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.260860606235e-13 true resid
norm 1.871444107996e-13 ||Ae||/||Ax|| 9.280979626076e-14
       0 KSP preconditioned resid norm 1.997708017818e+00 true resid
norm 2.122037753565e+03 ||Ae||/||Ax|| 2.122037753565e+03
       1 KSP preconditioned resid norm 4.618193595607e-01 true resid
norm 2.540609128927e+02 ||Ae||/||Ax|| 2.540609128927e+02
         0 KSP preconditioned resid norm 5.299709888224e+02 true resid
norm 4.801745769741e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.017584542111e-10 true resid
norm 5.940522720915e-11 ||Ae||/||Ax|| 1.237158942973e-13
       0 KSP preconditioned resid norm 9.416500710791e+02 true resid
norm 8.177676944591e+05 ||Ae||/||Ax|| 8.177676944591e+05
     8 KSP preconditioned resid norm 1.187310607316e+00 true resid norm
1.187310607316e+00 ||Ae||/||Ax|| 9.072454810953e-01
         0 KSP preconditioned resid norm 1.191721427949e+01 true resid
norm 1.804358617749e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.618507637154e-12 true resid
norm 2.010483783173e-12 ||Ae||/||Ax|| 1.114237360243e-12
       0 KSP preconditioned resid norm 1.957620812169e+01 true resid
norm 1.741562232256e+04 ||Ae||/||Ax|| 1.741562232256e+04
       1 KSP preconditioned resid norm 3.235571300995e+00 true resid
norm 1.560872557301e+03 ||Ae||/||Ax|| 1.560872557301e+03
         0 KSP preconditioned resid norm 2.146086637228e+04 true resid
norm 2.116725369143e+03 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 5.012680009150e-09 true resid
norm 4.641272711834e-09 ||Ae||/||Ax|| 2.192666455221e-12
       0 KSP preconditioned resid norm 3.553939957626e+04 true resid
norm 4.552924260777e+07 ||Ae||/||Ax|| 4.552924260777e+07
     9 KSP preconditioned resid norm 1.184881170018e+00 true resid norm
1.184881170018e+00 ||Ae||/||Ax|| 9.053891041734e-01
         0 KSP preconditioned resid norm 9.013294569631e+00 true resid
norm 1.590917299780e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.522672180871e-12 true resid
norm 2.646584400435e-12 ||Ae||/||Ax|| 1.663558753683e-12
       0 KSP preconditioned resid norm 1.609904368624e+01 true resid
norm 2.548311040691e+04 ||Ae||/||Ax|| 2.548311040691e+04
       1 KSP preconditioned resid norm 3.138102119429e+00 true resid
norm 3.221616601602e+03 ||Ae||/||Ax|| 3.221616601602e+03
         0 KSP preconditioned resid norm 2.966723868503e+04 true resid
norm 4.385489957291e+03 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 9.554991804882e-09 true resid
norm 9.729410050451e-09 ||Ae||/||Ax|| 2.218545737239e-12
       0 KSP preconditioned resid norm 5.467848851613e+04 true resid
norm 9.720762904183e+07 ||Ae||/||Ax|| 9.720762904183e+07
    10 KSP preconditioned resid norm 1.183250603772e+00 true resid norm
1.183250603772e+00 ||Ae||/||Ax|| 9.041431590527e-01
         0 KSP preconditioned resid norm 1.139917359003e+02 true resid
norm 1.461985081857e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.936778552378e-11 true resid
norm 2.155858862569e-12 ||Ae||/||Ax|| 1.474610712053e-12
       0 KSP preconditioned resid norm 1.699009818121e+02 true resid
norm 1.966564654661e+04 ||Ae||/||Ax|| 1.966564654661e+04
         0 KSP preconditioned resid norm 2.209481632608e+06 true resid
norm 2.722888057718e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.439021080164e-07 true resid
norm 5.024351882292e-08 ||Ae||/||Ax|| 1.845228953886e-12
       0 KSP preconditioned resid norm 3.293067141092e+06 true resid
norm 4.566021924053e+08 ||Ae||/||Ax|| 4.566021924053e+08
    11 KSP preconditioned resid norm 1.179842952379e+00 true resid norm
1.179842952379e+00 ||Ae||/||Ax|| 9.015393110718e-01
         0 KSP preconditioned resid norm 9.312336333634e+00 true resid
norm 1.536038920080e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.543499555963e-12 true resid
norm 2.831415628740e-12 ||Ae||/||Ax|| 1.843322842752e-12
       0 KSP preconditioned resid norm 1.627124439842e+01 true resid
norm 2.454100587432e+04 ||Ae||/||Ax|| 2.454100587432e+04
         0 KSP preconditioned resid norm 2.438191586954e+05 true resid
norm 3.383001147319e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 7.198980589988e-08 true resid
norm 8.440942648826e-08 ||Ae||/||Ax|| 2.495104873232e-12
       0 KSP preconditioned resid norm 4.383111884338e+05 true resid
norm 7.484515504412e+08 ||Ae||/||Ax|| 7.484515504412e+08
    12 KSP preconditioned resid norm 1.175376162628e+00 true resid norm
1.175376162628e+00 ||Ae||/||Ax|| 8.981261563404e-01
         0 KSP preconditioned resid norm 7.051008824068e+01 true resid
norm 1.585083538737e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.165012706118e-11 true resid
norm 2.206772755388e-12 ||Ae||/||Ax|| 1.392212272387e-12
       0 KSP preconditioned resid norm 1.050376935802e+02 true resid
norm 1.866739366731e+04 ||Ae||/||Ax|| 1.866739366731e+04
         0 KSP preconditioned resid norm 1.368703621692e+06 true resid
norm 2.585360901893e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.169639697438e-07 true resid
norm 5.809353183331e-08 ||Ae||/||Ax|| 2.247018270864e-12
       0 KSP preconditioned resid norm 2.043969827711e+06 true resid
norm 5.113529582468e+08 ||Ae||/||Ax|| 5.113529582468e+08
    13 KSP preconditioned resid norm 1.163992595272e+00 true resid norm
1.163992595272e+00 ||Ae||/||Ax|| 8.894277669060e-01
         0 KSP preconditioned resid norm 8.515303915212e+00 true resid
norm 1.904882460913e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.570331341241e-12 true resid
norm 3.322159253556e-13 ||Ae||/||Ax|| 1.744023225435e-13
       0 KSP preconditioned resid norm 1.443576158217e+01 true resid
norm 3.491626175321e+03 ||Ae||/||Ax|| 3.491626175321e+03
       1 KSP preconditioned resid norm 2.144436548969e+00 true resid
norm 2.584436198878e+02 ||Ae||/||Ax|| 2.584436198878e+02
         0 KSP preconditioned resid norm 6.082095393362e+03 true resid
norm 3.982679317553e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.609299091694e-09 true resid
norm 2.053609341656e-10 ||Ae||/||Ax|| 5.156351234720e-13
       0 KSP preconditioned resid norm 9.468237802274e+03 true resid
norm 1.500791057830e+06 ||Ae||/||Ax|| 1.500791057830e+06
    14 KSP preconditioned resid norm 1.161954853862e+00 true resid norm
1.161954853862e+00 ||Ae||/||Ax|| 8.878706918874e-01
         0 KSP preconditioned resid norm 7.268493138378e+01 true resid
norm 1.658381589506e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.236800083833e-11 true resid
norm 1.609673637112e-12 ||Ae||/||Ax|| 9.706292250817e-13
       0 KSP preconditioned resid norm 1.090962150823e+02 true resid
norm 1.422422881859e+04 ||Ae||/||Ax|| 1.422422881859e+04
         0 KSP preconditioned resid norm 1.392543317987e+06 true resid
norm 1.985413188675e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.159467768755e-07 true resid
norm 3.770676244274e-08 ||Ae||/||Ax|| 1.899189682924e-12
       0 KSP preconditioned resid norm 2.078324384653e+06 true resid
norm 3.490817405338e+08 ||Ae||/||Ax|| 3.490817405338e+08
    15 KSP preconditioned resid norm 1.161122807373e+00 true resid norm
1.161122807373e+00 ||Ae||/||Ax|| 8.872349101363e-01
         0 KSP preconditioned resid norm 4.486384106202e+01 true resid
norm 1.505866250635e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 7.107455382253e-12 true resid
norm 2.713186111845e-12 ||Ae||/||Ax|| 1.801744418337e-12
       0 KSP preconditioned resid norm 6.731100076983e+01 true resid
norm 2.507166440335e+04 ||Ae||/||Ax|| 2.507166440335e+04
         0 KSP preconditioned resid norm 8.735838913666e+05 true resid
norm 3.455516905875e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.763472347693e-07 true resid
norm 8.184396405326e-08 ||Ae||/||Ax|| 2.368501335187e-12
       0 KSP preconditioned resid norm 1.318309422898e+06 true resid
norm 7.524118563334e+08 ||Ae||/||Ax|| 7.524118563334e+08
    16 KSP preconditioned resid norm 1.160759375595e+00 true resid norm
1.160759375595e+00 ||Ae||/||Ax|| 8.869572053499e-01
         0 KSP preconditioned resid norm 1.049374964108e+02 true resid
norm 1.434877879459e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.462232523302e-11 true resid
norm 2.449064800648e-12 ||Ae||/||Ax|| 1.706810618317e-12
       0 KSP preconditioned resid norm 1.563689176972e+02 true resid
norm 2.234748831325e+04 ||Ae||/||Ax|| 2.234748831325e+04
         0 KSP preconditioned resid norm 2.034170341786e+06 true resid
norm 3.086532544601e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.973509809548e-07 true resid
norm 6.238722918085e-08 ||Ae||/||Ax|| 2.021272359171e-12
       0 KSP preconditioned resid norm 3.034308733052e+06 true resid
norm 5.829656771747e+08 ||Ae||/||Ax|| 5.829656771747e+08
    17 KSP preconditioned resid norm 1.159720744650e+00 true resid norm
1.159720744650e+00 ||Ae||/||Ax|| 8.861635686847e-01
         0 KSP preconditioned resid norm 6.945410558826e+00 true resid
norm 1.698126116149e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.046608765850e-12 true resid
norm 5.634458822597e-13 ||Ae||/||Ax|| 3.318044972639e-13
       0 KSP preconditioned resid norm 1.177325940074e+01 true resid
norm 5.082427013645e+03 ||Ae||/||Ax|| 5.082427013645e+03
       1 KSP preconditioned resid norm 2.205234596357e+00 true resid
norm 4.860264071810e+02 ||Ae||/||Ax|| 4.860264071810e+02
         0 KSP preconditioned resid norm 1.073978588334e+04 true resid
norm 7.396119503065e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.790941343669e-09 true resid
norm 3.888806692558e-10 ||Ae||/||Ax|| 5.257901377806e-13
Otherwise:
   0 SNES Function norm 6.643976542462e-01
     0 KSP preconditioned resid norm 6.643976542462e-01 true resid norm
6.643976542462e-01 ||Ae||/||Ax|| 1.000000000000e+00
         0 KSP preconditioned resid norm 2.725399523210e-01 true resid
norm 3.166954099258e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.106117940771e-13 true resid
norm 2.315021615293e-12 ||Ae||/||Ax|| 7.309931065420e-13
       0 KSP preconditioned resid norm 4.929790573526e-01 true resid
norm 9.951144782040e+02 ||Ae||/||Ax|| 9.951144782040e+02
       1 KSP preconditioned resid norm 1.564900133045e-01 true resid
norm 2.114279379086e+02 ||Ae||/||Ax|| 2.114279379086e+02
         0 KSP preconditioned resid norm 1.643532578826e+03 true resid
norm 3.242219706609e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 5.414885267904e-10 true resid
norm 6.046106295275e-10 ||Ae||/||Ax|| 1.864804622262e-12
       0 KSP preconditioned resid norm 2.943982335376e+03 true resid
norm 5.509225819313e+06 ||Ae||/||Ax|| 5.509225819313e+06
     1 KSP preconditioned resid norm 6.638944563800e-01 true resid norm
6.638944563800e-01 ||Ae||/||Ax|| 9.992426254623e-01
         0 KSP preconditioned resid norm 9.123125465961e+00 true resid
norm 1.382122000671e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.695428248071e-12 true resid
norm 3.359968818024e-12 ||Ae||/||Ax|| 2.431021875342e-12
       0 KSP preconditioned resid norm 1.640642499067e+01 true resid
norm 3.058206355968e+04 ||Ae||/||Ax|| 3.058206355968e+04
         0 KSP preconditioned resid norm 2.797910566205e+05 true resid
norm 4.206726908841e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 8.740791701929e-08 true resid
norm 1.010734630198e-07 ||Ae||/||Ax|| 2.402662811492e-12
       0 KSP preconditioned resid norm 5.035724534228e+05 true resid
norm 9.384726253260e+08 ||Ae||/||Ax|| 9.384726253260e+08
     2 KSP preconditioned resid norm 6.578097894415e-01 true resid norm
6.578097894415e-01 ||Ae||/||Ax|| 9.900844550510e-01
         0 KSP preconditioned resid norm 3.479843101860e+00 true resid
norm 1.765526142479e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 6.880414574516e-13 true resid
norm 5.729119550389e-13 ||Ae||/||Ax|| 3.244992760257e-13
       0 KSP preconditioned resid norm 5.427680497553e+00 true resid
norm 5.361948161829e+03 ||Ae||/||Ax|| 5.361948161829e+03
       1 KSP preconditioned resid norm 1.300714694506e+00 true resid
norm 6.605629913301e+02 ||Ae||/||Ax|| 6.605629913301e+02
         0 KSP preconditioned resid norm 8.505888265686e+03 true resid
norm 1.023439478635e+03 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.876815951467e-09 true resid
norm 1.061881454058e-09 ||Ae||/||Ax|| 1.037561552222e-12
       0 KSP preconditioned resid norm 1.290609974182e+04 true resid
norm 9.664058465504e+06 ||Ae||/||Ax|| 9.664058465504e+06
     3 KSP preconditioned resid norm 6.561200836326e-01 true resid norm
6.561200836327e-01 ||Ae||/||Ax|| 9.875412404594e-01
         0 KSP preconditioned resid norm 9.170586094295e+01 true resid
norm 1.631125873731e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.103282620964e-11 true resid
norm 1.497493808500e-12 ||Ae||/||Ax|| 9.180737260177e-13
       0 KSP preconditioned resid norm 1.347370724401e+02 true resid
norm 1.463309001406e+04 ||Ae||/||Ax|| 1.463309001406e+04
         0 KSP preconditioned resid norm 1.777008569360e+06 true resid
norm 2.049123792919e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.273597544885e-07 true resid
norm 3.156333476700e-08 ||Ae||/||Ax|| 1.540333232969e-12
       0 KSP preconditioned resid norm 2.610973345558e+06 true resid
norm 3.067242396541e+08 ||Ae||/||Ax|| 3.067242396541e+08
     4 KSP preconditioned resid norm 6.548326787335e-01 true resid norm
6.548326787335e-01 ||Ae||/||Ax|| 9.856035381047e-01
         0 KSP preconditioned resid norm 6.744279341020e+01 true resid
norm 1.575413893640e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 9.596044804676e-12 true resid
norm 2.188670572403e-12 ||Ae||/||Ax|| 1.389267024519e-12
       0 KSP preconditioned resid norm 9.923158845467e+01 true resid
norm 2.077302460532e+04 ||Ae||/||Ax|| 2.077302460532e+04
         0 KSP preconditioned resid norm 1.312863536630e+06 true resid
norm 2.875558120734e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.220066071362e-07 true resid
norm 6.253679189569e-08 ||Ae||/||Ax|| 2.174770575659e-12
       0 KSP preconditioned resid norm 1.935695568057e+06 true resid
norm 5.883388937994e+08 ||Ae||/||Ax|| 5.883388937994e+08
     5 KSP preconditioned resid norm 6.544976830743e-01 true resid norm
6.544976830743e-01 ||Ae||/||Ax|| 9.850993285291e-01
         0 KSP preconditioned resid norm 7.174448897397e+01 true resid
norm 1.430312312462e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.020678358228e-11 true resid
norm 2.744384895131e-12 ||Ae||/||Ax|| 1.918731224796e-12
       0 KSP preconditioned resid norm 1.056248445749e+02 true resid
norm 2.626622745496e+04 ||Ae||/||Ax|| 2.626622745496e+04
         0 KSP preconditioned resid norm 1.400394797757e+06 true resid
norm 3.619726511862e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.193605648209e-07 true resid
norm 8.494919484928e-08 ||Ae||/||Ax|| 2.346840143058e-12
       0 KSP preconditioned resid norm 2.068710085645e+06 true resid
norm 7.667828660174e+08 ||Ae||/||Ax|| 7.667828660174e+08
     6 KSP preconditioned resid norm 6.439039598676e-01 true resid norm
6.439039598676e-01 ||Ae||/||Ax|| 9.691544751135e-01
         0 KSP preconditioned resid norm 2.179140600580e+00 true resid
norm 1.989332702312e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.326937782582e-13 true resid
norm 4.947256796457e-13 ||Ae||/||Ax|| 2.486892610123e-13
       0 KSP preconditioned resid norm 3.444435655294e+00 true resid
norm 3.156694238579e+03 ||Ae||/||Ax|| 3.156694238579e+03
       1 KSP preconditioned resid norm 6.515773480483e-01 true resid
norm 2.901000501958e+02 ||Ae||/||Ax|| 2.901000501958e+02
         0 KSP preconditioned resid norm 3.915459779122e+03 true resid
norm 5.038345879332e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 5.039414912287e-10 true resid
norm 1.678723587391e-10 ||Ae||/||Ax|| 3.331894291493e-13
       0 KSP preconditioned resid norm 5.807751000664e+03 true resid
norm 1.539570200699e+06 ||Ae||/||Ax|| 1.539570200699e+06
     7 KSP preconditioned resid norm 6.363395202453e-01 true resid norm
6.363395202453e-01 ||Ae||/||Ax|| 9.577690652253e-01
         0 KSP preconditioned resid norm 1.052630074523e+01 true resid
norm 1.781752945860e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.199838493352e-12 true resid
norm 7.304943596974e-13 ||Ae||/||Ax|| 4.099863347469e-13
       0 KSP preconditioned resid norm 1.564794701194e+01 true resid
norm 6.589276558755e+03 ||Ae||/||Ax|| 6.589276558755e+03
         0 KSP preconditioned resid norm 2.055277044182e+05 true resid
norm 9.748412831200e+03 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 5.031500847154e-08 true resid
norm 1.699803899076e-08 ||Ae||/||Ax|| 1.743672460850e-12
       0 KSP preconditioned resid norm 3.055340634218e+05 true resid
norm 1.467054190881e+08 ||Ae||/||Ax|| 1.467054190881e+08
     8 KSP preconditioned resid norm 6.359350697478e-01 true resid norm
6.359350697478e-01 ||Ae||/||Ax|| 9.571603175951e-01
         0 KSP preconditioned resid norm 2.616392072429e+01 true resid
norm 1.399164584086e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 8.560221274332e-12 true resid
norm 3.396335397864e-12 ||Ae||/||Ax|| 2.427402348868e-12
       0 KSP preconditioned resid norm 3.941467939860e+01 true resid
norm 2.988458651670e+04 ||Ae||/||Ax|| 2.988458651670e+04
         0 KSP preconditioned resid norm 5.488120293113e+05 true resid
norm 4.111465519054e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.293564612577e-07 true resid
norm 9.984868100046e-08 ||Ae||/||Ax|| 2.428542341842e-12
       0 KSP preconditioned resid norm 8.476371588574e+05 true resid
norm 9.130561850506e+08 ||Ae||/||Ax|| 9.130561850506e+08
     9 KSP preconditioned resid norm 6.335496131622e-01 true resid norm
6.335496131621e-01 ||Ae||/||Ax|| 9.535699127067e-01
         0 KSP preconditioned resid norm 1.106152616615e+02 true resid
norm 1.583060778556e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.805535309513e-11 true resid
norm 1.673866852654e-12 ||Ae||/||Ax|| 1.057361078822e-12
       0 KSP preconditioned resid norm 1.629014513164e+02 true resid
norm 1.721563662560e+04 ||Ae||/||Ax|| 1.721563662560e+04
         0 KSP preconditioned resid norm 2.143400094103e+06 true resid
norm 2.391592584678e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.655288006358e-07 true resid
norm 3.651187137683e-08 ||Ae||/||Ax|| 1.526676057233e-12
       0 KSP preconditioned resid norm 3.157145952315e+06 true resid
norm 3.635185867036e+08 ||Ae||/||Ax|| 3.635185867036e+08
    10 KSP preconditioned resid norm 6.286299560309e-01 true resid norm
6.286299560308e-01 ||Ae||/||Ax|| 9.461652250172e-01
         0 KSP preconditioned resid norm 7.134714110556e+01 true resid
norm 1.817675317602e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.367511627937e-11 true resid
norm 1.069313196151e-12 ||Ae||/||Ax|| 5.882861398820e-13
       0 KSP preconditioned resid norm 1.051163731361e+02 true resid
norm 1.080698356605e+04 ||Ae||/||Ax|| 1.080698356605e+04
         0 KSP preconditioned resid norm 1.382173007807e+06 true resid
norm 1.533268566333e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.409130608602e-07 true resid
norm 1.986640520809e-08 ||Ae||/||Ax|| 1.295689851362e-12
       0 KSP preconditioned resid norm 2.035749163308e+06 true resid
norm 2.035717866610e+08 ||Ae||/||Ax|| 2.035717866610e+08
    11 KSP preconditioned resid norm 6.240432713585e-01 true resid norm
6.240432713583e-01 ||Ae||/||Ax|| 9.392617017383e-01
         0 KSP preconditioned resid norm 3.844303874505e+00 true resid
norm 2.025754466097e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 7.084772487291e-13 true resid
norm 2.498173588423e-13 ||Ae||/||Ax|| 1.233206506629e-13
       0 KSP preconditioned resid norm 6.693139988729e+00 true resid
norm 3.219334957995e+03 ||Ae||/||Ax|| 3.219334957995e+03
       1 KSP preconditioned resid norm 9.050137472631e-01 true resid
norm 1.774360140771e+02 ||Ae||/||Ax|| 1.774360140771e+02
         0 KSP preconditioned resid norm 9.159860571453e+02 true resid
norm 2.849079799533e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.715724723628e-10 true resid
norm 6.479512209525e-11 ||Ae||/||Ax|| 2.274247358950e-13
       0 KSP preconditioned resid norm 1.534505089525e+03 true resid
norm 7.119178925600e+05 ||Ae||/||Ax|| 7.119178925600e+05
    12 KSP preconditioned resid norm 6.215082061046e-01 true resid norm
6.215082061043e-01 ||Ae||/||Ax|| 9.354461174452e-01
         0 KSP preconditioned resid norm 9.582212676361e+00 true resid
norm 1.600198293761e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 4.199386304534e-12 true resid
norm 2.546378223943e-12 ||Ae||/||Ax|| 1.591289175767e-12
       0 KSP preconditioned resid norm 1.605976238605e+01 true resid
norm 2.420119403833e+04 ||Ae||/||Ax|| 2.420119403833e+04
         0 KSP preconditioned resid norm 2.470980401312e+05 true resid
norm 3.335769643727e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 9.641301617231e-08 true resid
norm 7.742484597259e-08 ||Ae||/||Ax|| 2.321048940480e-12
       0 KSP preconditioned resid norm 4.265452000486e+05 true resid
norm 7.382063118236e+08 ||Ae||/||Ax|| 7.382063118236e+08
    13 KSP preconditioned resid norm 6.174461224321e-01 true resid norm
6.174461224316e-01 ||Ae||/||Ax|| 9.293321830465e-01
         0 KSP preconditioned resid norm 7.162749884317e+00 true resid
norm 1.724169083549e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.245030787092e-12 true resid
norm 2.158165526832e-12 ||Ae||/||Ax|| 1.251713389032e-12
       0 KSP preconditioned resid norm 1.261531472323e+01 true resid
norm 1.934063218915e+04 ||Ae||/||Ax|| 1.934063218915e+04
       1 KSP preconditioned resid norm 3.138349049840e+00 true resid
norm 3.196943394208e+03 ||Ae||/||Ax|| 3.196943394208e+03
         0 KSP preconditioned resid norm 3.009138537539e+04 true resid
norm 4.382853471310e+03 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.158503853275e-08 true resid
norm 1.004172948430e-08 ||Ae||/||Ax|| 2.291139676477e-12
       0 KSP preconditioned resid norm 5.318204723101e+04 true resid
norm 9.571798797533e+07 ||Ae||/||Ax|| 9.571798797533e+07
    14 KSP preconditioned resid norm 6.149499196279e-01 true resid norm
6.149499196273e-01 ||Ae||/||Ax|| 9.255750915091e-01
         0 KSP preconditioned resid norm 1.035088573396e+02 true resid
norm 1.643475237600e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.216424963006e-11 true resid
norm 1.506827148268e-12 ||Ae||/||Ax|| 9.168541842274e-13
       0 KSP preconditioned resid norm 1.551868703751e+02 true resid
norm 1.536835258272e+04 ||Ae||/||Ax|| 1.536835258272e+04
         0 KSP preconditioned resid norm 2.005122433856e+06 true resid
norm 2.139846293667e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.699635663738e-07 true resid
norm 3.022165390047e-08 ||Ae||/||Ax|| 1.412328258806e-12
       0 KSP preconditioned resid norm 3.006635999374e+06 true resid
norm 3.017362591687e+08 ||Ae||/||Ax|| 3.017362591687e+08
    15 KSP preconditioned resid norm 6.119892528016e-01 true resid norm
6.119892528010e-01 ||Ae||/||Ax|| 9.211189246225e-01
         0 KSP preconditioned resid norm 7.708088998606e+01 true resid
norm 1.711478746266e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.060008672565e-11 true resid
norm 1.607068827031e-12 ||Ae||/||Ax|| 9.389943232059e-13
       0 KSP preconditioned resid norm 1.156508047473e+02 true resid
norm 1.535553658162e+04 ||Ae||/||Ax|| 1.535553658162e+04
         0 KSP preconditioned resid norm 1.494713077437e+06 true resid
norm 2.137562818275e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.212752436065e-07 true resid
norm 3.856329184915e-08 ||Ae||/||Ax|| 1.804077593390e-12
       0 KSP preconditioned resid norm 2.242894821533e+06 true resid
norm 3.794045949252e+08 ||Ae||/||Ax|| 3.794045949252e+08
    16 KSP preconditioned resid norm 6.117490632701e-01 true resid norm
6.117490632695e-01 ||Ae||/||Ax|| 9.207574099032e-01
         0 KSP preconditioned resid norm 3.772808947649e+01 true resid
norm 1.405980393316e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 6.476258783730e-12 true resid
norm 2.941069111800e-12 ||Ae||/||Ax|| 2.091827969851e-12
       0 KSP preconditioned resid norm 5.708326125111e+01 true resid
norm 2.931735332166e+04 ||Ae||/||Ax|| 2.931735332166e+04
         0 KSP preconditioned resid norm 7.589513697668e+05 true resid
norm 4.034303627079e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.910686949086e-07 true resid
norm 9.440768132030e-08 ||Ae||/||Ax|| 2.340123353300e-12
       0 KSP preconditioned resid norm 1.161530456729e+06 true resid
norm 8.904990807332e+08 ||Ae||/||Ax|| 8.904990807332e+08
    17 KSP preconditioned resid norm 6.105492772342e-01 true resid norm
6.105492772335e-01 ||Ae||/||Ax|| 9.189515846894e-01
         0 KSP preconditioned resid norm 1.151371970652e+01 true resid
norm 1.840366588465e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.665910011647e-12 true resid
norm 3.270852369182e-13 ||Ae||/||Ax|| 1.777283063974e-13
       0 KSP preconditioned resid norm 1.982093669992e+01 true resid
norm 4.092310687071e+03 ||Ae||/||Ax|| 4.092310687071e+03
       1 KSP preconditioned resid norm 2.901141640394e+00 true resid
norm 3.049777392969e+02 ||Ae||/||Ax|| 3.049777392969e+02
         0 KSP preconditioned resid norm 5.458502977349e+03 true resid
norm 4.752917147299e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 8.762473639268e-10 true resid
norm 1.958600237389e-10 ||Ae||/||Ax|| 4.120838164626e-13
       0 KSP preconditioned resid norm 8.830916923215e+03 true resid
norm 1.946797262204e+06 ||Ae||/||Ax|| 1.946797262204e+06
    18 KSP preconditioned resid norm 6.100978815994e-01 true resid norm
6.100978815987e-01 ||Ae||/||Ax|| 9.182721788669e-01
         0 KSP preconditioned resid norm 1.293152526116e+01 true resid
norm 1.770047949512e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.309788070646e-12 true resid
norm 1.025001129138e-12 ||Ae||/||Ax|| 5.790809957554e-13
       0 KSP preconditioned resid norm 1.985392961918e+01 true resid
norm 8.566236604412e+03 ||Ae||/||Ax|| 8.566236604412e+03
       1 KSP preconditioned resid norm 2.789899652666e+00 true resid
norm 5.636415083587e+02 ||Ae||/||Ax|| 5.636415083587e+02
         0 KSP preconditioned resid norm 1.733288768604e+04 true resid
norm 7.546515122842e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 4.025556233669e-09 true resid
norm 1.580051674878e-09 ||Ae||/||Ax|| 2.093750094127e-12
       0 KSP preconditioned resid norm 2.630250151670e+04 true resid
norm 1.330699007354e+07 ||Ae||/||Ax|| 1.330699007354e+07
    19 KSP preconditioned resid norm 6.100476482561e-01 true resid norm
6.100476482555e-01 ||Ae||/||Ax|| 9.181965715210e-01
         0 KSP preconditioned resid norm 2.339579819469e+01 true resid
norm 1.408053443111e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 7.059179601313e-12 true resid
norm 3.493662559442e-12 ||Ae||/||Ax|| 2.481200253111e-12
       0 KSP preconditioned resid norm 3.611630692345e+01 true resid
norm 2.951947847829e+04 ||Ae||/||Ax|| 2.951947847829e+04
         0 KSP preconditioned resid norm 4.983690252370e+05 true resid
norm 4.062078711009e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.933795534368e-07 true resid
norm 1.083017498942e-07 ||Ae||/||Ax|| 2.666165714629e-12
       0 KSP preconditioned resid norm 7.927031893526e+05 true resid
norm 9.022735540634e+08 ||Ae||/||Ax|| 9.022735540634e+08
    20 KSP preconditioned resid norm 6.099044961083e-01 true resid norm
6.099044961077e-01 ||Ae||/||Ax|| 9.179811099720e-01
         0 KSP preconditioned resid norm 1.251927093876e+02 true resid
norm 1.442674197968e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.456260036321e-11 true resid
norm 1.988746674151e-12 ||Ae||/||Ax|| 1.378514065721e-12
       0 KSP preconditioned resid norm 1.873393344533e+02 true resid
norm 1.892014590772e+04 ||Ae||/||Ax|| 1.892014590772e+04
         0 KSP preconditioned resid norm 2.424466095987e+06 true resid
norm 2.622281316135e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.415684007216e-07 true resid
norm 3.908490203452e-08 ||Ae||/||Ax|| 1.490492335587e-12
       0 KSP preconditioned resid norm 3.626351939650e+06 true resid
norm 3.890678942290e+08 ||Ae||/||Ax|| 3.890678942290e+08
    21 KSP preconditioned resid norm 6.087261901598e-01 true resid norm
6.087261901594e-01 ||Ae||/||Ax|| 9.162076149261e-01
         0 KSP preconditioned resid norm 4.361818580845e+01 true resid
norm 1.808235581815e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 6.784202597730e-12 true resid
norm 7.762183967973e-13 ||Ae||/||Ax|| 4.292684009781e-13
       0 KSP preconditioned resid norm 6.583953430980e+01 true resid
norm 7.133930076680e+03 ||Ae||/||Ax|| 7.133930076680e+03
       1 KSP preconditioned resid norm 7.286222194976e+00 true resid
norm 4.292142002963e+02 ||Ae||/||Ax|| 4.292142002963e+02
         0 KSP preconditioned resid norm 4.338403929132e+04 true resid
norm 5.595290563559e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 5.453364725694e-09 true resid
norm 6.267303520695e-10 ||Ae||/||Ax|| 1.120103317156e-12
       0 KSP preconditioned resid norm 6.512792957865e+04 true resid
norm 6.434436103270e+06 ||Ae||/||Ax|| 6.434436103270e+06
    22 KSP preconditioned resid norm 6.077687858338e-01 true resid norm
6.077687858336e-01 ||Ae||/||Ax|| 9.147666039296e-01
         0 KSP preconditioned resid norm 3.342477813280e+01 true resid
norm 1.697753978801e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 5.150944066234e-12 true resid
norm 2.293439355587e-12 ||Ae||/||Ax|| 1.350866724051e-12
       0 KSP preconditioned resid norm 5.032915530318e+01 true resid
norm 2.116838708059e+04 ||Ae||/||Ax|| 2.116838708059e+04
         0 KSP preconditioned resid norm 6.525917140824e+05 true resid
norm 2.922908744358e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.104328032200e-07 true resid
norm 6.770091806491e-08 ||Ae||/||Ax|| 2.316217302219e-12
       0 KSP preconditioned resid norm 9.810237265904e+05 true resid
norm 6.357251340383e+08 ||Ae||/||Ax|| 6.357251340383e+08
    23 KSP preconditioned resid norm 6.069380285565e-01 true resid norm
6.069380285564e-01 ||Ae||/||Ax|| 9.135162122826e-01
         0 KSP preconditioned resid norm 1.059057767841e+01 true resid
norm 1.676979421356e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 4.019380321433e-12 true resid
norm 2.416866152316e-12 ||Ae||/||Ax|| 1.441202033572e-12
       0 KSP preconditioned resid norm 1.856014897240e+01 true resid
norm 2.258409074155e+04 ||Ae||/||Ax|| 2.258409074155e+04
       1 KSP preconditioned resid norm 4.134595169550e+00 true resid
norm 3.095073305960e+03 ||Ae||/||Ax|| 3.095073305960e+03
         0 KSP preconditioned resid norm 3.186685909810e+04 true resid
norm 4.221911484877e+03 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.033970147546e-08 true resid
norm 9.465431646552e-09 ||Ae||/||Ax|| 2.241977758287e-12
       0 KSP preconditioned resid norm 5.453066254562e+04 true resid
norm 9.302387893635e+07 ||Ae||/||Ax|| 9.302387893635e+07
    24 KSP preconditioned resid norm 6.067888484804e-01 true resid norm
6.067888484804e-01 ||Ae||/||Ax|| 9.132916779617e-01
         0 KSP preconditioned resid norm 1.291113553227e+02 true resid
norm 1.435263438672e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.063613842780e-11 true resid
norm 1.896260102609e-12 ||Ae||/||Ax|| 1.321193065688e-12
       0 KSP preconditioned resid norm 1.906301114234e+02 true resid
norm 1.909600705660e+04 ||Ae||/||Ax|| 1.909600705660e+04
         0 KSP preconditioned resid norm 2.501076355639e+06 true resid
norm 2.646155443442e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.359675984372e-07 true resid
norm 3.948400636824e-08 ||Ae||/||Ax|| 1.492127246949e-12
       0 KSP preconditioned resid norm 3.692870740707e+06 true resid
norm 3.829388910660e+08 ||Ae||/||Ax|| 3.829388910660e+08
    25 KSP preconditioned resid norm 6.061458143347e-01 true resid norm
6.061458143349e-01 ||Ae||/||Ax|| 9.123238326640e-01
         0 KSP preconditioned resid norm 1.898570610054e+01 true resid
norm 1.765725343657e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.936978050501e-12 true resid
norm 6.086094877948e-13 ||Ae||/||Ax|| 3.446795901645e-13
       0 KSP preconditioned resid norm 2.890356755979e+01 true resid
norm 5.632353342854e+03 ||Ae||/||Ax|| 5.632353342854e+03
       1 KSP preconditioned resid norm 3.347545957016e+00 true resid
norm 2.977681913510e+02 ||Ae||/||Ax|| 2.977681913510e+02
         0 KSP preconditioned resid norm 1.672293494579e+04 true resid
norm 3.791067067454e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.688318749233e-09 true resid
norm 3.706105424556e-10 ||Ae||/||Ax|| 9.775889897526e-13
       0 KSP preconditioned resid norm 2.479351467762e+04 true resid
norm 3.649825941230e+06 ||Ae||/||Ax|| 3.649825941230e+06
    26 KSP preconditioned resid norm 6.061203278023e-01 true resid norm
6.061203278025e-01 ||Ae||/||Ax|| 9.122854723052e-01
         0 KSP preconditioned resid norm 1.113968853625e+01 true resid
norm 1.391648103460e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.583571291504e-12 true resid
norm 3.085091090508e-12 ||Ae||/||Ax|| 2.216861491664e-12
       0 KSP preconditioned resid norm 1.817483010767e+01 true resid
norm 3.036021800260e+04 ||Ae||/||Ax|| 3.036021800260e+04
         0 KSP preconditioned resid norm 3.035870909300e+05 true resid
norm 4.176399375582e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 7.682916311580e-08 true resid
norm 9.856631045334e-08 ||Ae||/||Ax|| 2.360078660811e-12
       0 KSP preconditioned resid norm 5.052605839103e+05 true resid
norm 9.313866415726e+08 ||Ae||/||Ax|| 9.313866415726e+08
    27 KSP preconditioned resid norm 6.050582839469e-01 true resid norm
6.050582839475e-01 ||Ae||/||Ax|| 9.106869659767e-01
         0 KSP preconditioned resid norm 2.990447709478e+01 true resid
norm 1.906982335170e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.975901688762e-12 true resid
norm 8.959071659844e-13 ||Ae||/||Ax|| 4.698035998874e-13
       0 KSP preconditioned resid norm 4.564797272899e+01 true resid
norm 6.660826868796e+03 ||Ae||/||Ax|| 6.660826868796e+03
       1 KSP preconditioned resid norm 5.741856900376e+00 true resid
norm 4.316372746358e+02 ||Ae||/||Ax|| 4.316372746358e+02
         0 KSP preconditioned resid norm 3.362508054185e+04 true resid
norm 5.723491523243e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.908925535146e-09 true resid
norm 8.167920463020e-10 ||Ae||/||Ax|| 1.427087020196e-12
       0 KSP preconditioned resid norm 5.016878651847e+04 true resid
norm 7.777153439460e+06 ||Ae||/||Ax|| 7.777153439460e+06
    28 KSP preconditioned resid norm 6.049696067046e-01 true resid norm
6.049696067052e-01 ||Ae||/||Ax|| 9.105534958452e-01
         0 KSP preconditioned resid norm 1.307515958591e+02 true resid
norm 1.427906745250e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.182758355330e-11 true resid
norm 2.057201119195e-12 ||Ae||/||Ax|| 1.440711115091e-12
       0 KSP preconditioned resid norm 1.939032992484e+02 true resid
norm 1.887943093068e+04 ||Ae||/||Ax|| 1.887943093068e+04
         0 KSP preconditioned resid norm 2.532822079009e+06 true resid
norm 2.617156607772e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.703584245532e-07 true resid
norm 3.916415744457e-08 ||Ae||/||Ax|| 1.496439201547e-12
       0 KSP preconditioned resid norm 3.755750940247e+06 true resid
norm 3.657512765233e+08 ||Ae||/||Ax|| 3.657512765233e+08
    29 KSP preconditioned resid norm 6.042206997356e-01 true resid norm
6.042206997367e-01 ||Ae||/||Ax|| 9.094262989567e-01
         0 KSP preconditioned resid norm 1.605346211532e+01 true resid
norm 1.860429376270e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 4.246735117107e-12 true resid
norm 5.084451043297e-13 ||Ae||/||Ax|| 2.732944936340e-13
       0 KSP preconditioned resid norm 2.610320208714e+01 true resid
norm 4.065852706967e+03 ||Ae||/||Ax|| 4.065852706967e+03
       1 KSP preconditioned resid norm 2.877850025932e+00 true resid
norm 1.989585620495e+02 ||Ae||/||Ax|| 1.989585620495e+02
         0 KSP preconditioned resid norm 8.393515860467e+03 true resid
norm 2.716610215568e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.135902017233e-09 true resid
norm 1.613470301832e-10 ||Ae||/||Ax|| 5.939277900765e-13
       0 KSP preconditioned resid norm 1.249128866550e+04 true resid
norm 1.357354794244e+06 ||Ae||/||Ax|| 1.357354794244e+06
    30 KSP preconditioned resid norm 6.036072464106e-01 true resid norm
6.036072464106e-01 ||Ae||/||Ax|| 9.085029764221e-01
         0 KSP preconditioned resid norm 2.883261330146e+00 true resid
norm 3.250739645318e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 4.235830945947e-13 true resid
norm 2.317887358969e-13 ||Ae||/||Ax|| 7.130338359480e-14
       0 KSP preconditioned resid norm 4.332828306944e+00 true resid
norm 4.805075908318e+02 ||Ae||/||Ax|| 4.805075908318e+02
       1 KSP preconditioned resid norm 4.997777789575e-01 true resid
norm 2.836772510689e+01 ||Ae||/||Ax|| 2.836772510689e+01
         0 KSP preconditioned resid norm 2.719893799256e+03 true resid
norm 3.835679662417e+01 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.870465267545e-10 true resid
norm 3.805711052931e-11 ||Ae||/||Ax|| 9.921868841708e-13
       0 KSP preconditioned resid norm 4.032513880803e+03 true resid
norm 4.073608352827e+05 ||Ae||/||Ax|| 4.073608352827e+05
    31 KSP preconditioned resid norm 6.033915473355e-01 true resid norm
6.033915473355e-01 ||Ae||/||Ax|| 9.081783228451e-01
         0 KSP preconditioned resid norm 1.291700871249e+02 true resid
norm 1.391465820303e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.588667833148e-11 true resid
norm 1.910717598385e-12 ||Ae||/||Ax|| 1.373168906132e-12
       0 KSP preconditioned resid norm 1.910746715229e+02 true resid
norm 2.020332593927e+04 ||Ae||/||Ax|| 2.020332593927e+04
         0 KSP preconditioned resid norm 2.502932703828e+06 true resid
norm 2.796674096377e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.496637287492e-07 true resid
norm 4.190289858538e-08 ||Ae||/||Ax|| 1.498311821161e-12
       0 KSP preconditioned resid norm 3.701965548826e+06 true resid
norm 4.332025520420e+08 ||Ae||/||Ax|| 4.332025520420e+08
    32 KSP preconditioned resid norm 6.032347872852e-01 true resid norm
6.032347872852e-01 ||Ae||/||Ax|| 9.079423797328e-01
         0 KSP preconditioned resid norm 3.085017822443e+01 true resid
norm 1.411525194635e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 6.004209530886e-12 true resid
norm 3.040519508209e-12 ||Ae||/||Ax|| 2.154066763927e-12
       0 KSP preconditioned resid norm 4.655296569273e+01 true resid
norm 2.908584213658e+04 ||Ae||/||Ax|| 2.908584213658e+04
         0 KSP preconditioned resid norm 6.283648135204e+05 true resid
norm 4.002788588006e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.683469568558e-07 true resid
norm 9.315480748208e-08 ||Ae||/||Ax|| 2.327247753259e-12
       0 KSP preconditioned resid norm 9.613159135516e+05 true resid
norm 8.862542433870e+08 ||Ae||/||Ax|| 8.862542433870e+08
    33 KSP preconditioned resid norm 6.021170668776e-01 true resid norm
6.021170668776e-01 ||Ae||/||Ax|| 9.062600733603e-01
         0 KSP preconditioned resid norm 2.496747114756e+01 true resid
norm 1.763454064944e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.750593750321e-12 true resid
norm 8.749039226071e-13 ||Ae||/||Ax|| 4.961308264272e-13
       0 KSP preconditioned resid norm 3.839165429671e+01 true resid
norm 8.874445848779e+03 ||Ae||/||Ax|| 8.874445848779e+03
       1 KSP preconditioned resid norm 4.704365723380e+00 true resid
norm 4.544637711713e+02 ||Ae||/||Ax|| 4.544637711713e+02
         0 KSP preconditioned resid norm 2.117949112992e+04 true resid
norm 6.068694107650e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.274185237091e-09 true resid
norm 1.033879257432e-09 ||Ae||/||Ax|| 1.703627236918e-12
       0 KSP preconditioned resid norm 3.155284085205e+04 true resid
norm 1.026498895736e+07 ||Ae||/||Ax|| 1.026498895736e+07
    34 KSP preconditioned resid norm 6.020154889627e-01 true resid norm
6.020154889627e-01 ||Ae||/||Ax|| 9.061071861335e-01
         0 KSP preconditioned resid norm 6.600844705337e+01 true resid
norm 1.571282551433e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 9.127035655198e-12 true resid
norm 2.123441646685e-12 ||Ae||/||Ax|| 1.351406623047e-12
       0 KSP preconditioned resid norm 9.927912839217e+01 true resid
norm 1.983631149639e+04 ||Ae||/||Ax|| 1.983631149639e+04
         0 KSP preconditioned resid norm 1.282366227710e+06 true resid
norm 2.746699271493e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.694202700277e-07 true resid
norm 5.923079044524e-08 ||Ae||/||Ax|| 2.156435218809e-12
       0 KSP preconditioned resid norm 1.930685097231e+06 true resid
norm 5.580347911211e+08 ||Ae||/||Ax|| 5.580347911211e+08
    35 KSP preconditioned resid norm 6.019283247034e-01 true resid norm
6.019283247034e-01 ||Ae||/||Ax|| 9.059759932269e-01
         0 KSP preconditioned resid norm 8.594466828936e+00 true resid
norm 1.552167113542e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.302259299493e-12 true resid
norm 2.501851397978e-12 ||Ae||/||Ax|| 1.611844096007e-12
       0 KSP preconditioned resid norm 1.517062035319e+01 true resid
norm 2.395769141617e+04 ||Ae||/||Ax|| 2.395769141617e+04
       1 KSP preconditioned resid norm 3.768531609462e+00 true resid
norm 3.805704144094e+03 ||Ae||/||Ax|| 3.805704144094e+03
         0 KSP preconditioned resid norm 3.564523833517e+04 true resid
norm 5.210768718140e+03 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 9.976990409103e-09 true resid
norm 1.202787548197e-08 ||Ae||/||Ax|| 2.308272758316e-12
       0 KSP preconditioned resid norm 6.204405659939e+04 true resid
norm 1.148661297759e+08 ||Ae||/||Ax|| 1.148661297759e+08
    36 KSP preconditioned resid norm 6.018961864301e-01 true resid norm
6.018961864301e-01 ||Ae||/||Ax|| 9.059276211819e-01
         0 KSP preconditioned resid norm 1.168188962338e+02 true resid
norm 1.462216988869e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.418645682499e-11 true resid
norm 2.041023520946e-12 ||Ae||/||Ax|| 1.395841750221e-12
       0 KSP preconditioned resid norm 1.754388599855e+02 true resid
norm 1.921631796353e+04 ||Ae||/||Ax|| 1.921631796353e+04
         0 KSP preconditioned resid norm 2.263469795458e+06 true resid
norm 2.662858824807e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.716948113752e-07 true resid
norm 4.419656110223e-08 ||Ae||/||Ax|| 1.659741053130e-12
       0 KSP preconditioned resid norm 3.398850621172e+06 true resid
norm 4.296111918873e+08 ||Ae||/||Ax|| 4.296111918873e+08
    37 KSP preconditioned resid norm 6.018568422787e-01 true resid norm
6.018568422787e-01 ||Ae||/||Ax|| 9.058684034059e-01
         0 KSP preconditioned resid norm 1.034549019132e+01 true resid
norm 1.592038204875e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 6.000967723181e-12 true resid
norm 2.596964945857e-12 ||Ae||/||Ax|| 1.631220242017e-12
       0 KSP preconditioned resid norm 1.829726167467e+01 true resid
norm 2.244731226201e+04 ||Ae||/||Ax|| 2.244731226201e+04
       1 KSP preconditioned resid norm 3.636192348103e+00 true resid
norm 2.423089425503e+03 ||Ae||/||Ax|| 2.423089425503e+03
         0 KSP preconditioned resid norm 2.212926062660e+04 true resid
norm 3.283730406261e+03 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 9.403141259045e-09 true resid
norm 8.329503216749e-09 ||Ae||/||Ax|| 2.536597767243e-12
       0 KSP preconditioned resid norm 3.981873087265e+04 true resid
norm 7.213540526219e+07 ||Ae||/||Ax|| 7.213540526219e+07
    38 KSP preconditioned resid norm 6.018155290858e-01 true resid norm
6.018155290858e-01 ||Ae||/||Ax|| 9.058062219810e-01
         0 KSP preconditioned resid norm 1.349486872589e+01 true resid
norm 1.610396989430e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 6.175356860142e-12 true resid
norm 2.581123862449e-12 ||Ae||/||Ax|| 1.602787312315e-12
       0 KSP preconditioned resid norm 2.277553440852e+01 true resid
norm 2.133686523868e+04 ||Ae||/||Ax|| 2.133686523868e+04
       1 KSP preconditioned resid norm 4.289217345014e+00 true resid
norm 2.171775997019e+03 ||Ae||/||Ax|| 2.171775997019e+03
         0 KSP preconditioned resid norm 2.724991496114e+04 true resid
norm 2.927865309940e+03 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.241609895331e-08 true resid
norm 7.411776807546e-09 ||Ae||/||Ax|| 2.531460987083e-12
       0 KSP preconditioned resid norm 4.577058668061e+04 true resid
norm 6.399361173665e+07 ||Ae||/||Ax|| 6.399361173665e+07
    39 KSP preconditioned resid norm 6.018052851232e-01 true resid norm
6.018052851232e-01 ||Ae||/||Ax|| 9.057908035601e-01
         0 KSP preconditioned resid norm 9.545633930615e+00 true resid
norm 1.399666424034e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.225392454749e-12 true resid
norm 3.086870800377e-12 ||Ae||/||Ax|| 2.205433199919e-12
       0 KSP preconditioned resid norm 1.652136392969e+01 true resid
norm 3.005162698204e+04 ||Ae||/||Ax|| 3.005162698204e+04
         0 KSP preconditioned resid norm 2.808361970186e+05 true resid
norm 4.134441311453e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 8.960616496849e-08 true resid
norm 9.365904867226e-08 ||Ae||/||Ax|| 2.265337481338e-12
       0 KSP preconditioned resid norm 4.897440548135e+05 true resid
norm 9.218837674986e+08 ||Ae||/||Ax|| 9.218837674986e+08
    40 KSP preconditioned resid norm 6.015950872280e-01 true resid norm
6.015950872280e-01 ||Ae||/||Ax|| 9.054744299338e-01
         0 KSP preconditioned resid norm 1.144394898101e+01 true resid
norm 1.814391014800e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.520795319563e-12 true resid
norm 8.121754756768e-13 ||Ae||/||Ax|| 4.476297937169e-13
       0 KSP preconditioned resid norm 1.858758832997e+01 true resid
norm 7.522048855661e+03 ||Ae||/||Ax|| 7.522048855661e+03
       1 KSP preconditioned resid norm 2.518949764582e+00 true resid
norm 4.604287589273e+02 ||Ae||/||Ax|| 4.604287589273e+02
         0 KSP preconditioned resid norm 1.151661799541e+04 true resid
norm 6.314749970776e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.557958051927e-09 true resid
norm 1.135574112491e-09 ||Ae||/||Ax|| 1.798288321384e-12
       0 KSP preconditioned resid norm 1.753433812926e+04 true resid
norm 1.065913803144e+07 ||Ae||/||Ax|| 1.065913803144e+07
    41 KSP preconditioned resid norm 6.015090207046e-01 true resid norm
6.015090207046e-01 ||Ae||/||Ax|| 9.053448892547e-01
         0 KSP preconditioned resid norm 1.258660956657e+02 true resid
norm 1.438750764647e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.197701486962e-11 true resid
norm 1.773092241127e-12 ||Ae||/||Ax|| 1.232383179002e-12
       0 KSP preconditioned resid norm 1.867078416778e+02 true resid
norm 1.892221435105e+04 ||Ae||/||Ax|| 1.892221435105e+04
         0 KSP preconditioned resid norm 2.438197842595e+06 true resid
norm 2.622741836494e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.337308579470e-07 true resid
norm 3.676792841539e-08 ||Ae||/||Ax|| 1.401888966111e-12
       0 KSP preconditioned resid norm 3.615812631507e+06 true resid
norm 3.864011886426e+08 ||Ae||/||Ax|| 3.864011886426e+08
    42 KSP preconditioned resid norm 6.010305638787e-01 true resid norm
6.010305638787e-01 ||Ae||/||Ax|| 9.046247530187e-01
         0 KSP preconditioned resid norm 1.601892860278e+01 true resid
norm 1.620093141150e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.906376270553e-12 true resid
norm 2.341203654775e-12 ||Ae||/||Ax|| 1.445104355613e-12
       0 KSP preconditioned resid norm 2.477212981787e+01 true resid
norm 2.156064096911e+04 ||Ae||/||Ax|| 2.156064096911e+04
       1 KSP preconditioned resid norm 4.331360143003e+00 true resid
norm 1.728804931154e+03 ||Ae||/||Ax|| 1.728804931154e+03
         0 KSP preconditioned resid norm 2.698079436494e+04 true resid
norm 2.294109252400e+03 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 8.349797339796e-09 true resid
norm 5.432498245662e-09 ||Ae||/||Ax|| 2.368020720887e-12
       0 KSP preconditioned resid norm 4.215514246356e+04 true resid
norm 4.982999912105e+07 ||Ae||/||Ax|| 4.982999912105e+07
    43 KSP preconditioned resid norm 6.006234170649e-01 true resid norm
6.006234170649e-01 ||Ae||/||Ax|| 9.040119471017e-01
         0 KSP preconditioned resid norm 4.463958619807e+01 true resid
norm 1.574622602196e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 5.878231775653e-12 true resid
norm 2.441357046325e-12 ||Ae||/||Ax|| 1.550439478591e-12
       0 KSP preconditioned resid norm 6.644535573814e+01 true resid
norm 2.258145514606e+04 ||Ae||/||Ax|| 2.258145514606e+04
         0 KSP preconditioned resid norm 8.735448534613e+05 true resid
norm 3.116818060412e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.396527101691e-07 true resid
norm 7.278451382343e-08 ||Ae||/||Ax|| 2.335218559848e-12
       0 KSP preconditioned resid norm 1.306405480468e+06 true resid
norm 6.715521545148e+08 ||Ae||/||Ax|| 6.715521545148e+08
    44 KSP preconditioned resid norm 5.989943047846e-01 true resid norm
5.989943047846e-01 ||Ae||/||Ax|| 9.015599332062e-01
         0 KSP preconditioned resid norm 7.801033326842e+00 true resid
norm 1.858930249500e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.080604064893e-12 true resid
norm 1.090544444514e-12 ||Ae||/||Ax|| 5.866516211717e-13
       0 KSP preconditioned resid norm 1.379151864335e+01 true resid
norm 9.550188217064e+03 ||Ae||/||Ax|| 9.550188217064e+03
       1 KSP preconditioned resid norm 2.496696302386e+00 true resid
norm 9.139746581256e+02 ||Ae||/||Ax|| 9.139746581256e+02
         0 KSP preconditioned resid norm 9.828395655932e+03 true resid
norm 1.265631564011e+03 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 5.186882436309e-09 true resid
norm 2.816213825702e-09 ||Ae||/||Ax|| 2.225145062578e-12
       0 KSP preconditioned resid norm 1.683202118005e+04 true resid
norm 2.519632014187e+07 ||Ae||/||Ax|| 2.519632014187e+07
    45 KSP preconditioned resid norm 5.988241351926e-01 true resid norm
5.988241351925e-01 ||Ae||/||Ax|| 9.013038070881e-01
         0 KSP preconditioned resid norm 9.447428573545e+00 true resid
norm 1.429955730938e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 4.374949556633e-12 true resid
norm 3.254725539134e-12 ||Ae||/||Ax|| 2.276102307725e-12
       0 KSP preconditioned resid norm 1.683315376191e+01 true resid
norm 2.939854160002e+04 ||Ae||/||Ax|| 2.939854160002e+04
         0 KSP preconditioned resid norm 2.744710812966e+05 true resid
norm 4.045045515226e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.042493610744e-07 true resid
norm 9.586945287664e-08 ||Ae||/||Ax|| 2.370046332378e-12
       0 KSP preconditioned resid norm 4.926385836574e+05 true resid
norm 9.016080040954e+08 ||Ae||/||Ax|| 9.016080040954e+08
    46 KSP preconditioned resid norm 5.976964499873e-01 true resid norm
5.976964499873e-01 ||Ae||/||Ax|| 8.996065024723e-01
         0 KSP preconditioned resid norm 5.383367053747e+01 true resid
norm 1.764260162117e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 7.982003528687e-12 true resid
norm 9.988259842004e-13 ||Ae||/||Ax|| 5.661443848520e-13
       0 KSP preconditioned resid norm 7.967851250204e+01 true resid
norm 8.835407003521e+03 ||Ae||/||Ax|| 8.835407003521e+03
         0 KSP preconditioned resid norm 1.040087569810e+06 true resid
norm 1.273374485100e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.866589553920e-07 true resid
norm 1.610309314332e-08 ||Ae||/||Ax|| 1.264599953253e-12
       0 KSP preconditioned resid norm 1.535186941089e+06 true resid
norm 1.559914877523e+08 ||Ae||/||Ax|| 1.559914877523e+08
    47 KSP preconditioned resid norm 5.974396534595e-01 true resid norm
5.974396534595e-01 ||Ae||/||Ax|| 8.992199921858e-01
         0 KSP preconditioned resid norm 1.228150074723e+02 true resid
norm 1.476952018797e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.984957681616e-11 true resid
norm 1.797935076021e-12 ||Ae||/||Ax|| 1.217328019556e-12
       0 KSP preconditioned resid norm 1.811463975130e+02 true resid
norm 1.780914291385e+04 ||Ae||/||Ax|| 1.780914291385e+04
         0 KSP preconditioned resid norm 2.379005322375e+06 true resid
norm 2.472348820548e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 4.010884330048e-07 true resid
norm 3.569588576897e-08 ||Ae||/||Ax|| 1.443804590691e-12
       0 KSP preconditioned resid norm 3.509863401975e+06 true resid
norm 3.439767658288e+08 ||Ae||/||Ax|| 3.439767658288e+08
    48 KSP preconditioned resid norm 5.967070550787e-01 true resid norm
5.967070550787e-01 ||Ae||/||Ax|| 8.981173417231e-01
         0 KSP preconditioned resid norm 1.012539150796e+01 true resid
norm 1.765630637766e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.017922063749e-12 true resid
norm 1.697008580802e-12 ||Ae||/||Ax|| 9.611345343154e-13
       0 KSP preconditioned resid norm 1.749232306387e+01 true resid
norm 1.597340655478e+04 ||Ae||/||Ax|| 1.597340655478e+04
       1 KSP preconditioned resid norm 3.684080674752e+00 true resid
norm 1.813668746237e+03 ||Ae||/||Ax|| 1.813668746237e+03
         0 KSP preconditioned resid norm 2.013743165402e+04 true resid
norm 2.471319024569e+03 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 4.952352169099e-09 true resid
norm 5.601376542559e-09 ||Ae||/||Ax|| 2.266553401998e-12
       0 KSP preconditioned resid norm 3.294847400007e+04 true resid
norm 5.308988230187e+07 ||Ae||/||Ax|| 5.308988230187e+07
    49 KSP preconditioned resid norm 5.964515532433e-01 true resid norm
5.964515532433e-01 ||Ae||/||Ax|| 8.977327801074e-01
         0 KSP preconditioned resid norm 1.093052977323e+01 true resid
norm 1.523465150496e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.866847176528e-12 true resid
norm 2.802894812225e-12 ||Ae||/||Ax|| 1.839815509605e-12
       0 KSP preconditioned resid norm 1.813239863676e+01 true resid
norm 2.649037958872e+04 ||Ae||/||Ax|| 2.649037958872e+04
       1 KSP preconditioned resid norm 4.704200672868e+00 true resid
norm 4.271453532090e+03 ||Ae||/||Ax|| 4.271453532090e+03
         0 KSP preconditioned resid norm 4.372886205198e+04 true resid
norm 5.835849696038e+03 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 9.133182203665e-09 true resid
norm 1.333609063719e-08 ||Ae||/||Ax|| 2.285201184369e-12
       0 KSP preconditioned resid norm 7.260583406741e+04 true resid
norm 1.294173995053e+08 ||Ae||/||Ax|| 1.294173995053e+08
    50 KSP preconditioned resid norm 5.960049857385e-01 true resid norm
5.960049857384e-01 ||Ae||/||Ax|| 8.970606412129e-01
         0 KSP preconditioned resid norm 1.411765679476e+01 true resid
norm 1.767166683640e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.790271420127e-12 true resid
norm 1.520411942802e-12 ||Ae||/||Ax|| 8.603670252939e-13
       0 KSP preconditioned resid norm 2.321069451170e+01 true resid
norm 1.425848084877e+04 ||Ae||/||Ax|| 1.425848084877e+04
       1 KSP preconditioned resid norm 3.191110393758e+00 true resid
norm 8.938658647825e+02 ||Ae||/||Ax|| 8.938658647825e+02
         0 KSP preconditioned resid norm 1.423075913273e+04 true resid
norm 1.180447594766e+03 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 4.329162150964e-09 true resid
norm 2.697398221869e-09 ||Ae||/||Ax|| 2.285063931537e-12
       0 KSP preconditioned resid norm 2.254311405745e+04 true resid
norm 2.474682478603e+07 ||Ae||/||Ax|| 2.474682478603e+07
    51 KSP preconditioned resid norm 5.958843670909e-01 true resid norm
5.958843670909e-01 ||Ae||/||Ax|| 8.968790953468e-01
         0 KSP preconditioned resid norm 1.092502887893e+01 true resid
norm 1.489476681404e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 5.018879028103e-12 true resid
norm 2.959819346932e-12 ||Ae||/||Ax|| 1.987153866782e-12
       0 KSP preconditioned resid norm 1.888449217337e+01 true resid
norm 2.739572864219e+04 ||Ae||/||Ax|| 2.739572864219e+04
       1 KSP preconditioned resid norm 4.035613628494e+00 true resid
norm 3.621007811356e+03 ||Ae||/||Ax|| 3.621007811356e+03
         0 KSP preconditioned resid norm 3.565338989617e+04 true resid
norm 4.925936392346e+03 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.046410122204e-08 true resid
norm 1.126961437319e-08 ||Ae||/||Ax|| 2.287811590645e-12
       0 KSP preconditioned resid norm 6.286318510382e+04 true resid
norm 1.092621103884e+08 ||Ae||/||Ax|| 1.092621103884e+08
    52 KSP preconditioned resid norm 5.957958851724e-01 true resid norm
5.957958851724e-01 ||Ae||/||Ax|| 8.967459192015e-01
         0 KSP preconditioned resid norm 1.211500138028e+02 true resid
norm 1.470634192348e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.975615407437e-11 true resid
norm 1.742509977986e-12 ||Ae||/||Ax|| 1.184869756906e-12
       0 KSP preconditioned resid norm 1.783437433640e+02 true resid
norm 1.770927873907e+04 ||Ae||/||Ax|| 1.770927873907e+04
         0 KSP preconditioned resid norm 2.346650900918e+06 true resid
norm 2.459469721678e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 4.012877817092e-07 true resid
norm 3.364140079131e-08 ||Ae||/||Ax|| 1.367831467685e-12
       0 KSP preconditioned resid norm 3.453647937892e+06 true resid
norm 3.451901379566e+08 ||Ae||/||Ax|| 3.451901379566e+08
    53 KSP preconditioned resid norm 5.954303411293e-01 true resid norm
5.954303411293e-01 ||Ae||/||Ax|| 8.961957305597e-01
         0 KSP preconditioned resid norm 5.715319337158e+01 true resid
norm 1.713539825575e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 8.897594180720e-12 true resid
norm 9.392050869917e-13 ||Ae||/||Ax|| 5.481081168781e-13
       0 KSP preconditioned resid norm 8.421037088804e+01 true resid
norm 9.203195248415e+03 ||Ae||/||Ax|| 9.203195248415e+03
         0 KSP preconditioned resid norm 1.103266320611e+06 true resid
norm 1.326262551612e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.842280857507e-07 true resid
norm 1.636640643909e-08 ||Ae||/||Ax|| 1.234024621987e-12
       0 KSP preconditioned resid norm 1.623605198021e+06 true resid
norm 1.607960339473e+08 ||Ae||/||Ax|| 1.607960339473e+08
    54 KSP preconditioned resid norm 5.949923440921e-01 true resid norm
5.949923440921e-01 ||Ae||/||Ax|| 8.955364912706e-01
         0 KSP preconditioned resid norm 1.061464977350e+01 true resid
norm 1.835872043325e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.793279972453e-12 true resid
norm 3.305229259383e-13 ||Ae||/||Ax|| 1.800359274166e-13
       0 KSP preconditioned resid norm 1.834029670367e+01 true resid
norm 3.861587136413e+03 ||Ae||/||Ax|| 3.861587136413e+03
       1 KSP preconditioned resid norm 2.680650618945e+00 true resid
norm 2.982419314611e+02 ||Ae||/||Ax|| 2.982419314611e+02
         0 KSP preconditioned resid norm 6.846891275509e+03 true resid
norm 4.640227862039e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.024701703837e-09 true resid
norm 1.644112819257e-10 ||Ae||/||Ax|| 3.543172594405e-13
       0 KSP preconditioned resid norm 1.072754643541e+04 true resid
norm 1.529713354040e+06 ||Ae||/||Ax|| 1.529713354040e+06
    55 KSP preconditioned resid norm 5.947851576153e-01 true resid norm
5.947851576152e-01 ||Ae||/||Ax|| 8.952246501984e-01
         0 KSP preconditioned resid norm 1.125730446931e+02 true resid
norm 1.556173812245e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.469897153038e-11 true resid
norm 1.731757462454e-12 ||Ae||/||Ax|| 1.112830359197e-12
       0 KSP preconditioned resid norm 1.668273278200e+02 true resid
norm 1.632173942149e+04 ||Ae||/||Ax|| 1.632173942149e+04
         0 KSP preconditioned resid norm 2.179151939112e+06 true resid
norm 2.267782824374e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.847526869939e-07 true resid
norm 3.227848451342e-08 ||Ae||/||Ax|| 1.423349897816e-12
       0 KSP preconditioned resid norm 3.226961147785e+06 true resid
norm 3.144514013843e+08 ||Ae||/||Ax|| 3.144514013843e+08
    56 KSP preconditioned resid norm 5.943009473236e-01 true resid norm
5.943009473235e-01 ||Ae||/||Ax|| 8.944958542904e-01
         0 KSP preconditioned resid norm 7.363443081780e+01 true resid
norm 1.757542262235e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.178069690966e-11 true resid
norm 1.190151633396e-12 ||Ae||/||Ax|| 6.771681449541e-13
       0 KSP preconditioned resid norm 1.090924087373e+02 true resid
norm 1.091377024910e+04 ||Ae||/||Ax|| 1.091377024910e+04
         0 KSP preconditioned resid norm 1.419669181163e+06 true resid
norm 1.534117214607e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.793307000436e-07 true resid
norm 2.115715522194e-08 ||Ae||/||Ax|| 1.379109433132e-12
       0 KSP preconditioned resid norm 2.101655795427e+06 true resid
norm 2.051504710492e+08 ||Ae||/||Ax|| 2.051504710492e+08
    57 KSP preconditioned resid norm 5.937338810967e-01 true resid norm
5.937338810966e-01 ||Ae||/||Ax|| 8.936423500324e-01
         0 KSP preconditioned resid norm 5.540540796433e+00 true resid
norm 1.771708196255e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 9.900895699938e-13 true resid
norm 3.966205335163e-13 ||Ae||/||Ax|| 2.238633508355e-13
       0 KSP preconditioned resid norm 9.701783015791e+00 true resid
norm 4.626355063667e+03 ||Ae||/||Ax|| 4.626355063667e+03
       1 KSP preconditioned resid norm 1.731539506149e+00 true resid
norm 4.020164242588e+02 ||Ae||/||Ax|| 4.020164242588e+02
         0 KSP preconditioned resid norm 4.360695698079e+03 true resid
norm 6.007582914621e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 6.740768116089e-10 true resid
norm 2.018820313798e-10 ||Ae||/||Ax|| 3.360453517644e-13
       0 KSP preconditioned resid norm 6.754387403272e+03 true resid
norm 2.034041489697e+06 ||Ae||/||Ax|| 2.034041489697e+06
    58 KSP preconditioned resid norm 5.932312048038e-01 true resid norm
5.932312048037e-01 ||Ae||/||Ax|| 8.928857605266e-01
         0 KSP preconditioned resid norm 2.194320843042e+01 true resid
norm 1.869287614685e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 5.296101831586e-12 true resid
norm 5.421633987559e-13 ||Ae||/||Ax|| 2.900374423373e-13
       0 KSP preconditioned resid norm 3.423876919685e+01 true resid
norm 4.547328997714e+03 ||Ae||/||Ax|| 4.547328997714e+03
       1 KSP preconditioned resid norm 3.995343397614e+00 true resid
norm 2.761588321024e+02 ||Ae||/||Ax|| 2.761588321024e+02
         0 KSP preconditioned resid norm 2.142308971213e+04 true resid
norm 3.951713072929e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.296595003158e-09 true resid
norm 3.330987235677e-10 ||Ae||/||Ax|| 8.429223413248e-13
       0 KSP preconditioned resid norm 3.202913929430e+04 true resid
norm 3.173564174806e+06 ||Ae||/||Ax|| 3.173564174806e+06
    59 KSP preconditioned resid norm 5.932111446241e-01 true resid norm
5.932111446240e-01 ||Ae||/||Ax|| 8.928555674944e-01
         0 KSP preconditioned resid norm 1.324767095623e+02 true resid
norm 1.405154609000e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.460794873924e-11 true resid
norm 1.931722813340e-12 ||Ae||/||Ax|| 1.374740402919e-12
       0 KSP preconditioned resid norm 1.967181449773e+02 true resid
norm 1.911658248966e+04 ||Ae||/||Ax|| 1.911658248966e+04
         0 KSP preconditioned resid norm 2.566330314698e+06 true resid
norm 2.649537984418e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.012663459242e-07 true resid
norm 3.698257725532e-08 ||Ae||/||Ax|| 1.395812306629e-12
       0 KSP preconditioned resid norm 3.809949813796e+06 true resid
norm 3.702109838396e+08 ||Ae||/||Ax|| 3.702109838396e+08
    60 KSP preconditioned resid norm 5.928602983876e-01 true resid norm
5.928602983876e-01 ||Ae||/||Ax|| 8.923275008553e-01
         0 KSP preconditioned resid norm 5.179438201612e-01 true resid
norm 3.250710514971e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 7.966760428987e-14 true resid
norm 7.545966269105e-14 ||Ae||/||Ax|| 2.321328286340e-14
       0 KSP preconditioned resid norm 1.033835105831e+00 true resid
norm 2.054494906229e+02 ||Ae||/||Ax|| 2.054494906229e+02
       1 KSP preconditioned resid norm 1.721270363501e-01 true resid
norm 1.772266094130e+01 ||Ae||/||Ax|| 1.772266094130e+01
         0 KSP preconditioned resid norm 2.287664874308e+02 true resid
norm 3.141706116754e+01 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 4.263435537337e-11 true resid
norm 1.930191711152e-11 ||Ae||/||Ax|| 6.143769147786e-13
       0 KSP preconditioned resid norm 3.937719734879e+02 true resid
norm 1.874883066320e+05 ||Ae||/||Ax|| 1.874883066320e+05
    61 KSP preconditioned resid norm 5.927978462698e-01 true resid norm
5.927978462698e-01 ||Ae||/||Ax|| 8.922335027542e-01
         0 KSP preconditioned resid norm 2.012108955893e+01 true resid
norm 1.407145543919e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 4.941711699645e-12 true resid
norm 2.950708049107e-12 ||Ae||/||Ax|| 2.096945878738e-12
       0 KSP preconditioned resid norm 3.155009698607e+01 true resid
norm 2.954858506909e+04 ||Ae||/||Ax|| 2.954858506909e+04
         0 KSP preconditioned resid norm 4.394139517734e+05 true resid
norm 4.065913733480e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.201387843927e-07 true resid
norm 9.242186560010e-08 ||Ae||/||Ax|| 2.273089683115e-12
       0 KSP preconditioned resid norm 7.030059377776e+05 true resid
norm 9.042247003330e+08 ||Ae||/||Ax|| 9.042247003330e+08
    62 KSP preconditioned resid norm 5.919537264319e-01 true resid norm
5.919537264319e-01 ||Ae||/||Ax|| 8.909629988135e-01
         0 KSP preconditioned resid norm 3.921276882243e+01 true resid
norm 1.752866070607e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 7.478780080025e-12 true resid
norm 1.074682746094e-12 ||Ae||/||Ax|| 6.131003184529e-13
       0 KSP preconditioned resid norm 6.051435663370e+01 true resid
norm 1.081789435855e+04 ||Ae||/||Ax|| 1.081789435855e+04
       1 KSP preconditioned resid norm 8.475042638128e+00 true resid
norm 8.648968591390e+02 ||Ae||/||Ax|| 8.648968591390e+02
         0 KSP preconditioned resid norm 6.171310505682e+04 true resid
norm 1.166624528674e+03 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.117035425221e-08 true resid
norm 2.084284926060e-09 ||Ae||/||Ax|| 1.786594465341e-12
       0 KSP preconditioned resid norm 9.334852695260e+04 true resid
norm 2.001338415085e+07 ||Ae||/||Ax|| 2.001338415085e+07
    63 KSP preconditioned resid norm 5.918304743007e-01 true resid norm
5.918304743007e-01 ||Ae||/||Ax|| 8.907774892314e-01
         0 KSP preconditioned resid norm 1.271757156211e+02 true resid
norm 1.442068162039e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.334657192625e-11 true resid
norm 1.755668015052e-12 ||Ae||/||Ax|| 1.217465346832e-12
       0 KSP preconditioned resid norm 1.907435869396e+02 true resid
norm 1.848711923036e+04 ||Ae||/||Ax|| 1.848711923036e+04
         0 KSP preconditioned resid norm 2.463163205707e+06 true resid
norm 2.564497576568e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 4.347566836521e-07 true resid
norm 3.700016154754e-08 ||Ae||/||Ax|| 1.442784032460e-12
       0 KSP preconditioned resid norm 3.698822458564e+06 true resid
norm 3.607966636266e+08 ||Ae||/||Ax|| 3.607966636266e+08
    64 KSP preconditioned resid norm 5.916348688499e-01 true resid norm
5.916348688499e-01 ||Ae||/||Ax|| 8.904830790245e-01
         0 KSP preconditioned resid norm 9.178083267510e+00 true resid
norm 1.576994924133e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 5.122102451871e-12 true resid
norm 2.576063074067e-12 ||Ae||/||Ax|| 1.633526547642e-12
       0 KSP preconditioned resid norm 1.564902268937e+01 true resid
norm 2.210478804214e+04 ||Ae||/||Ax|| 2.210478804214e+04
       1 KSP preconditioned resid norm 3.303401751858e+00 true resid
norm 2.716649640785e+03 ||Ae||/||Ax|| 2.716649640785e+03
         0 KSP preconditioned resid norm 2.703257356530e+04 true resid
norm 3.707021829719e+03 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.306788053895e-08 true resid
norm 9.205858705099e-09 ||Ae||/||Ax|| 2.483357025658e-12
       0 KSP preconditioned resid norm 4.675567763743e+04 true resid
norm 8.110243296727e+07 ||Ae||/||Ax|| 8.110243296727e+07
    65 KSP preconditioned resid norm 5.914431066657e-01 true resid norm
5.914431066657e-01 ||Ae||/||Ax|| 8.901944534056e-01
         0 KSP preconditioned resid norm 1.292123063289e+01 true resid
norm 1.579270302837e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 5.710439570660e-12 true resid
norm 2.548363112462e-12 ||Ae||/||Ax|| 1.613633276004e-12
       0 KSP preconditioned resid norm 2.079497685090e+01 true resid
norm 2.178641699821e+04 ||Ae||/||Ax|| 2.178641699821e+04
       1 KSP preconditioned resid norm 4.068151260640e+00 true resid
norm 2.235880590500e+03 ||Ae||/||Ax|| 2.235880590500e+03
         0 KSP preconditioned resid norm 2.936493457576e+04 true resid
norm 3.013807321465e+03 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.654868770687e-08 true resid
norm 7.565264176378e-09 ||Ae||/||Ax|| 2.510201671652e-12
       0 KSP preconditioned resid norm 4.809680205703e+04 true resid
norm 6.585494986157e+07 ||Ae||/||Ax|| 6.585494986157e+07
    66 KSP preconditioned resid norm 5.913378660812e-01 true resid norm
5.913378660812e-01 ||Ae||/||Ax|| 8.900360534115e-01
         0 KSP preconditioned resid norm 8.055011517200e+01 true resid
norm 1.481363614120e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.157691046605e-11 true resid
norm 2.337248942784e-12 ||Ae||/||Ax|| 1.577768564386e-12
       0 KSP preconditioned resid norm 1.194780984915e+02 true resid
norm 2.291312903788e+04 ||Ae||/||Ax|| 2.291312903788e+04
         0 KSP preconditioned resid norm 1.562577617260e+06 true resid
norm 3.162548632421e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.531197148422e-07 true resid
norm 6.955139474877e-08 ||Ae||/||Ax|| 2.199219769643e-12
       0 KSP preconditioned resid norm 2.316893078437e+06 true resid
norm 6.446392523306e+08 ||Ae||/||Ax|| 6.446392523306e+08
    67 KSP preconditioned resid norm 5.911446104772e-01 true resid norm
5.911446104772e-01 ||Ae||/||Ax|| 8.897451800125e-01
         0 KSP preconditioned resid norm 3.378924964593e+01 true resid
norm 1.557514924799e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 5.918960423550e-12 true resid
norm 2.303848597703e-12 ||Ae||/||Ax|| 1.479182357113e-12
       0 KSP preconditioned resid norm 5.084440656493e+01 true resid
norm 2.259304599402e+04 ||Ae||/||Ax|| 2.259304599402e+04
         0 KSP preconditioned resid norm 6.557284297420e+05 true resid
norm 3.118004113197e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.437397587258e-07 true resid
norm 7.205948047578e-08 ||Ae||/||Ax|| 2.311077146139e-12
       0 KSP preconditioned resid norm 9.823883172453e+05 true resid
norm 6.799097454264e+08 ||Ae||/||Ax|| 6.799097454264e+08
    68 KSP preconditioned resid norm 5.909708050484e-01 true resid norm
5.909708050484e-01 ||Ae||/||Ax|| 8.894835815139e-01
         0 KSP preconditioned resid norm 1.029814855951e+02 true resid
norm 1.528108053546e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.441035778527e-11 true resid
norm 1.764200363703e-12 ||Ae||/||Ax|| 1.154499748633e-12
       0 KSP preconditioned resid norm 1.525231162412e+02 true resid
norm 1.723355688473e+04 ||Ae||/||Ax|| 1.723355688473e+04
         0 KSP preconditioned resid norm 1.991893423870e+06 true resid
norm 2.392943171797e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.957228856265e-07 true resid
norm 4.096332740568e-08 ||Ae||/||Ax|| 1.711838705092e-12
       0 KSP preconditioned resid norm 2.948628795930e+06 true resid
norm 3.878356440933e+08 ||Ae||/||Ax|| 3.878356440933e+08
    69 KSP preconditioned resid norm 5.896448468440e-01 true resid norm
5.896448468440e-01 ||Ae||/||Ax|| 8.874878517038e-01
         0 KSP preconditioned resid norm 9.959789410450e+00 true resid
norm 1.824191731213e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.971054140591e-12 true resid
norm 2.985849351125e-13 ||Ae||/||Ax|| 1.636806756677e-13
       0 KSP preconditioned resid norm 1.726064485951e+01 true resid
norm 3.573429631643e+03 ||Ae||/||Ax|| 3.573429631643e+03
       1 KSP preconditioned resid norm 1.767181500542e+00 true resid
norm 1.664467395793e+02 ||Ae||/||Ax|| 1.664467395793e+02
         0 KSP preconditioned resid norm 3.163790325043e+03 true resid
norm 2.324997666159e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 6.289145898962e-10 true resid
norm 7.670345105221e-11 ||Ae||/||Ax|| 3.299076475158e-13
       0 KSP preconditioned resid norm 4.864956911035e+03 true resid
norm 8.021173018370e+05 ||Ae||/||Ax|| 8.021173018370e+05
    70 KSP preconditioned resid norm 5.889057970138e-01 true resid norm
5.889057970138e-01 ||Ae||/||Ax|| 8.863754910182e-01
         0 KSP preconditioned resid norm 1.324284912711e+01 true resid
norm 1.610385052874e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 4.041728266896e-12 true resid
norm 2.112113869715e-12 ||Ae||/||Ax|| 1.311558292189e-12
       0 KSP preconditioned resid norm 2.102017771354e+01 true resid
norm 1.998307524113e+04 ||Ae||/||Ax|| 1.998307524113e+04
       1 KSP preconditioned resid norm 3.260579450742e+00 true resid
norm 1.564822546570e+03 ||Ae||/||Ax|| 1.564822546570e+03
         0 KSP preconditioned resid norm 2.226546285877e+04 true resid
norm 2.098460913561e+03 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 7.188599597040e-09 true resid
norm 4.612612176875e-09 ||Ae||/||Ax|| 2.198092967597e-12
       0 KSP preconditioned resid norm 3.635036633697e+04 true resid
norm 4.533513630815e+07 ||Ae||/||Ax|| 4.533513630815e+07
    71 KSP preconditioned resid norm 5.883704232756e-01 true resid norm
5.883704232756e-01 ||Ae||/||Ax|| 8.855696878447e-01
         0 KSP preconditioned resid norm 7.920074111172e+00 true resid
norm 1.547320913348e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.316080647221e-12 true resid
norm 2.537037818142e-12 ||Ae||/||Ax|| 1.639632603848e-12
       0 KSP preconditioned resid norm 1.442399388621e+01 true resid
norm 2.368516623298e+04 ||Ae||/||Ax|| 2.368516623298e+04
       1 KSP preconditioned resid norm 3.086776130929e+00 true resid
norm 3.332271030731e+03 ||Ae||/||Ax|| 3.332271030731e+03
         0 KSP preconditioned resid norm 2.999510096744e+04 true resid
norm 4.545338210712e+03 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 5.577628756679e-09 true resid
norm 1.057139225253e-08 ||Ae||/||Ax|| 2.325765820377e-12
       0 KSP preconditioned resid norm 5.577865132754e+04 true resid
norm 1.003633683157e+08 ||Ae||/||Ax|| 1.003633683157e+08
    72 KSP preconditioned resid norm 5.882348116387e-01 true resid norm
5.882348116387e-01 ||Ae||/||Ax|| 8.853655756899e-01
         0 KSP preconditioned resid norm 1.092002953913e+02 true resid
norm 1.442811838005e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.510142363396e-11 true resid
norm 2.472805557534e-12 ||Ae||/||Ax|| 1.713879448725e-12
       0 KSP preconditioned resid norm 1.617555465975e+02 true resid
norm 2.174335767635e+04 ||Ae||/||Ax|| 2.174335767635e+04
         0 KSP preconditioned resid norm 2.117461285795e+06 true resid
norm 3.004256903182e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.784290598771e-07 true resid
norm 6.296997145031e-08 ||Ae||/||Ax|| 2.096024856717e-12
       0 KSP preconditioned resid norm 3.138421687462e+06 true resid
norm 5.514384235017e+08 ||Ae||/||Ax|| 5.514384235017e+08
    73 KSP preconditioned resid norm 5.879913320737e-01 true resid norm
5.879913320737e-01 ||Ae||/||Ax|| 8.849991090664e-01
         0 KSP preconditioned resid norm 3.904908866645e+01 true resid
norm 1.513472973354e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 8.170949789843e-12 true resid
norm 3.071966572315e-12 ||Ae||/||Ax|| 2.029746567266e-12
       0 KSP preconditioned resid norm 5.862913141809e+01 true resid
norm 2.549874294023e+04 ||Ae||/||Ax|| 2.549874294023e+04
         0 KSP preconditioned resid norm 7.707267786027e+05 true resid
norm 3.513193195809e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.957443610758e-07 true resid
norm 8.973046683565e-08 ||Ae||/||Ax|| 2.554099983533e-12
       0 KSP preconditioned resid norm 1.168625078742e+06 true resid
norm 7.695198083471e+08 ||Ae||/||Ax|| 7.695198083471e+08
    74 KSP preconditioned resid norm 5.874271286263e-01 true resid norm
5.874271286262e-01 ||Ae||/||Ax|| 8.841499136428e-01
         0 KSP preconditioned resid norm 6.814273537836e+01 true resid
norm 1.685650475236e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 8.630067001308e-12 true resid
norm 1.639428530065e-12 ||Ae||/||Ax|| 9.725791640377e-13
       0 KSP preconditioned resid norm 1.012230599537e+02 true resid
norm 1.439070776509e+04 ||Ae||/||Ax|| 1.439070776509e+04
         0 KSP preconditioned resid norm 1.313576699279e+06 true resid
norm 2.005797728971e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.929798598126e-07 true resid
norm 4.228044967898e-08 ||Ae||/||Ax|| 2.107911932908e-12
       0 KSP preconditioned resid norm 1.947249912005e+06 true resid
norm 3.651807360488e+08 ||Ae||/||Ax|| 3.651807360488e+08
    75 KSP preconditioned resid norm 5.868568962526e-01 true resid norm
5.868568962526e-01 ||Ae||/||Ax|| 8.832916439454e-01
         0 KSP preconditioned resid norm 7.973593956915e+00 true resid
norm 1.815468893600e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.459684326756e-12 true resid
norm 3.431243764136e-13 ||Ae||/||Ax|| 1.890004161587e-13
       0 KSP preconditioned resid norm 1.451784367052e+01 true resid
norm 4.216755428875e+03 ||Ae||/||Ax|| 4.216755428875e+03
       1 KSP preconditioned resid norm 2.272817824119e+00 true resid
norm 3.227785703171e+02 ||Ae||/||Ax|| 3.227785703171e+02
         0 KSP preconditioned resid norm 4.387520111849e+03 true resid
norm 4.916672293340e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.228893771290e-09 true resid
norm 1.591744413248e-10 ||Ae||/||Ax|| 3.237442559277e-13
       0 KSP preconditioned resid norm 7.014386174558e+03 true resid
norm 1.590707000623e+06 ||Ae||/||Ax|| 1.590707000623e+06
    76 KSP preconditioned resid norm 5.864843728836e-01 true resid norm
5.864843728836e-01 ||Ae||/||Ax|| 8.827309505615e-01
         0 KSP preconditioned resid norm 6.250747246117e+01 true resid
norm 1.680360161727e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.024294628567e-11 true resid
norm 1.496340330347e-12 ||Ae||/||Ax|| 8.904878635119e-13
       0 KSP preconditioned resid norm 9.290074177060e+01 true resid
norm 1.431458510242e+04 ||Ae||/||Ax|| 1.431458510242e+04
         0 KSP preconditioned resid norm 1.209934875804e+06 true resid
norm 2.002398243896e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.927413143647e-07 true resid
norm 3.890279585053e-08 ||Ae||/||Ax|| 1.942810126263e-12
       0 KSP preconditioned resid norm 1.795157337590e+06 true resid
norm 3.681390335541e+08 ||Ae||/||Ax|| 3.681390335541e+08
    77 KSP preconditioned resid norm 5.863438456782e-01 true resid norm
5.863438456782e-01 ||Ae||/||Ax|| 8.825194398728e-01
         0 KSP preconditioned resid norm 3.557457154005e+01 true resid
norm 1.495175850272e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 6.552976352371e-12 true resid
norm 2.697118522673e-12 ||Ae||/||Ax|| 1.803880474783e-12
       0 KSP preconditioned resid norm 5.314014688463e+01 true resid
norm 2.602314726827e+04 ||Ae||/||Ax|| 2.602314726827e+04
         0 KSP preconditioned resid norm 7.104613432327e+05 true resid
norm 3.586135159711e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.700579336387e-07 true resid
norm 8.241198236784e-08 ||Ae||/||Ax|| 2.298072400999e-12
       0 KSP preconditioned resid norm 1.070349184999e+06 true resid
norm 7.869520417219e+08 ||Ae||/||Ax|| 7.869520417219e+08
    78 KSP preconditioned resid norm 5.862761416078e-01 true resid norm
5.862761416078e-01 ||Ae||/||Ax|| 8.824175369387e-01
         0 KSP preconditioned resid norm 1.137370859163e+02 true resid
norm 1.431251994420e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.550599539711e-11 true resid
norm 2.140123663840e-12 ||Ae||/||Ax|| 1.495280825588e-12
       0 KSP preconditioned resid norm 1.685511344030e+02 true resid
norm 2.128989830652e+04 ||Ae||/||Ax|| 2.128989830652e+04
         0 KSP preconditioned resid norm 2.205305922755e+06 true resid
norm 2.943649269335e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.001524327934e-07 true resid
norm 5.345386935089e-08 ||Ae||/||Ax|| 1.815904833084e-12
       0 KSP preconditioned resid norm 3.269519691203e+06 true resid
norm 5.226429163913e+08 ||Ae||/||Ax|| 5.226429163913e+08
    79 KSP preconditioned resid norm 5.853325048441e-01 true resid norm
5.853325048441e-01 ||Ae||/||Ax|| 8.809972478126e-01
         0 KSP preconditioned resid norm 1.285183313505e+01 true resid
norm 1.902522964885e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.400674526664e-12 true resid
norm 3.109052139726e-13 ||Ae||/||Ax|| 1.634173251577e-13
       0 KSP preconditioned resid norm 2.224990077161e+01 true resid
norm 3.354904043059e+03 ||Ae||/||Ax|| 3.354904043059e+03
       1 KSP preconditioned resid norm 3.540335796102e+00 true resid
norm 3.236675479086e+02 ||Ae||/||Ax|| 3.236675479086e+02
         0 KSP preconditioned resid norm 1.210770398169e+04 true resid
norm 5.113311265897e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.382186944719e-09 true resid
norm 2.286802654925e-10 ||Ae||/||Ax|| 4.472253958364e-13
       0 KSP preconditioned resid norm 1.854289484283e+04 true resid
norm 2.136959299308e+06 ||Ae||/||Ax|| 2.136959299308e+06
    80 KSP preconditioned resid norm 5.845194027528e-01 true resid norm
5.845194027528e-01 ||Ae||/||Ax|| 8.797734293868e-01
         0 KSP preconditioned resid norm 5.129824230359e+01 true resid
norm 1.787548726169e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 7.352487657917e-12 true resid
norm 1.098422290421e-12 ||Ae||/||Ax|| 6.144852301593e-13
       0 KSP preconditioned resid norm 7.752428823074e+01 true resid
norm 9.082631362949e+03 ||Ae||/||Ax|| 9.082631362949e+03
         0 KSP preconditioned resid norm 9.791629346963e+05 true resid
norm 1.290809980827e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.287113113167e-07 true resid
norm 2.046236012232e-08 ||Ae||/||Ax|| 1.585234110850e-12
       0 KSP preconditioned resid norm 1.463510519927e+06 true resid
norm 1.923865562740e+08 ||Ae||/||Ax|| 1.923865562740e+08
    81 KSP preconditioned resid norm 5.843606398102e-01 true resid norm
5.843606398102e-01 ||Ae||/||Ax|| 8.795344716759e-01
         0 KSP preconditioned resid norm 8.540929220162e+01 true resid
norm 1.460153032186e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.251223185764e-11 true resid
norm 2.700840277944e-12 ||Ae||/||Ax|| 1.849696722473e-12
       0 KSP preconditioned resid norm 1.273080251685e+02 true resid
norm 2.428337899099e+04 ||Ae||/||Ax|| 2.428337899099e+04
         0 KSP preconditioned resid norm 1.659645652487e+06 true resid
norm 3.348400350969e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.372997882797e-07 true resid
norm 7.347016639941e-08 ||Ae||/||Ax|| 2.194187035554e-12
       0 KSP preconditioned resid norm 2.480495543944e+06 true resid
norm 6.845724150934e+08 ||Ae||/||Ax|| 6.845724150934e+08
    82 KSP preconditioned resid norm 5.842984450525e-01 true resid norm
5.842984450525e-01 ||Ae||/||Ax|| 8.794408609335e-01
         0 KSP preconditioned resid norm 8.992052614542e+01 true resid
norm 1.408770938845e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.123782548146e-11 true resid
norm 2.665039187047e-12 ||Ae||/||Ax|| 1.891747702599e-12
       0 KSP preconditioned resid norm 1.341038910343e+02 true resid
norm 2.553689722159e+04 ||Ae||/||Ax|| 2.553689722159e+04
         0 KSP preconditioned resid norm 1.748515981060e+06 true resid
norm 3.519698125828e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.205306864500e-07 true resid
norm 7.778023791760e-08 ||Ae||/||Ax|| 2.209855366483e-12
       0 KSP preconditioned resid norm 2.613685337068e+06 true resid
norm 7.205543009626e+08 ||Ae||/||Ax|| 7.205543009626e+08
    83 KSP preconditioned resid norm 5.836925298371e-01 true resid norm
5.836925298370e-01 ||Ae||/||Ax|| 8.785288841805e-01
         0 KSP preconditioned resid norm 1.566216522481e+01 true resid
norm 1.762689629179e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.474200242271e-12 true resid
norm 5.672372200220e-13 ||Ae||/||Ax|| 3.218020975628e-13
       0 KSP preconditioned resid norm 2.476535413970e+01 true resid
norm 5.179236647466e+03 ||Ae||/||Ax|| 5.179236647466e+03
       1 KSP preconditioned resid norm 3.886472467620e+00 true resid
norm 4.607747242004e+02 ||Ae||/||Ax|| 4.607747242004e+02
         0 KSP preconditioned resid norm 2.642989888257e+04 true resid
norm 6.691168916981e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.451274694668e-09 true resid
norm 5.548097328087e-10 ||Ae||/||Ax|| 8.291671301268e-13
       0 KSP preconditioned resid norm 3.978749399029e+04 true resid
norm 5.239781741328e+06 ||Ae||/||Ax|| 5.239781741328e+06
    84 KSP preconditioned resid norm 5.833447809338e-01 true resid norm
5.833447809337e-01 ||Ae||/||Ax|| 8.780054794075e-01
         0 KSP preconditioned resid norm 1.579817072976e+01 true resid
norm 1.847120603885e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.949880851394e-12 true resid
norm 4.536574430896e-13 ||Ae||/||Ax|| 2.456025026927e-13
       0 KSP preconditioned resid norm 2.608767270889e+01 true resid
norm 4.616421797210e+03 ||Ae||/||Ax|| 4.616421797210e+03
       1 KSP preconditioned resid norm 2.834914979831e+00 true resid
norm 2.374949050100e+02 ||Ae||/||Ax|| 2.374949050100e+02
         0 KSP preconditioned resid norm 9.577533214753e+03 true resid
norm 3.434071579533e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.042397070877e-09 true resid
norm 4.088972236920e-10 ||Ae||/||Ax|| 1.190706757917e-12
       0 KSP preconditioned resid norm 1.437880068149e+04 true resid
norm 3.751388111097e+06 ||Ae||/||Ax|| 3.751388111097e+06
    85 KSP preconditioned resid norm 5.833349314379e-01 true resid norm
5.833349314378e-01 ||Ae||/||Ax|| 8.779906547075e-01
         0 KSP preconditioned resid norm 4.750562102904e+01 true resid
norm 1.386915909260e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 7.134517663227e-12 true resid
norm 3.169630514519e-12 ||Ae||/||Ax|| 2.285380456997e-12
       0 KSP preconditioned resid norm 7.055485444445e+01 true resid
norm 2.929761031751e+04 ||Ae||/||Ax|| 2.929761031751e+04
         0 KSP preconditioned resid norm 9.419265122794e+05 true resid
norm 4.031732428306e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.985240298731e-07 true resid
norm 9.672100610764e-08 ||Ae||/||Ax|| 2.398993678960e-12
       0 KSP preconditioned resid norm 1.412581656802e+06 true resid
norm 8.846053470960e+08 ||Ae||/||Ax|| 8.846053470960e+08
    86 KSP preconditioned resid norm 5.833010574132e-01 true resid norm
5.833010574131e-01 ||Ae||/||Ax|| 8.779396701436e-01
         0 KSP preconditioned resid norm 1.192404334527e+02 true resid
norm 1.425183123674e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.235604647787e-11 true resid
norm 2.012951294373e-12 ||Ae||/||Ax|| 1.412415893042e-12
       0 KSP preconditioned resid norm 1.758432326455e+02 true resid
norm 2.042921119685e+04 ||Ae||/||Ax|| 2.042921119685e+04
         0 KSP preconditioned resid norm 2.311016294074e+06 true resid
norm 2.827058116366e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.068968815656e-07 true resid
norm 4.919920936275e-08 ||Ae||/||Ax|| 1.740297062800e-12
       0 KSP preconditioned resid norm 3.407232359321e+06 true resid
norm 4.735317430036e+08 ||Ae||/||Ax|| 4.735317430036e+08
    87 KSP preconditioned resid norm 5.829989969913e-01 true resid norm
5.829989969912e-01 ||Ae||/||Ax|| 8.774850321418e-01
         0 KSP preconditioned resid norm 3.998747085072e+01 true resid
norm 1.762721503673e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.166969562084e-12 true resid
norm 6.486870653528e-13 ||Ae||/||Ax|| 3.680031496758e-13
       0 KSP preconditioned resid norm 5.915011054672e+01 true resid
norm 7.133627477421e+03 ||Ae||/||Ax|| 7.133627477421e+03
         0 KSP preconditioned resid norm 7.627346460647e+05 true resid
norm 1.056638572840e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 6.206469550246e-08 true resid
norm 1.123586577536e-08 ||Ae||/||Ax|| 1.063359417702e-12
       0 KSP preconditioned resid norm 1.123499573231e+06 true resid
norm 1.189736380226e+08 ||Ae||/||Ax|| 1.189736380226e+08
    88 KSP preconditioned resid norm 5.824042251653e-01 true resid norm
5.824042251652e-01 ||Ae||/||Ax|| 8.765898275573e-01
         0 KSP preconditioned resid norm 6.971219401195e+00 true resid
norm 1.807720222312e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.247867208892e-12 true resid
norm 3.789951794609e-13 ||Ae||/||Ax|| 2.096536702876e-13
       0 KSP preconditioned resid norm 1.252183439206e+01 true resid
norm 4.360337135947e+03 ||Ae||/||Ax|| 4.360337135947e+03
       1 KSP preconditioned resid norm 2.103328754386e+00 true resid
norm 3.614838050848e+02 ||Ae||/||Ax|| 3.614838050848e+02
         0 KSP preconditioned resid norm 6.979189452907e+03 true resid
norm 5.474992312237e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 9.173120402766e-10 true resid
norm 1.907318411549e-10 ||Ae||/||Ax|| 3.483691488088e-13
       0 KSP preconditioned resid norm 1.055666429308e+04 true resid
norm 1.946817034359e+06 ||Ae||/||Ax|| 1.946817034359e+06
    89 KSP preconditioned resid norm 5.819404872683e-01 true resid norm
5.819404872682e-01 ||Ae||/||Ax|| 8.758918451157e-01
         0 KSP preconditioned resid norm 1.171719403375e+02 true resid
norm 1.533726361322e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.507753137557e-11 true resid
norm 1.656754525441e-12 ||Ae||/||Ax|| 1.080215198240e-12
       0 KSP preconditioned resid norm 1.713834710495e+02 true resid
norm 1.694232906255e+04 ||Ae||/||Ax|| 1.694232906255e+04
         0 KSP preconditioned resid norm 2.267713864968e+06 true resid
norm 2.352031145597e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.483320177602e-07 true resid
norm 3.371772002715e-08 ||Ae||/||Ax|| 1.433557548346e-12
       0 KSP preconditioned resid norm 3.314656971024e+06 true resid
norm 3.271599665189e+08 ||Ae||/||Ax|| 3.271599665189e+08
    90 KSP preconditioned resid norm 5.805277469629e-01 true resid norm
5.805277469629e-01 ||Ae||/||Ax|| 8.737654975942e-01
         0 KSP preconditioned resid norm 7.556994708818e-01 true resid
norm 3.238265285333e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.403845620262e-13 true resid
norm 9.384504348959e-14 ||Ae||/||Ax|| 2.898003567362e-14
       0 KSP preconditioned resid norm 1.431048996739e+00 true resid
norm 2.305182412482e+02 ||Ae||/||Ax|| 2.305182412482e+02
       1 KSP preconditioned resid norm 1.820810784106e-01 true resid
norm 1.341964601131e+01 ||Ae||/||Ax|| 1.341964601131e+01
         0 KSP preconditioned resid norm 2.143023034754e+02 true resid
norm 2.210114040080e+01 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.780027858452e-11 true resid
norm 1.104665955924e-11 ||Ae||/||Ax|| 4.998230570418e-13
       0 KSP preconditioned resid norm 3.504567738402e+02 true resid
norm 1.093748627228e+05 ||Ae||/||Ax|| 1.093748627228e+05
    91 KSP preconditioned resid norm 5.804055078487e-01 true resid norm
5.804055078487e-01 ||Ae||/||Ax|| 8.735815127270e-01
         0 KSP preconditioned resid norm 3.158687200419e+01 true resid
norm 1.416104290344e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 6.244679655833e-12 true resid
norm 2.963175603927e-12 ||Ae||/||Ax|| 2.092484024046e-12
       0 KSP preconditioned resid norm 4.798514922521e+01 true resid
norm 2.887862428400e+04 ||Ae||/||Ax|| 2.887862428400e+04
         0 KSP preconditioned resid norm 6.394308191634e+05 true resid
norm 3.974417995165e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.562537743433e-07 true resid
norm 9.185447772751e-08 ||Ae||/||Ax|| 2.311142860143e-12
       0 KSP preconditioned resid norm 9.822860946702e+05 true resid
norm 8.795690602290e+08 ||Ae||/||Ax|| 8.795690602290e+08
    92 KSP preconditioned resid norm 5.793523053958e-01 true resid norm
5.793523053958e-01 ||Ae||/||Ax|| 8.719963137935e-01
         0 KSP preconditioned resid norm 5.111607574546e+01 true resid
norm 1.694029865489e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 8.869362598310e-12 true resid
norm 1.395781692390e-12 ||Ae||/||Ax|| 8.239416086019e-13
       0 KSP preconditioned resid norm 7.747343073638e+01 true resid
norm 1.350834865747e+04 ||Ae||/||Ax|| 1.350834865747e+04
         0 KSP preconditioned resid norm 9.646228444529e+05 true resid
norm 1.888679638275e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.814486071819e-07 true resid
norm 3.645899554871e-08 ||Ae||/||Ax|| 1.930395966042e-12
       0 KSP preconditioned resid norm 1.442939231682e+06 true resid
norm 3.652889929148e+08 ||Ae||/||Ax|| 3.652889929148e+08
    93 KSP preconditioned resid norm 5.790676556936e-01 true resid norm
5.790676556936e-01 ||Ae||/||Ax|| 8.715678810614e-01
         0 KSP preconditioned resid norm 1.211809242713e+02 true resid
norm 1.476259870633e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.458475779350e-11 true resid
norm 1.840603999110e-12 ||Ae||/||Ax|| 1.246802162495e-12
       0 KSP preconditioned resid norm 1.806135167741e+02 true resid
norm 1.771464011215e+04 ||Ae||/||Ax|| 1.771464011215e+04
         0 KSP preconditioned resid norm 2.344872063761e+06 true resid
norm 2.459046505164e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 4.005958017645e-07 true resid
norm 3.524344338907e-08 ||Ae||/||Ax|| 1.433215814140e-12
       0 KSP preconditioned resid norm 3.497168058421e+06 true resid
norm 3.475528395444e+08 ||Ae||/||Ax|| 3.475528395444e+08
    94 KSP preconditioned resid norm 5.785720406840e-01 true resid norm
5.785720406840e-01 ||Ae||/||Ax|| 8.708219196535e-01
         0 KSP preconditioned resid norm 8.335095456735e+00 true resid
norm 1.789667043600e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.560623267105e-12 true resid
norm 3.930049335444e-13 ||Ae||/||Ax|| 2.195966757894e-13
       0 KSP preconditioned resid norm 1.532975782280e+01 true resid
norm 4.611363927514e+03 ||Ae||/||Ax|| 4.611363927514e+03
       1 KSP preconditioned resid norm 2.804788016722e+00 true resid
norm 4.915315731076e+02 ||Ae||/||Ax|| 4.915315731076e+02
         0 KSP preconditioned resid norm 1.432433111230e+04 true resid
norm 7.751097283288e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.678629111897e-09 true resid
norm 2.873408800557e-10 ||Ae||/||Ax|| 3.707099389337e-13
       0 KSP preconditioned resid norm 2.179340507789e+04 true resid
norm 3.160361945851e+06 ||Ae||/||Ax|| 3.160361945851e+06
    95 KSP preconditioned resid norm 5.781488580957e-01 true resid norm
5.781488580957e-01 ||Ae||/||Ax|| 8.701849779280e-01
         0 KSP preconditioned resid norm 2.306204794839e+01 true resid
norm 1.753817523071e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.909464122181e-12 true resid
norm 1.012358671775e-12 ||Ae||/||Ax|| 5.772314727487e-13
       0 KSP preconditioned resid norm 3.566359604330e+01 true resid
norm 1.033237546789e+04 ||Ae||/||Ax|| 1.033237546789e+04
       1 KSP preconditioned resid norm 3.961363384402e+00 true resid
norm 4.523755966710e+02 ||Ae||/||Ax|| 4.523755966710e+02
         0 KSP preconditioned resid norm 1.569777113244e+04 true resid
norm 5.646829084848e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.960576905791e-09 true resid
norm 1.003138802914e-09 ||Ae||/||Ax|| 1.776463901849e-12
       0 KSP preconditioned resid norm 2.328272999469e+04 true resid
norm 1.019146903873e+07 ||Ae||/||Ax|| 1.019146903873e+07
    96 KSP preconditioned resid norm 5.780939353474e-01 true resid norm
5.780939353474e-01 ||Ae||/||Ax|| 8.701023124521e-01
         0 KSP preconditioned resid norm 2.523966994426e+01 true resid
norm 1.427142417818e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 4.696151373685e-12 true resid
norm 2.899424767120e-12 ||Ae||/||Ax|| 2.031629591356e-12
       0 KSP preconditioned resid norm 3.822047061207e+01 true resid
norm 2.877773199279e+04 ||Ae||/||Ax|| 2.877773199279e+04
         0 KSP preconditioned resid norm 5.239827145472e+05 true resid
norm 3.960542084533e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.206943437103e-07 true resid
norm 8.344477043618e-08 ||Ae||/||Ax|| 2.106902758641e-12
       0 KSP preconditioned resid norm 8.091905864722e+05 true resid
norm 8.786451350027e+08 ||Ae||/||Ax|| 8.786451350027e+08
    97 KSP preconditioned resid norm 5.780693193956e-01 true resid norm
5.780693193956e-01 ||Ae||/||Ax|| 8.700652624239e-01
         0 KSP preconditioned resid norm 1.273735521175e+02 true resid
norm 1.417872493295e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.225895266321e-11 true resid
norm 1.949742713331e-12 ||Ae||/||Ax|| 1.375118512102e-12
       0 KSP preconditioned resid norm 1.869831058212e+02 true resid
norm 1.960134092692e+04 ||Ae||/||Ax|| 1.960134092692e+04
         0 KSP preconditioned resid norm 2.467970681993e+06 true resid
norm 2.715215672456e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.219361812540e-07 true resid
norm 4.024137180932e-08 ||Ae||/||Ax|| 1.482069075306e-12
       0 KSP preconditioned resid norm 3.622922508749e+06 true resid
norm 4.123732289482e+08 ||Ae||/||Ax|| 4.123732289482e+08
    98 KSP preconditioned resid norm 5.778578187423e-01 true resid norm
5.778578187423e-01 ||Ae||/||Ax|| 8.697469279868e-01
         0 KSP preconditioned resid norm 2.420335031712e+01 true resid
norm 1.801507397798e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 4.176865923608e-12 true resid
norm 1.508027966661e-12 ||Ae||/||Ax|| 8.370922975417e-13
       0 KSP preconditioned resid norm 3.645152326544e+01 true resid
norm 1.328932384933e+04 ||Ae||/||Ax|| 1.328932384933e+04
       1 KSP preconditioned resid norm 5.097331049424e+00 true resid
norm 8.083826688367e+02 ||Ae||/||Ax|| 8.083826688367e+02
         0 KSP preconditioned resid norm 2.671749989304e+04 true resid
norm 1.002642116539e+03 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 5.213856477170e-09 true resid
norm 2.347280397678e-09 ||Ae||/||Ax|| 2.341094951987e-12
       0 KSP preconditioned resid norm 3.996800141628e+04 true resid
norm 2.015710432510e+07 ||Ae||/||Ax|| 2.015710432510e+07
    99 KSP preconditioned resid norm 5.778052005289e-01 true resid norm
5.778052005289e-01 ||Ae||/||Ax|| 8.696677311186e-01
         0 KSP preconditioned resid norm 2.117180191019e+01 true resid
norm 1.467579483375e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 6.487968255464e-12 true resid
norm 3.171231925791e-12 ||Ae||/||Ax|| 2.160858721258e-12
       0 KSP preconditioned resid norm 3.225029306820e+01 true resid
norm 2.814631621777e+04 ||Ae||/||Ax|| 2.814631621777e+04
         0 KSP preconditioned resid norm 4.523530320889e+05 true resid
norm 3.875023149071e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.810687583045e-07 true resid
norm 9.909937010344e-08 ||Ae||/||Ax|| 2.557387821727e-12
       0 KSP preconditioned resid norm 7.127529316003e+05 true resid
norm 8.602590991178e+08 ||Ae||/||Ax|| 8.602590991178e+08
   100 KSP preconditioned resid norm 5.775826742339e-01 true resid norm
5.775826742339e-01 ||Ae||/||Ax|| 8.693328017378e-01
         0 KSP preconditioned resid norm 4.173866730709e+01 true resid
norm 1.656068350932e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 5.102909071988e-12 true resid
norm 1.371828994781e-12 ||Ae||/||Ax|| 8.283649609085e-13
       0 KSP preconditioned resid norm 6.233517788619e+01 true resid
norm 1.224436983729e+04 ||Ae||/||Ax|| 1.224436983729e+04
         0 KSP preconditioned resid norm 8.081153626986e+05 true resid
norm 1.727926041098e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.254789580939e-07 true resid
norm 3.634672700734e-08 ||Ae||/||Ax|| 2.103488583589e-12
       0 KSP preconditioned resid norm 1.205026700003e+06 true resid
norm 3.215246992350e+08 ||Ae||/||Ax|| 3.215246992350e+08
   101 KSP preconditioned resid norm 5.775307980729e-01 true resid norm
5.775307980729e-01 ||Ae||/||Ax|| 8.692547217496e-01
         0 KSP preconditioned resid norm 3.435170014284e+01 true resid
norm 1.438517571536e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 7.260722810963e-12 true resid
norm 3.112827248484e-12 ||Ae||/||Ax|| 2.163913260482e-12
       0 KSP preconditioned resid norm 5.163926752198e+01 true resid
norm 2.759499368127e+04 ||Ae||/||Ax|| 2.759499368127e+04
         0 KSP preconditioned resid norm 6.919550922855e+05 true resid
norm 3.800160663045e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.957221831070e-07 true resid
norm 9.319415383300e-08 ||Ae||/||Ax|| 2.452374046689e-12
       0 KSP preconditioned resid norm 1.055717278577e+06 true resid
norm 8.370811507176e+08 ||Ae||/||Ax|| 8.370811507176e+08
   102 KSP preconditioned resid norm 5.774689532168e-01 true resid norm
5.774689532168e-01 ||Ae||/||Ax|| 8.691616376521e-01
         0 KSP preconditioned resid norm 1.222577866385e+02 true resid
norm 1.420473159311e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.344428508248e-11 true resid
norm 2.158060760638e-12 ||Ae||/||Ax|| 1.519254866938e-12
       0 KSP preconditioned resid norm 1.817007589865e+02 true resid
norm 2.058936356161e+04 ||Ae||/||Ax|| 2.058936356161e+04
         0 KSP preconditioned resid norm 2.369595886156e+06 true resid
norm 2.848701428949e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.649654983221e-07 true resid
norm 5.187838733359e-08 ||Ae||/||Ax|| 1.821124067493e-12
       0 KSP preconditioned resid norm 3.523006001226e+06 true resid
norm 4.718192712223e+08 ||Ae||/||Ax|| 4.718192712223e+08
   103 KSP preconditioned resid norm 5.763526267619e-01 true resid norm
5.763526267619e-01 ||Ae||/||Ax|| 8.674814293494e-01
         0 KSP preconditioned resid norm 1.697136665891e+01 true resid
norm 1.955324008574e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.305659692046e-12 true resid
norm 5.152032928709e-13 ||Ae||/||Ax|| 2.634874274604e-13
       0 KSP preconditioned resid norm 2.585789437966e+01 true resid
norm 4.260004083289e+03 ||Ae||/||Ax|| 4.260004083289e+03
       1 KSP preconditioned resid norm 3.042227338085e+00 true resid
norm 2.437924699318e+02 ||Ae||/||Ax|| 2.437924699318e+02
         0 KSP preconditioned resid norm 1.786172665561e+04 true resid
norm 3.672203942080e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.117674500496e-09 true resid
norm 2.927523198325e-10 ||Ae||/||Ax|| 7.972114960115e-13
       0 KSP preconditioned resid norm 2.668032793746e+04 true resid
norm 2.836190692441e+06 ||Ae||/||Ax|| 2.836190692441e+06
   104 KSP preconditioned resid norm 5.751140756815e-01 true resid norm
5.751140756815e-01 ||Ae||/||Ax|| 8.656172579868e-01
         0 KSP preconditioned resid norm 4.178662399122e+01 true resid
norm 1.904158424088e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 4.352669269920e-12 true resid
norm 9.152708855467e-13 ||Ae||/||Ax|| 4.806695041591e-13
       0 KSP preconditioned resid norm 6.271220970509e+01 true resid
norm 7.352924591664e+03 ||Ae||/||Ax|| 7.352924591664e+03
         0 KSP preconditioned resid norm 7.968922992108e+05 true resid
norm 1.065682553344e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 8.404499849571e-08 true resid
norm 1.479317097437e-08 ||Ae||/||Ax|| 1.388140485921e-12
       0 KSP preconditioned resid norm 1.183939233126e+06 true resid
norm 1.477007546814e+08 ||Ae||/||Ax|| 1.477007546814e+08
   105 KSP preconditioned resid norm 5.749561994761e-01 true resid norm
5.749561994761e-01 ||Ae||/||Ax|| 8.653796349242e-01
         0 KSP preconditioned resid norm 9.629549323088e+01 true resid
norm 1.451840154351e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.074371741787e-11 true resid
norm 2.619883717379e-12 ||Ae||/||Ax|| 1.804526283095e-12
       0 KSP preconditioned resid norm 1.429556151408e+02 true resid
norm 2.380182751776e+04 ||Ae||/||Ax|| 2.380182751776e+04
         0 KSP preconditioned resid norm 1.870052902184e+06 true resid
norm 3.283587561260e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 2.042873448645e-07 true resid
norm 7.432012031120e-08 ||Ae||/||Ax|| 2.263381710542e-12
       0 KSP preconditioned resid norm 2.780763673784e+06 true resid
norm 6.511750937577e+08 ||Ae||/||Ax|| 6.511750937577e+08
   106 KSP preconditioned resid norm 5.748966047003e-01 true resid norm
5.748966047003e-01 ||Ae||/||Ax|| 8.652899374735e-01
         0 KSP preconditioned resid norm 8.306424730183e+01 true resid
norm 1.405049149366e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 7.962670663381e-12 true resid
norm 2.842302835209e-12 ||Ae||/||Ax|| 2.022920576474e-12
       0 KSP preconditioned resid norm 1.234427131551e+02 true resid
norm 2.643728907119e+04 ||Ae||/||Ax|| 2.643728907119e+04
         0 KSP preconditioned resid norm 1.617784243922e+06 true resid
norm 3.642368999034e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.864935874265e-07 true resid
norm 8.452353792722e-08 ||Ae||/||Ax|| 2.320564938633e-12
       0 KSP preconditioned resid norm 2.410992663918e+06 true resid
norm 7.598164966855e+08 ||Ae||/||Ax|| 7.598164966855e+08
   107 KSP preconditioned resid norm 5.742602293381e-01 true resid norm
5.742602293380e-01 ||Ae||/||Ax|| 8.643321144617e-01
         0 KSP preconditioned resid norm 1.676038567028e+01 true resid
norm 1.791468385419e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.962647878255e-12 true resid
norm 6.853297459495e-13 ||Ae||/||Ax|| 3.825519621375e-13
       0 KSP preconditioned resid norm 2.532885709747e+01 true resid
norm 5.454466483346e+03 ||Ae||/||Ax|| 5.454466483346e+03
       1 KSP preconditioned resid norm 3.229688487480e+00 true resid
norm 3.267906245437e+02 ||Ae||/||Ax|| 3.267906245437e+02
         0 KSP preconditioned resid norm 1.843164949732e+04 true resid
norm 4.218893826926e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.468796375580e-09 true resid
norm 4.208772922021e-10 ||Ae||/||Ax|| 9.976010524747e-13
       0 KSP preconditioned resid norm 2.745803820367e+04 true resid
norm 3.939322544201e+06 ||Ae||/||Ax|| 3.939322544201e+06
   108 KSP preconditioned resid norm 5.739811873555e-01 true resid norm
5.739811873555e-01 ||Ae||/||Ax|| 8.639121220359e-01
         0 KSP preconditioned resid norm 3.808636715213e+01 true resid
norm 1.781146119626e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 5.250981783333e-12 true resid
norm 9.707995399207e-13 ||Ae||/||Ax|| 5.450420542278e-13
       0 KSP preconditioned resid norm 5.732830282847e+01 true resid
norm 8.318751076374e+03 ||Ae||/||Ax|| 8.318751076374e+03
       1 KSP preconditioned resid norm 6.350839005809e+00 true resid
norm 4.337752163776e+02 ||Ae||/||Ax|| 4.337752163776e+02
         0 KSP preconditioned resid norm 3.460910136920e+04 true resid
norm 5.622099019164e+02 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 3.147780388064e-09 true resid
norm 9.213377499091e-10 ||Ae||/||Ax|| 1.638778944961e-12
       0 KSP preconditioned resid norm 5.148608005798e+04 true resid
norm 8.314771885136e+06 ||Ae||/||Ax|| 8.314771885136e+06
   109 KSP preconditioned resid norm 5.739472011349e-01 true resid norm
5.739472011349e-01 ||Ae||/||Ax|| 8.638609686033e-01
         0 KSP preconditioned resid norm 7.237935221900e+01 true resid
norm 1.429408161357e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 7.128641055025e-12 true resid
norm 2.862624540144e-12 ||Ae||/||Ax|| 2.002664191749e-12
       0 KSP preconditioned resid norm 1.075650813158e+02 true resid
norm 2.636274829393e+04 ||Ae||/||Ax|| 2.636274829393e+04
         0 KSP preconditioned resid norm 1.411126440713e+06 true resid
norm 3.632049357939e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.769173357385e-07 true resid
norm 8.417464772249e-08 ||Ae||/||Ax|| 2.317552418127e-12
       0 KSP preconditioned resid norm 2.101840499421e+06 true resid
norm 7.697095423823e+08 ||Ae||/||Ax|| 7.697095423823e+08
   110 KSP preconditioned resid norm 5.739335924829e-01 true resid norm
5.739335924829e-01 ||Ae||/||Ax|| 8.638404859121e-01
         0 KSP preconditioned resid norm 1.062282481225e+02 true resid
norm 1.402026143656e+00 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 8.851539111518e-12 true resid
norm 2.527921035453e-12 ||Ae||/||Ax|| 1.803048428799e-12
       0 KSP preconditioned resid norm 1.575377524634e+02 true resid
norm 2.367845612632e+04 ||Ae||/||Ax|| 2.367845612632e+04
         0 KSP preconditioned resid norm 2.061767162809e+06 true resid
norm 3.267618142454e+04 ||Ae||/||Ax|| 1.000000000000e+00
         1 KSP preconditioned resid norm 1.860389500586e-07 true resid
norm 6.799701708474e-08 ||Ae||/||Ax|| 2.080935229282e-12
       0 KSP preconditioned resid norm 3.058445347287e+06 true resid
norm 6.285663338975e+08 ||Ae||/||Ax|| 6.285663338975e+08
Thanks again,
Hal
Barry Smith wrote:
>   No, I want it on the nonworking two-level case. Isn't that your goal
> to do multigrid? If one level is working and you are happy with it then
> why send the email?
>    Barry
> On Aug 26, 2009, at 3:45 PM, Hal Finkel wrote:
>> Barry,
>> Here is the output with those options in the (working) 1-level case on
>> 1 cpu. Is that what you wanted?
>>  0 SNES Function norm 6.643976542462e-01
>>    0 KSP preconditioned resid norm 6.643976542462e-01 true resid norm
>> 6.643976542462e-01 ||Ae||/||Ax|| 1.000000000000e+00
>>      0 KSP preconditioned resid norm 1.438911631652e-03 true resid
>> norm 1.000000000000e+00 ||Ae||/||Ax|| 1.000000000000e+00
>>      1 KSP preconditioned resid norm 5.141505633982e-04 true resid
>> norm 1.970012522193e-01 ||Ae||/||Ax|| 1.970012522193e-01
>>    1 KSP preconditioned resid norm 4.790430472989e-02 true resid norm
>> 4.790430472989e-02 ||Ae||/||Ax|| 7.210185710881e-02
>>      0 KSP preconditioned resid norm 8.314136308720e-03 true resid
>>      1 KSP preconditioned resid norm 4.510029589596e-03 true resid
>> norm 5.934134865465e-01 ||Ae||/||Ax|| 5.934134865465e-01
>>    2 KSP preconditioned resid norm 8.487458086567e-03 true resid norm
>> 8.487458086567e-03 ||Ae||/||Ax|| 1.277466594339e-02
>>      0 KSP preconditioned resid norm 6.119493660032e-02 true resid
>>      1 KSP preconditioned resid norm 2.236002849750e-02 true resid
>> norm 7.814908146189e-01 ||Ae||/||Ax|| 7.814908146189e-01
>>    3 KSP preconditioned resid norm 5.965466932886e-03 true resid norm
>> 5.965466932886e-03 ||Ae||/||Ax|| 8.978759775506e-03
>>      0 KSP preconditioned resid norm 1.765708232662e-01 true resid
>>      1 KSP preconditioned resid norm 2.422901024605e-02 true resid
>> norm 6.919985015683e-01 ||Ae||/||Ax|| 6.919985015683e-01
>>    4 KSP preconditioned resid norm 4.622977909431e-03 true resid norm
>> 4.622977909431e-03 ||Ae||/||Ax|| 6.958149054087e-03
>>      0 KSP preconditioned resid norm 8.428635776507e-01 true resid
>>      1 KSP preconditioned resid norm 1.071459298111e-02 true resid
>> norm 4.423943234439e-01 ||Ae||/||Ax|| 4.423943234439e-01
>>    5 KSP preconditioned resid norm 2.949006884559e-03 true resid norm
>> 2.949006884560e-03 ||Ae||/||Ax|| 4.438617243322e-03
>>      0 KSP preconditioned resid norm 4.221520918573e-01 true resid
>>      1 KSP preconditioned resid norm 1.795668593850e-02 true resid
>> norm 8.064343336541e-01 ||Ae||/||Ax|| 8.064343336541e-01
>>    6 KSP preconditioned resid norm 1.327402359192e-03 true resid norm
>> 1.327402359192e-03 ||Ae||/||Ax|| 1.997903440370e-03
>>      0 KSP preconditioned resid norm 3.239330680409e-02 true resid
>>      1 KSP preconditioned resid norm 1.103583195381e-02 true resid
>> norm 5.910503837805e-01 ||Ae||/||Ax|| 5.910503837805e-01
>>    7 KSP preconditioned resid norm 5.579319891254e-04 true resid norm
>> 5.579319891255e-04 ||Ae||/||Ax|| 8.397561092512e-04
>>      0 KSP preconditioned resid norm 2.166256693843e-01 true resid
>>      1 KSP preconditioned resid norm 2.527142494434e-02 true resid
>> norm 3.938455942305e-01 ||Ae||/||Ax|| 3.938455942305e-01
>>    8 KSP preconditioned resid norm 1.841437265702e-04 true resid norm
>> 1.841437265703e-04 ||Ae||/||Ax|| 2.771589053535e-04
>>      0 KSP preconditioned resid norm 1.097958713832e-01 true resid
>>      1 KSP preconditioned resid norm 4.070826208815e-02 true resid
>> norm 5.960016421595e-01 ||Ae||/||Ax|| 5.960016421595e-01
>>    9 KSP preconditioned resid norm 6.545738966234e-05 true resid norm
>> 6.545738966232e-05 ||Ae||/||Ax|| 9.852140392726e-05
>>      0 KSP preconditioned resid norm 9.668719808206e-02 true resid
>>      1 KSP preconditioned resid norm 7.944112488019e-02 true resid
>> norm 7.461779305230e-01 ||Ae||/||Ax|| 7.461779305230e-01
>>   10 KSP preconditioned resid norm 4.125461342831e-05 true resid norm
>> 4.125461342821e-05 ||Ae||/||Ax|| 6.209325569492e-05
>>      0 KSP preconditioned resid norm 3.008151203349e-01 true resid
>>      1 KSP preconditioned resid norm 7.247738676584e-02 true resid
>> norm 7.832960673267e-01 ||Ae||/||Ax|| 7.832960673267e-01
>>   11 KSP preconditioned resid norm 3.280778128691e-05 true resid norm
>> 3.280778128689e-05 ||Ae||/||Ax|| 4.937973678446e-05
>>      0 KSP preconditioned resid norm 9.091470733399e-01 true resid
>>      1 KSP preconditioned resid norm 1.215403990109e-01 true resid
>> norm 7.059207029764e-01 ||Ae||/||Ax|| 7.059207029764e-01
>>   12 KSP preconditioned resid norm 2.968550831459e-05 true resid norm
>> 2.968550831435e-05 ||Ae||/||Ax|| 4.468033281669e-05
>>      0 KSP preconditioned resid norm 1.024246289230e+00 true resid
>>      1 KSP preconditioned resid norm 9.302673603327e-02 true resid
>> norm 5.985130004903e-01 ||Ae||/||Ax|| 5.985130004903e-01
>>   13 KSP preconditioned resid norm 2.521514028222e-05 true resid norm
>> 2.521514028196e-05 ||Ae||/||Ax|| 3.795188035479e-05
>>      0 KSP preconditioned resid norm 5.990912160630e-01 true resid
>>      1 KSP preconditioned resid norm 9.781990197263e-02 true resid
>> norm 5.480521896855e-01 ||Ae||/||Ax|| 5.480521896855e-01
>>   14 KSP preconditioned resid norm 1.978375072845e-05 true resid norm
>> 1.978375072804e-05 ||Ae||/||Ax|| 2.977697257298e-05
>>      0 KSP preconditioned resid norm 1.008331187053e+00 true resid
>>      1 KSP preconditioned resid norm 2.294954965258e-01 true resid
>> norm 6.339103426898e-01 ||Ae||/||Ax|| 6.339103426898e-01
>>   15 KSP preconditioned resid norm 1.488645974384e-05 true resid norm
>> 1.488645974344e-05 ||Ae||/||Ax|| 2.240594867893e-05
>>      0 KSP preconditioned resid norm 1.849227047229e+00 true resid
>>      1 KSP preconditioned resid norm 2.919984907088e-01 true resid
>> norm 5.183188121423e-01 ||Ae||/||Ax|| 5.183188121423e-01
>>   16 KSP preconditioned resid norm 7.094849419546e-06 true resid norm
>> 7.094849419588e-06 ||Ae||/||Ax|| 1.067861900813e-05
>>      0 KSP preconditioned resid norm 1.388766130430e+00 true resid
>>      1 KSP preconditioned resid norm 3.878119571370e-01 true resid
>> norm 7.032718519224e-01 ||Ae||/||Ax|| 7.032718519224e-01
>>   17 KSP preconditioned resid norm 4.097305136804e-06 true resid norm
>> 4.097305136552e-06 ||Ae||/||Ax|| 6.166947023919e-06
>>  1 SNES Function norm 5.850920566283e-06
>>    0 KSP preconditioned resid norm 5.850920566283e-06 true resid norm
>> 5.850920566283e-06 ||Ae||/||Ax|| 1.000000000000e+00
>>      0 KSP preconditioned resid norm 8.276021960717e-01 true resid
>>      1 KSP preconditioned resid norm 3.809774037292e-01 true resid
>> norm 7.868108837109e-01 ||Ae||/||Ax|| 7.868108837109e-01
>>    1 KSP preconditioned resid norm 3.947856942305e-06 true resid norm
>> 3.947856942305e-06 ||Ae||/||Ax|| 6.747411621096e-01
>>      0 KSP preconditioned resid norm 2.497905632896e+00 true resid
>>      1 KSP preconditioned resid norm 5.608088417629e-01 true resid
>> norm 8.391706412367e-01 ||Ae||/||Ax|| 8.391706412367e-01
>>    2 KSP preconditioned resid norm 3.305771768709e-06 true resid norm
>> 3.305771768709e-06 ||Ae||/||Ax|| 5.650002817948e-01
>>      0 KSP preconditioned resid norm 7.301425383804e-01 true resid
>>      1 KSP preconditioned resid norm 3.476223530528e-01 true resid
>> norm 5.563009832684e-01 ||Ae||/||Ax|| 5.563009832684e-01
>>    3 KSP preconditioned resid norm 3.007329187251e-06 true resid norm
>> 3.007329187251e-06 ||Ae||/||Ax|| 5.139924825815e-01
>>      0 KSP preconditioned resid norm 2.880397337024e+00 true resid
>>      1 KSP preconditioned resid norm 4.471977831965e-01 true resid
>> norm 7.798621978217e-01 ||Ae||/||Ax|| 7.798621978217e-01
>>    4 KSP preconditioned resid norm 3.001204159469e-06 true resid norm
>> 3.001204159469e-06 ||Ae||/||Ax|| 5.129456340194e-01
>>      0 KSP preconditioned resid norm 4.619989941290e+00 true resid
>>      1 KSP preconditioned resid norm 3.243648576810e-01 true resid
>> norm 1.108094778155e+00 ||Ae||/||Ax|| 1.108094778155e+00
>>    5 KSP preconditioned resid norm 3.001115709599e-06 true resid norm
>> 3.001115709599e-06 ||Ae||/||Ax|| 5.129305167624e-01
>>      0 KSP preconditioned resid norm 4.829994865746e+00 true resid
>>      1 KSP preconditioned resid norm 4.325734548745e-01 true resid
>> norm 1.088867367033e+00 ||Ae||/||Ax|| 1.088867367033e+00
>>    6 KSP preconditioned resid norm 2.974277803753e-06 true resid norm
>> 2.974277803753e-06 ||Ae||/||Ax|| 5.083435623606e-01
>>      0 KSP preconditioned resid norm 1.381129102428e+00 true resid
>>      1 KSP preconditioned resid norm 3.098881160663e-01 true resid
>> norm 6.431427158439e-01 ||Ae||/||Ax|| 6.431427158439e-01
>>    7 KSP preconditioned resid norm 2.816838388951e-06 true resid norm
>> 2.816838388951e-06 ||Ae||/||Ax|| 4.814350762483e-01
>>      0 KSP preconditioned resid norm 1.559573417426e+00 true resid
>>      1 KSP preconditioned resid norm 2.532723445272e-01 true resid
>> norm 8.138557633078e-01 ||Ae||/||Ax|| 8.138557633078e-01
>>    8 KSP preconditioned resid norm 2.572324455447e-06 true resid norm
>> 2.572324455447e-06 ||Ae||/||Ax|| 4.396443989123e-01
>>      0 KSP preconditioned resid norm 5.946831260059e+00 true resid
>>      1 KSP preconditioned resid norm 3.929968207615e-01 true resid
>> norm 1.354756640752e+00 ||Ae||/||Ax|| 1.354756640752e+00
>>    9 KSP preconditioned resid norm 2.177455315353e-06 true resid norm
>> 2.177455315353e-06 ||Ae||/||Ax|| 3.721560206954e-01
>>      0 KSP preconditioned resid norm 5.315723299063e+00 true resid
>>      1 KSP preconditioned resid norm 3.628504511585e-01 true resid
>> norm 1.244733734536e+00 ||Ae||/||Ax|| 1.244733734536e+00
>>   10 KSP preconditioned resid norm 1.409067985559e-06 true resid norm
>> 1.409067985559e-06 ||Ae||/||Ax|| 2.408284251334e-01
>>      0 KSP preconditioned resid norm 1.522258580690e+00 true resid
>>      1 KSP preconditioned resid norm 2.414238177111e-01 true resid
>> norm 8.091416034904e-01 ||Ae||/||Ax|| 8.091416034904e-01
>>   11 KSP preconditioned resid norm 1.001503517728e-06 true resid norm
>> 1.001503517728e-06 ||Ae||/||Ax|| 1.711702468667e-01
>>      0 KSP preconditioned resid norm 8.244553153983e-01 true resid
>>      1 KSP preconditioned resid norm 2.244218748685e-01 true resid
>> norm 6.292257324755e-01 ||Ae||/||Ax|| 6.292257324755e-01
>>   12 KSP preconditioned resid norm 7.556215980081e-07 true resid norm
>> 7.556215980082e-07 ||Ae||/||Ax|| 1.291457625254e-01
>>      0 KSP preconditioned resid norm 1.857974243745e+00 true resid
>>      1 KSP preconditioned resid norm 3.451523414794e-01 true resid
>> norm 6.449941313821e-01 ||Ae||/||Ax|| 6.449941313821e-01
>>   13 KSP preconditioned resid norm 5.872140840954e-07 true resid norm
>> 5.872140840955e-07 ||Ae||/||Ax|| 1.003626826656e-01
>>      0 KSP preconditioned resid norm 2.611648570586e+00 true resid
>>      1 KSP preconditioned resid norm 2.740043981340e-01 true resid
>> norm 6.369784579675e-01 ||Ae||/||Ax|| 6.369784579675e-01
>>   14 KSP preconditioned resid norm 4.352350316840e-07 true resid norm
>> 4.352350316841e-07 ||Ae||/||Ax|| 7.438744497613e-02
>>      0 KSP preconditioned resid norm 2.003016340281e+00 true resid
>>      1 KSP preconditioned resid norm 4.073409352245e-01 true resid
>> norm 6.562979155542e-01 ||Ae||/||Ax|| 6.562979155542e-01
>>   15 KSP preconditioned resid norm 3.052867274622e-07 true resid norm
>> 3.052867274624e-07 ||Ae||/||Ax|| 5.217755462648e-02
>>      0 KSP preconditioned resid norm 1.286639096168e+00 true resid
>>      1 KSP preconditioned resid norm 3.656621503377e-01 true resid
>> norm 6.308753365212e-01 ||Ae||/||Ax|| 6.308753365212e-01
>>   16 KSP preconditioned resid norm 1.955997188783e-07 true resid norm
>> 1.955997188782e-07 ||Ae||/||Ax|| 3.343058868468e-02
>>      0 KSP preconditioned resid norm 1.335903581256e+00 true resid
>>      1 KSP preconditioned resid norm 3.001895431683e-01 true resid
>> norm 6.789558143016e-01 ||Ae||/||Ax|| 6.789558143016e-01
>>   17 KSP preconditioned resid norm 1.567782688997e-07 true resid norm
>> 1.567782688996e-07 ||Ae||/||Ax|| 2.679548750039e-02
>>      0 KSP preconditioned resid norm 1.651696143482e+00 true resid
>>      1 KSP preconditioned resid norm 2.713972348795e-01 true resid
>> norm 5.033537683058e-01 ||Ae||/||Ax|| 5.033537683058e-01
>>   18 KSP preconditioned resid norm 1.010718356377e-07 true resid norm
>> 1.010718356378e-07 ||Ae||/||Ax|| 1.727451851256e-02
>>      0 KSP preconditioned resid norm 1.011081720758e+00 true resid
>>      1 KSP preconditioned resid norm 5.527570671391e-01 true resid
>> norm 7.947330071383e-01 ||Ae||/||Ax|| 7.947330071383e-01
>>   19 KSP preconditioned resid norm 8.997938714701e-08 true resid norm
>> 8.997938714709e-08 ||Ae||/||Ax|| 1.537867180519e-02
>>      0 KSP preconditioned resid norm 1.537108246495e+00 true resid
>>      1 KSP preconditioned resid norm 4.298772065070e-01 true resid
>> norm 5.876338587223e-01 ||Ae||/||Ax|| 5.876338587223e-01
>>   20 KSP preconditioned resid norm 8.711914509357e-08 true resid norm
>> 8.711914509361e-08 ||Ae||/||Ax|| 1.488981846646e-02
>>      0 KSP preconditioned resid norm 1.923097362850e+00 true resid
>>      1 KSP preconditioned resid norm 3.075948671586e-01 true resid
>> norm 4.631591237704e-01 ||Ae||/||Ax|| 4.631591237704e-01
>>   21 KSP preconditioned resid norm 8.323067409578e-08 true resid norm
>> 8.323067409577e-08 ||Ae||/||Ax|| 1.422522715065e-02
>>      0 KSP preconditioned resid norm 9.819276869885e-01 true resid
>>      1 KSP preconditioned resid norm 4.279383354509e-01 true resid
>> norm 6.842834730228e-01 ||Ae||/||Ax|| 6.842834730228e-01
>>   22 KSP preconditioned resid norm 7.909034553981e-08 true resid norm
>> 7.909034553913e-08 ||Ae||/||Ax|| 1.351759003445e-02
>>      0 KSP preconditioned resid norm 9.582482498733e-01 true resid
>>      1 KSP preconditioned resid norm 4.872542232901e-01 true resid
>> norm 6.520743487433e-01 ||Ae||/||Ax|| 6.520743487433e-01
>>   23 KSP preconditioned resid norm 7.583943619887e-08 true resid norm
>> 7.583943619831e-08 ||Ae||/||Ax|| 1.296196646992e-02
>>      0 KSP preconditioned resid norm 1.129055084162e+00 true resid
>>      1 KSP preconditioned resid norm 3.940290407027e-01 true resid
>> norm 5.533623127492e-01 ||Ae||/||Ax|| 5.533623127492e-01
>>   24 KSP preconditioned resid norm 7.198974227007e-08 true resid norm
>> 7.198974226927e-08 ||Ae||/||Ax|| 1.230400266996e-02
>>      0 KSP preconditioned resid norm 7.922461164088e-01 true resid
>>      1 KSP preconditioned resid norm 3.568631157402e-01 true resid
>> norm 6.784746707201e-01 ||Ae||/||Ax|| 6.784746707201e-01
>>   25 KSP preconditioned resid norm 6.969681693595e-08 true resid norm
>> 6.969681693509e-08 ||Ae||/||Ax|| 1.191211129010e-02
>>      0 KSP preconditioned resid norm 8.506106408028e-01 true resid
>>      1 KSP preconditioned resid norm 2.674832821714e-01 true resid
>> norm 5.592992824796e-01 ||Ae||/||Ax|| 5.592992824796e-01
>>   26 KSP preconditioned resid norm 6.713093474885e-08 true resid norm
>> 6.713093474791e-08 ||Ae||/||Ax|| 1.147356796036e-02
>>      0 KSP preconditioned resid norm 7.107668950850e-01 true resid
>>      1 KSP preconditioned resid norm 3.080542740675e-01 true resid
>> norm 6.120847770454e-01 ||Ae||/||Ax|| 6.120847770454e-01
>>   27 KSP preconditioned resid norm 6.316951623357e-08 true resid norm
>> 6.316951623251e-08 ||Ae||/||Ax|| 1.079650894537e-02
>>      0 KSP preconditioned resid norm 9.816834307897e-01 true resid
>>      1 KSP preconditioned resid norm 3.035636714372e-01 true resid
>> norm 5.561308623772e-01 ||Ae||/||Ax|| 5.561308623772e-01
>>   28 KSP preconditioned resid norm 5.685161562141e-08 true resid norm
>> 5.685161562024e-08 ||Ae||/||Ax|| 9.716695856008e-03
>>      0 KSP preconditioned resid norm 1.017862349675e+00 true resid
>>      1 KSP preconditioned resid norm 3.438638918414e-01 true resid
>> norm 6.483000200066e-01 ||Ae||/||Ax|| 6.483000200066e-01
>>   29 KSP preconditioned resid norm 5.170566864610e-08 true resid norm
>> 5.170566864501e-08 ||Ae||/||Ax|| 8.837185201757e-03
>>      0 KSP preconditioned resid norm 8.897697988733e-01 true resid
>>      1 KSP preconditioned resid norm 3.213181899588e-01 true resid
>> norm 6.348471232738e-01 ||Ae||/||Ax|| 6.348471232738e-01
>>   30 KSP preconditioned resid norm 4.885061460285e-08 true resid norm
>> 4.885061460285e-08 ||Ae||/||Ax|| 8.349218563034e-03
>>      0 KSP preconditioned resid norm 7.100457326024e-01 true resid
>>      1 KSP preconditioned resid norm 6.955812925302e-01 true resid
>> norm 9.726932992087e-01 ||Ae||/||Ax|| 9.726932992087e-01
>>   31 KSP preconditioned resid norm 4.725291213013e-08 true resid norm
>> 4.725291213007e-08 ||Ae||/||Ax|| 8.076149999775e-03
>>      0 KSP preconditioned resid norm 4.185203199010e-01 true resid
>>      1 KSP preconditioned resid norm 2.196403938530e-01 true resid
>> norm 4.016140042970e-01 ||Ae||/||Ax|| 4.016140042970e-01
>>   32 KSP preconditioned resid norm 4.547823851359e-08 true resid norm
>> 4.547823851362e-08 ||Ae||/||Ax|| 7.772834718641e-03
>>      0 KSP preconditioned resid norm 6.581109982585e-01 true resid
>>      1 KSP preconditioned resid norm 3.128181724937e-01 true resid
>> norm 7.298286188824e-01 ||Ae||/||Ax|| 7.298286188824e-01
>>   33 KSP preconditioned resid norm 4.468618222477e-08 true resid norm
>> 4.468618222483e-08 ||Ae||/||Ax|| 7.637461783764e-03
>>      0 KSP preconditioned resid norm 8.120341282592e-01 true resid
>>      1 KSP preconditioned resid norm 2.218250119940e-01 true resid
>> norm 4.572201876132e-01 ||Ae||/||Ax|| 4.572201876132e-01
>>   34 KSP preconditioned resid norm 4.314354409778e-08 true resid norm
>> 4.314354409782e-08 ||Ae||/||Ax|| 7.373804448217e-03
>>      0 KSP preconditioned resid norm 5.778947005677e-01 true resid
>>      1 KSP preconditioned resid norm 3.877938034235e-01 true resid
>> norm 6.868568173397e-01 ||Ae||/||Ax|| 6.868568173397e-01
>>   35 KSP preconditioned resid norm 4.111383309670e-08 true resid norm
>> 4.111383309672e-08 ||Ae||/||Ax|| 7.026899892239e-03
>>      0 KSP preconditioned resid norm 7.589832929724e-01 true resid
>>      1 KSP preconditioned resid norm 2.735429451288e-01 true resid
>> norm 6.133540321550e-01 ||Ae||/||Ax|| 6.133540321550e-01
>>   36 KSP preconditioned resid norm 3.896413302095e-08 true resid norm
>> 3.896413302095e-08 ||Ae||/||Ax|| 6.659487610460e-03
>>      0 KSP preconditioned resid norm 9.173185113175e-01 true resid
>>      1 KSP preconditioned resid norm 3.052187383165e-01 true resid
>> norm 6.655288549919e-01 ||Ae||/||Ax|| 6.655288549919e-01
>>   37 KSP preconditioned resid norm 3.770537943429e-08 true resid norm
>> 3.770537943431e-08 ||Ae||/||Ax|| 6.444349911635e-03
>>      0 KSP preconditioned resid norm 1.137492649970e+00 true resid
>>      1 KSP preconditioned resid norm 3.044329763751e-01 true resid
>> norm 6.147370239994e-01 ||Ae||/||Ax|| 6.147370239994e-01
>>   38 KSP preconditioned resid norm 3.694716763304e-08 true resid norm
>> 3.694716763306e-08 ||Ae||/||Ax|| 6.314761448988e-03
>>      0 KSP preconditioned resid norm 1.223189932062e+00 true resid
>>      1 KSP preconditioned resid norm 2.107514686273e-01 true resid
>> norm 5.789372321326e-01 ||Ae||/||Ax|| 5.789372321326e-01
>>   39 KSP preconditioned resid norm 3.634742486594e-08 true resid norm
>> 3.634742486593e-08 ||Ae||/||Ax|| 6.212257448064e-03
>>      0 KSP preconditioned resid norm 1.192363148419e+00 true resid
>>      1 KSP preconditioned resid norm 2.860271918718e-01 true resid
>> norm 5.850260965540e-01 ||Ae||/||Ax|| 5.850260965540e-01
>>   40 KSP preconditioned resid norm 3.561782722372e-08 true resid norm
>> 3.561782722374e-08 ||Ae||/||Ax|| 6.087559525075e-03
>>      0 KSP preconditioned resid norm 8.881324685300e-01 true resid
>>      1 KSP preconditioned resid norm 2.642271412468e-01 true resid
>> norm 6.637278122540e-01 ||Ae||/||Ax|| 6.637278122540e-01
>>   41 KSP preconditioned resid norm 3.506823410956e-08 true resid norm
>> 3.506823410956e-08 ||Ae||/||Ax|| 5.993626765614e-03
>>      0 KSP preconditioned resid norm 9.513827527161e-01 true resid
>>      1 KSP preconditioned resid norm 2.263980500382e-01 true resid
>> norm 6.267230897905e-01 ||Ae||/||Ax|| 6.267230897905e-01
>>   42 KSP preconditioned resid norm 3.466236527477e-08 true resid norm
>> 3.466236527477e-08 ||Ae||/||Ax|| 5.924258393546e-03
>>      0 KSP preconditioned resid norm 1.407625976444e+00 true resid
>>      1 KSP preconditioned resid norm 1.841824427477e-01 true resid
>> norm 5.311814594204e-01 ||Ae||/||Ax|| 5.311814594204e-01
>>   43 KSP preconditioned resid norm 3.394294635279e-08 true resid norm
>> 3.394294635284e-08 ||Ae||/||Ax|| 5.801300148978e-03
>>      0 KSP preconditioned resid norm 1.536263909707e+00 true resid
>>      1 KSP preconditioned resid norm 2.972519671057e-01 true resid
>> norm 5.927201357618e-01 ||Ae||/||Ax|| 5.927201357618e-01
>>   44 KSP preconditioned resid norm 3.248296724023e-08 true resid norm
>> 3.248296724025e-08 ||Ae||/||Ax|| 5.551770336352e-03
>>      0 KSP preconditioned resid norm 1.783804105384e+00 true resid
>>      1 KSP preconditioned resid norm 3.722881763352e-01 true resid
>> norm 5.786098812309e-01 ||Ae||/||Ax|| 5.786098812309e-01
>>   45 KSP preconditioned resid norm 2.950320556254e-08 true resid norm
>> 2.950320556258e-08 ||Ae||/||Ax|| 5.042489507138e-03
>>      0 KSP preconditioned resid norm 2.201496546447e+00 true resid
>>      1 KSP preconditioned resid norm 4.087649817784e-01 true resid
>> norm 5.074174843604e-01 ||Ae||/||Ax|| 5.074174843604e-01
>>   46 KSP preconditioned resid norm 2.319584580786e-08 true resid norm
>> 2.319584580791e-08 ||Ae||/||Ax|| 3.964477990280e-03
>>      0 KSP preconditioned resid norm 1.736355434315e+00 true resid
>>      1 KSP preconditioned resid norm 6.867386399797e-01 true resid
>> norm 7.098722583695e-01 ||Ae||/||Ax|| 7.098722583695e-01
>>   47 KSP preconditioned resid norm 2.008430277340e-08 true resid norm
>> 2.008430277343e-08 ||Ae||/||Ax|| 3.432673977693e-03
>>      0 KSP preconditioned resid norm 1.488127968937e+00 true resid
>>      1 KSP preconditioned resid norm 5.516786708506e-01 true resid
>> norm 6.355423307226e-01 ||Ae||/||Ax|| 6.355423307226e-01
>>   48 KSP preconditioned resid norm 1.854206408497e-08 true resid norm
>> 1.854206408497e-08 ||Ae||/||Ax|| 3.169084911497e-03
>>      0 KSP preconditioned resid norm 1.380328436388e+00 true resid
>>      1 KSP preconditioned resid norm 4.575661767087e-01 true resid
>> norm 6.487066138646e-01 ||Ae||/||Ax|| 6.487066138646e-01
>>   49 KSP preconditioned resid norm 1.665547510085e-08 true resid norm
>> 1.665547510085e-08 ||Ae||/||Ax|| 2.846641808270e-03
>>      0 KSP preconditioned resid norm 2.313536103290e+00 true resid
>>      1 KSP preconditioned resid norm 5.305138630648e-01 true resid
>> norm 7.334968078908e-01 ||Ae||/||Ax|| 7.334968078908e-01
>>   50 KSP preconditioned resid norm 1.462283172240e-08 true resid norm
>> 1.462283172247e-08 ||Ae||/||Ax|| 2.499236070088e-03
>>      0 KSP preconditioned resid norm 3.213123410447e+00 true resid
>>      1 KSP preconditioned resid norm 5.224884980518e-01 true resid
>> norm 7.561756407001e-01 ||Ae||/||Ax|| 7.561756407001e-01
>>   51 KSP preconditioned resid norm 1.223657774649e-08 true resid norm
>> 1.223657774655e-08 ||Ae||/||Ax|| 2.091393586347e-03
>>      0 KSP preconditioned resid norm 2.023552916685e+00 true resid
>>      1 KSP preconditioned resid norm 5.574715128775e-01 true resid
>> norm 6.980817617824e-01 ||Ae||/||Ax|| 6.980817617824e-01
>>   52 KSP preconditioned resid norm 9.853979905043e-09 true resid norm
>> 9.853979905046e-09 ||Ae||/||Ax|| 1.684175984516e-03
>>      0 KSP preconditioned resid norm 1.170745734096e+00 true resid
>>      1 KSP preconditioned resid norm 4.134603323396e-01 true resid
>> norm 6.348912278346e-01 ||Ae||/||Ax|| 6.348912278346e-01
>>   53 KSP preconditioned resid norm 8.181596904133e-09 true resid norm
>> 8.181596904190e-09 ||Ae||/||Ax|| 1.398343527570e-03
>>      0 KSP preconditioned resid norm 2.385292955090e+00 true resid
>>      1 KSP preconditioned resid norm 5.286979495932e-01 true resid
>> norm 7.984208016570e-01 ||Ae||/||Ax|| 7.984208016570e-01
>>   54 KSP preconditioned resid norm 6.409203469073e-09 true resid norm
>> 6.409203469062e-09 ||Ae||/||Ax|| 1.095417959696e-03
>>      0 KSP preconditioned resid norm 5.707419973376e+00 true resid
>>      1 KSP preconditioned resid norm 6.431212555078e-01 true resid
>> norm 1.319769139913e+00 ||Ae||/||Ax|| 1.319769139913e+00
>>   55 KSP preconditioned resid norm 4.450638029919e-09 true resid norm
>> 4.450638029969e-09 ||Ae||/||Ax|| 7.606731247757e-04
>>      0 KSP preconditioned resid norm 7.199725849178e+00 true resid
>>      1 KSP preconditioned resid norm 8.820447922491e-01 true resid
>> norm 1.569220175230e+00 ||Ae||/||Ax|| 1.569220175230e+00
>>   56 KSP preconditioned resid norm 2.820717192827e-09 true resid norm
>> 2.820717192685e-09 ||Ae||/||Ax|| 4.820980153004e-04
>>      0 KSP preconditioned resid norm 3.954316557881e+00 true resid
>>      1 KSP preconditioned resid norm 1.174082394688e+00 true resid
>> norm 1.017969498279e+00 ||Ae||/||Ax|| 1.017969498279e+00
>>   57 KSP preconditioned resid norm 1.751635661806e-09 true resid norm
>> 1.751635661897e-09 ||Ae||/||Ax|| 2.993777888545e-04
>>      0 KSP preconditioned resid norm 1.876208896020e+00 true resid
>>      1 KSP preconditioned resid norm 1.566896137837e+00 true resid
>> norm 6.914905383075e-01 ||Ae||/||Ax|| 6.914905383075e-01
>>   58 KSP preconditioned resid norm 1.207891841472e-09 true resid norm
>> 1.207891841440e-09 ||Ae||/||Ax|| 2.064447513440e-04
>>      0 KSP preconditioned resid norm 2.297261201903e+00 true resid
>>      1 KSP preconditioned resid norm 1.961454513785e+00 true resid
>> norm 7.361082716350e-01 ||Ae||/||Ax|| 7.361082716350e-01
>>   59 KSP preconditioned resid norm 1.016539279879e-09 true resid norm
>> 1.016539279925e-09 ||Ae||/||Ax|| 1.737400582368e-04
>>      0 KSP preconditioned resid norm 3.254668263088e+00 true resid
>>      1 KSP preconditioned resid norm 1.640547979130e+00 true resid
>> norm 7.473445815641e-01 ||Ae||/||Ax|| 7.473445815641e-01
>>   60 KSP preconditioned resid norm 8.558459393246e-10 true resid norm
>> 8.558459393246e-10 ||Ae||/||Ax|| 1.462754330073e-04
>>      0 KSP preconditioned resid norm 3.699188433787e+00 true resid
>>      1 KSP preconditioned resid norm 3.641405579973e+00 true resid
>> norm 9.275791982055e-01 ||Ae||/||Ax|| 9.275791982055e-01
>>   61 KSP preconditioned resid norm 7.891395315495e-10 true resid norm
>> 7.891395315494e-10 ||Ae||/||Ax|| 1.348744223425e-04
>>      0 KSP preconditioned resid norm 2.675881805310e+00 true resid
>>      1 KSP preconditioned resid norm 1.453713947810e+00 true resid
>> norm 7.138367623914e-01 ||Ae||/||Ax|| 7.138367623914e-01
>>   62 KSP preconditioned resid norm 7.510552985484e-10 true resid norm
>> 7.510552985213e-10 ||Ae||/||Ax|| 1.283653213221e-04
>>      0 KSP preconditioned resid norm 1.338840353148e+00 true resid
>>      1 KSP preconditioned resid norm 1.146220467265e+00 true resid
>> norm 4.297177669038e-01 ||Ae||/||Ax|| 4.297177669038e-01
>>   63 KSP preconditioned resid norm 6.832740701908e-10 true resid norm
>> 6.832740702025e-10 ||Ae||/||Ax|| 1.167806095574e-04
>>      0 KSP preconditioned resid norm 2.478031412327e+00 true resid
>>      1 KSP preconditioned resid norm 1.547561676965e+00 true resid
>> norm 7.067319359604e-01 ||Ae||/||Ax|| 7.067319359604e-01
>>   64 KSP preconditioned resid norm 6.312416928849e-10 true resid norm
>> 6.312416928420e-10 ||Ae||/||Ax|| 1.078875854989e-04
>>      0 KSP preconditioned resid norm 2.510304348429e+00 true resid
>>      1 KSP preconditioned resid norm 1.470709935588e+00 true resid
>> norm 6.572137642951e-01 ||Ae||/||Ax|| 6.572137642951e-01
>>   65 KSP preconditioned resid norm 5.327354965414e-10 true resid norm
>> 5.327354965097e-10 ||Ae||/||Ax|| 9.105156880435e-05
>>      0 KSP preconditioned resid norm 2.476662569003e+00 true resid
>>      1 KSP preconditioned resid norm 2.310145576275e+00 true resid
>> norm 6.408918975397e-01 ||Ae||/||Ax|| 6.408918975397e-01
>>   66 KSP preconditioned resid norm 4.469580732178e-10 true resid norm
>> 4.469580732741e-10 ||Ae||/||Ax|| 7.639106841575e-05
>>      0 KSP preconditioned resid norm 3.243520644840e+00 true resid
>>      1 KSP preconditioned resid norm 2.732155047053e+00 true resid
>> norm 7.812059837441e-01 ||Ae||/||Ax|| 7.812059837441e-01
>>   67 KSP preconditioned resid norm 4.087445950732e-10 true resid norm
>> 4.087445950372e-10 ||Ae||/||Ax|| 6.985987767337e-05
>>      0 KSP preconditioned resid norm 4.570320195732e+00 true resid
>>      1 KSP preconditioned resid norm 2.087601985141e+00 true resid
>> norm 1.032266974836e+00 ||Ae||/||Ax|| 1.032266974836e+00
>>   68 KSP preconditioned resid norm 3.841153386650e-10 true resid norm
>> 3.841153386559e-10 ||Ae||/||Ax|| 6.565041078654e-05
>>      0 KSP preconditioned resid norm 5.718860667569e+00 true resid
>>      1 KSP preconditioned resid norm 1.709934079219e+00 true resid
>> norm 1.273174095131e+00 ||Ae||/||Ax|| 1.273174095131e+00
>>   69 KSP preconditioned resid norm 3.520264512665e-10 true resid norm
>> 3.520264512287e-10 ||Ae||/||Ax|| 6.016599392193e-05
>>      0 KSP preconditioned resid norm 4.537109521149e+00 true resid
>>      1 KSP preconditioned resid norm 1.937349360261e+00 true resid
>> norm 1.046686001054e+00 ||Ae||/||Ax|| 1.046686001054e+00
>>   70 KSP preconditioned resid norm 3.149991658898e-10 true resid norm
>> 3.149991658892e-10 ||Ae||/||Ax|| 5.383753929329e-05
>>      0 KSP preconditioned resid norm 3.602956988994e+00 true resid
>>      1 KSP preconditioned resid norm 2.093057977304e+00 true resid
>> norm 9.252238178106e-01 ||Ae||/||Ax|| 9.252238178106e-01
>>   71 KSP preconditioned resid norm 2.993160400510e-10 true resid norm
>> 2.993160400417e-10 ||Ae||/||Ax|| 5.115708488107e-05
>>      0 KSP preconditioned resid norm 3.336754379842e+00 true resid
>>      1 KSP preconditioned resid norm 1.284284263997e+00 true resid
>> norm 8.760668211902e-01 ||Ae||/||Ax|| 8.760668211902e-01
>>   72 KSP preconditioned resid norm 2.895591295761e-10 true resid norm
>> 2.895591295591e-10 ||Ae||/||Ax|| 4.948949934951e-05
>>      0 KSP preconditioned resid norm 2.267067098558e+00 true resid
>>      1 KSP preconditioned resid norm 8.534973699953e-01 true resid
>> norm 7.726740440864e-01 ||Ae||/||Ax|| 7.726740440864e-01
>>   73 KSP preconditioned resid norm 2.812425874590e-10 true resid norm
>> 2.812425874308e-10 ||Ae||/||Ax|| 4.806809189165e-05
>>      0 KSP preconditioned resid norm 1.144552955812e+00 true resid
>>      1 KSP preconditioned resid norm 6.664517534844e-01 true resid
>> norm 6.421695318305e-01 ||Ae||/||Ax|| 6.421695318305e-01
>>   74 KSP preconditioned resid norm 2.735484153434e-10 true resid norm
>> 2.735484153084e-10 ||Ae||/||Ax|| 4.675305573021e-05
>>      0 KSP preconditioned resid norm 1.554702841568e+00 true resid
>>      1 KSP preconditioned resid norm 7.157380114110e-01 true resid
>> norm 7.377660147515e-01 ||Ae||/||Ax|| 7.377660147515e-01
>>   75 KSP preconditioned resid norm 2.661574205602e-10 true resid norm
>> 2.661574205227e-10 ||Ae||/||Ax|| 4.548983660049e-05
>>      0 KSP preconditioned resid norm 4.199331451693e+00 true resid
>>      1 KSP preconditioned resid norm 7.261245258089e-01 true resid
>> norm 9.689217434547e-01 ||Ae||/||Ax|| 9.689217434547e-01
>>   76 KSP preconditioned resid norm 2.534998275631e-10 true resid norm
>> 2.534998275209e-10 ||Ae||/||Ax|| 4.332648591775e-05
>>      0 KSP preconditioned resid norm 3.743395182510e+00 true resid
>>      1 KSP preconditioned resid norm 8.990417749799e-01 true resid
>> norm 9.329106139559e-01 ||Ae||/||Ax|| 9.329106139559e-01
>>   77 KSP preconditioned resid norm 2.388049684536e-10 true resid norm
>> 2.388049684532e-10 ||Ae||/||Ax|| 4.081493941813e-05
>>      0 KSP preconditioned resid norm 1.894155910280e+00 true resid
>>      1 KSP preconditioned resid norm 8.684190700742e-01 true resid
>> norm 7.727740370555e-01 ||Ae||/||Ax|| 7.727740370555e-01
>>   78 KSP preconditioned resid norm 2.286512776556e-10 true resid norm
>> 2.286512776733e-10 ||Ae||/||Ax|| 3.907953886624e-05
>>      0 KSP preconditioned resid norm 1.276207551837e+00 true resid
>>      1 KSP preconditioned resid norm 5.355779104233e-01 true resid
>> norm 5.278462128508e-01 ||Ae||/||Ax|| 5.278462128508e-01
>>   79 KSP preconditioned resid norm 2.074225711250e-10 true resid norm
>> 2.074225711493e-10 ||Ae||/||Ax|| 3.545127109477e-05
>>      0 KSP preconditioned resid norm 1.200062868567e+00 true resid
>>      1 KSP preconditioned resid norm 6.893976477109e-01 true resid
>> norm 6.184761860600e-01 ||Ae||/||Ax|| 6.184761860600e-01
>>   80 KSP preconditioned resid norm 1.878908772984e-10 true resid norm
>> 1.878908773103e-10 ||Ae||/||Ax|| 3.211304532026e-05
>>      0 KSP preconditioned resid norm 1.387129119694e+00 true resid
>>      1 KSP preconditioned resid norm 8.742548405622e-01 true resid
>> norm 6.169338830681e-01 ||Ae||/||Ax|| 6.169338830681e-01
>>   81 KSP preconditioned resid norm 1.720957363240e-10 true resid norm
>> 1.720957363027e-10 ||Ae||/||Ax|| 2.941344603009e-05
>>      0 KSP preconditioned resid norm 1.602115661552e+00 true resid
>>      1 KSP preconditioned resid norm 8.392172521059e-01 true resid
>> norm 6.206948554932e-01 ||Ae||/||Ax|| 6.206948554932e-01
>>   82 KSP preconditioned resid norm 1.584755992063e-10 true resid norm
>> 1.584755991999e-10 ||Ae||/||Ax|| 2.708558378201e-05
>>      0 KSP preconditioned resid norm 1.601197866084e+00 true resid
>>      1 KSP preconditioned resid norm 8.359479912386e-01 true resid
>> norm 6.119059337506e-01 ||Ae||/||Ax|| 6.119059337506e-01
>>   83 KSP preconditioned resid norm 1.418702609113e-10 true resid norm
>> 1.418702608829e-10 ||Ae||/||Ax|| 2.424751101569e-05
>>      0 KSP preconditioned resid norm 1.499465989768e+00 true resid
>>      1 KSP preconditioned resid norm 1.045754716297e+00 true resid
>> norm 6.153015126718e-01 ||Ae||/||Ax|| 6.153015126718e-01
>>   84 KSP preconditioned resid norm 1.271329562402e-10 true resid norm
>> 1.271329562130e-10 ||Ae||/||Ax|| 2.172870999918e-05
>>      0 KSP preconditioned resid norm 1.634503776014e+00 true resid
>>      1 KSP preconditioned resid norm 1.222338373864e+00 true resid
>> norm 6.558960123395e-01 ||Ae||/||Ax|| 6.558960123395e-01
>>   85 KSP preconditioned resid norm 1.170830928689e-10 true resid norm
>> 1.170830928467e-10 ||Ae||/||Ax|| 2.001105493065e-05
>>      0 KSP preconditioned resid norm 2.189478982761e+00 true resid
>>      1 KSP preconditioned resid norm 1.257863289529e+00 true resid
>> norm 5.975673409262e-01 ||Ae||/||Ax|| 5.975673409262e-01
>>   86 KSP preconditioned resid norm 1.072794488701e-10 true resid norm
>> 1.072794488559e-10 ||Ae||/||Ax|| 1.833548202211e-05
>>      0 KSP preconditioned resid norm 3.043239239438e+00 true resid
>>      1 KSP preconditioned resid norm 1.508125411857e+00 true resid
>> norm 5.316504517748e-01 ||Ae||/||Ax|| 5.316504517748e-01
>>   87 KSP preconditioned resid norm 9.310419868753e-11 true resid norm
>> 9.310419867003e-11 ||Ae||/||Ax|| 1.591274357860e-05
>>      0 KSP preconditioned resid norm 2.707043890291e+00 true resid
>>      1 KSP preconditioned resid norm 2.156895340838e+00 true resid
>> norm 6.565618094970e-01 ||Ae||/||Ax|| 6.565618094970e-01
>>   88 KSP preconditioned resid norm 7.852841829285e-11 true resid norm
>> 7.852841828475e-11 ||Ae||/||Ax|| 1.342154920668e-05
>>      0 KSP preconditioned resid norm 2.582289916941e+00 true resid
>>      1 KSP preconditioned resid norm 2.382288228383e+00 true resid
>> norm 6.422921135312e-01 ||Ae||/||Ax|| 6.422921135312e-01
>>   89 KSP preconditioned resid norm 6.494099865988e-11 true resid norm
>> 6.494099869486e-11 ||Ae||/||Ax|| 1.109927881590e-05
>>      0 KSP preconditioned resid norm 2.588940215193e+00 true resid
>>      1 KSP preconditioned resid norm 2.412871891541e+00 true resid
>> norm 6.483026287919e-01 ||Ae||/||Ax|| 6.483026287919e-01
>>   90 KSP preconditioned resid norm 5.586819688621e-11 true resid norm
>> 5.586819689526e-11 ||Ae||/||Ax|| 9.548616540312e-06
>>  2 SNES Function norm 5.587280798316e-11
>> SNES Object:
>>  type: ls
>>    line search variant: SNESLineSearchCubic
>>    alpha=0.0001, maxstep=1e+08, minlambda=1e-12
>>  maximum iterations=50, maximum function evaluations=10000
>>  tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
>>  total number of linear solver iterations=107
>>  total number of function evaluations=3
>>  KSP Object:
>>    type: fgmres
>>      GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>> Orthogonalization with no iterative refinement
>>      GMRES: happy breakdown tolerance 1e-30
>>    maximum iterations=10000, initial guess is zero
>>    tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>>    right preconditioning
>>  PC Object:
>>    type: mg
>>      MG: type is FULL, levels=1 cycles=v
>>    Coarse gride solver -- level 0 presmooths=1 postsmooths=1 -----
>>      KSP Object:(mg_levels_0_)
>>        type: gmres
>>        maximum iterations=1, initial guess is zero
>>        left preconditioning
>>      PC Object:(mg_levels_0_)
>>        type: ilu
>>          ILU: 0 levels of fill
>>          ILU: factor fill ratio allocated 1
>>          ILU: tolerance for zero pivot 1e-12
>>          ILU: using diagonal shift to prevent zero pivot
>>          ILU: using diagonal shift on blocks to prevent zero pivot
>>               out-of-place factorization
>>               matrix ordering: natural
>>          ILU: factor fill ratio needed 1
>>               Factored matrix follows
>>              Matrix Object:
>>                type=seqaij, rows=39366, cols=39366
>>                package used to perform factorization: petsc
>>                total: nonzeros=2125764, allocated nonzeros=2125764
>>                  using I-node routines: found 19683 nodes, limit used
>> is 5
>>        linear system matrix = precond matrix:
>>        Matrix Object:
>>            using I-node routines: found 19683 nodes, limit used is 5
>>    Matrix Object:
>> Thanks again,
>> Hal
>> Barry Smith wrote:
>>>  Please run with
>>> -ksp_monitor_true_residual -snes_monitor
>>> -mg_levels_ksp_monitor_true_residua -mg_coarse_ksp_type gmres
>>> -mg_coarse_ksp_monitor_true_residual -snes_view
>>> and send the output for one time-step.
>>>   Barry
>>> On Aug 26, 2009, at 2:34 PM, Hal Finkel wrote:
>>>> Hello,
>>>> I've constructed a evolution scheme for a time-dependent 3D PDE
>>>> system using the DMMG layer. The core of the code is essentially a
>>>> loop around DMMGSolve in the spirit of
>>>> snes/examples/tutorials/ex29.c. If I only run with one level, then
>>>> the code runs and produces sensible results. Passing the option
>>>> -mg_levels_0_ksp_type bcgsl increases the solver speed by about 30%,
>>>> and -mg_levels_0_pc_type fieldsplit gives me another 5% improvement.
>>>> Does that say something about the structure of my problem?
>>>> If I run with two levels, the coarse solve seems to work, but the
>>>> fine grid's KSP never seems to complete. If I run with
>>>> -mg_levels_1_ksp_monitor_true_residual, I can see the residual does
>>>> not seem to be converging at all:
>>>>     0 KSP preconditioned resid norm 1.979915874387e+02 true resid
>>>> norm 1.889855551272e+04 ||Ae||/||Ax|| 1.889855551272e+04
>>>>     0 KSP preconditioned resid norm 3.833279709488e+06 true resid
>>>> norm 3.665290817713e+08 ||Ae||/||Ax|| 3.665290817713e+08
>>>>     0 KSP preconditioned resid norm 5.080465654647e+01 true resid
>>>> norm 8.284057252719e+03 ||Ae||/||Ax|| 8.284057252719e+03
>>>>     1 KSP preconditioned resid norm 6.057649668915e+00 true resid
>>>> norm 5.136009463814e+02 ||Ae||/||Ax|| 5.136009463814e+02
>>>>     0 KSP preconditioned resid norm 5.511785811223e+04 true resid
>>>> norm 1.055162492334e+07 ||Ae||/||Ax|| 1.055162492334e+07
>>>>     0 KSP preconditioned resid norm 2.164672340919e+01 true resid
>>>> norm 2.999406329054e+04 ||Ae||/||Ax|| 2.999406329054e+04
>>>>     0 KSP preconditioned resid norm 5.275983407134e+05 true resid
>>>> norm 9.196351032040e+08 ||Ae||/||Ax|| 9.196351032040e+08
>>>>     0 KSP preconditioned resid norm 3.338344860439e+01 true resid
>>>> norm 5.133553722923e+03 ||Ae||/||Ax|| 5.133553722923e+03
>>>>     1 KSP preconditioned resid norm 4.306407436023e+00 true resid
>>>> norm 3.361745947223e+02 ||Ae||/||Ax|| 3.361745947223e+02
>>>> If I run with -pc_mg_monitor I see, after the course solve, only
>>>> things like:
>>>>   Residual norms for mg_levels_1_ solve.
>>>>   0 KSP Residual norm 1.979915874387e+02
>>>>   0 KSP Residual norm 3.833279709488e+06
>>>>   0 KSP Residual norm 5.080465654647e+01
>>>>   1 KSP Residual norm 6.057649668915e+00
>>>>   0 KSP Residual norm 5.511785811223e+04
>>>>   0 KSP Residual norm 2.164672340919e+01
>>>>   0 KSP Residual norm 5.275983407134e+05
>>>>   0 KSP Residual norm 3.338344860439e+01
>>>>   1 KSP Residual norm 4.306407436023e+00
>>>> running with -info shows:
>>>> [0] KSPDefaultConverged(): user has provided nonzero initial guess,
>>>> computing 2-norm of preconditioned RHS
>>>> [0] KSPDefaultConverged(): Linear solver is diverging. Initial right
>>>> hand size norm 0.0066162, current residual norm 23282.7 at iteration 0
>>>> hand size norm 0.00287711, current residual norm 38.2205 at iteration 0
>>>> hand size norm 0.00287711, current residual norm 809191 at iteration 0
>>>> hand size norm 0.00970186, current residual norm 186.983 at iteration 0
>>>> hand size norm 0.00970186, current residual norm 3.62292e+06 at
>>>> iteration 0
>>>> What is a good way to debug this?
>>>> No matter how I run, I've arranged the code so that the fine grid is
>>>> *always* the same size; it has to be because the initial conditions
>>>> are loaded from a file.
>>>> In general, however, I don't understand exactly what the mg
>>>> preconditioner is doing. Is there a writeup somewhere which is more
>>>> verbose than the manual? In the one-level case, how are the results
>>>> of the solve used to precondition the Jacobian?
>>>> In an 1-processor, 1-level case, running with -snes_view gives:
>>>> SNES Object:
>>>> type: ls
>>>> total number of linear solver iterations=36
>>>> KSP Object:
>>>>   type: fgmres
>>>> PC Object:
>>>>   type: mg
>>>>       type: bcgsl
>>>>         BCGSL: Ell = 2
>>>>         BCGSL: Delta = 0
>>>>       type: fieldsplit
>>>>         FieldSplit with MULTIPLICATIVE composition: total splits =
>>>> 2, blocksize = 2
>>>>         Solver info for each split is in the following KSP objects:
>>>>         Split number 0 Fields  0
>>>>         KSP Object:(mg_levels_0_fieldsplit_0_)
>>>>           type: preonly
>>>>         PC Object:(mg_levels_0_fieldsplit_0_)
>>>>           type: ilu
>>>>                 Matrix Object:
>>>>                   type=seqaij, rows=19683, cols=19683
>>>>                   total: nonzeros=531441, allocated nonzeros=531441
>>>>                     not using I-node routines
>>>>           Matrix Object:
>>>>         Split number 1 Fields  1
>>>>         KSP Object:(mg_levels_0_fieldsplit_1_)
>>>>           type: preonly
>>>>         PC Object:(mg_levels_0_fieldsplit_1_)
>>>>           type: ilu
>>>>                 Matrix Object:
>>>>           Matrix Object:
>>>>       Matrix Object:
>>>>   Matrix Object:
>>>> Thank you in advance,
>>>> Hal
