Petsc with Intel MKL for blas/lapack
Thomas Witkowski
thomas.witkowski at tu-dresden.de
Tue Aug 25 05:47:12 CDT 2009
I want to compile petsc on two larger HPC system, on both we use Intels
MKL for blas and lapack. The first one is a pc farm, and I've
successfully compiled petsc with the parameter
--with-blas-lapack-dir=/work/licsoft/libraries/mkl/10.0.3.020/lib/em64t
This works fine. On the other system, its an SGI Altix, I've tried to do
the same. But it fails in configure, because petsc tries to link the
test program with "-lblas". The same test program on the pc farm was
linked with the correct library parameter "-lmkl". May question is, why
this can happen and what I can do to avoid the problem? Thanks for
answering!
Thomas
