Petsc with Intel MKL for blas/lapack
Tue Aug 25 14:21:52 CDT 2009
Actually we now use a notation with MKL library names that appears to
work consistantly across MKL versions.  So there could be other
issues.
configure.log will clear things up [so send it over to us at petsc-maint at mcs.anl.gov]
Satish
On Tue, 25 Aug 2009, Matthew Knepley wrote:
> The biggest reason that the BLAS/LAPACK configure changes so rapidly among
> patchlevels
> is that MKL is the worst library for maintenance. They change the content
> AND the names
> of the libraries, as well as the link order, in almost every version. I am
> beginning to really
> dislike the developers personally.
> I suspect the difference is the exact patchlevel of PETSc used on the
> different machines. However,
> as always with configure problems, we cannot tell you anything at all unless
> you send configure.log.
>    Matt
> On Tue, Aug 25, 2009 at 5:47 AM, Thomas Witkowski <
> thomas.witkowski at tu-dresden.de> wrote:
> > Hi,
> > I want to compile petsc on two larger HPC system, on both we use Intels MKL
> > for blas and lapack. The first one is a pc farm, and I've successfully
> > compiled petsc with the parameter
> > --with-blas-lapack-dir=/work/licsoft/libraries/mkl/10.0.3.020/lib/em64t
> > This works fine. On the other system, its an SGI Altix, I've tried to do
> > the same. But it fails in configure, because petsc tries to link the test
> > program with "-lblas". The same test program on the pc farm was linked with
> > the correct library parameter "-lmkl". May question is, why this can happen
> > and what I can do to avoid the problem? Thanks for answering!
> > Thomas
