hints wanted for huge eigenvalue problem
Christian May cmay at phys.ethz.ch
Sun Aug 23 05:52:23 CDT 2009
Dear all,
I want to extract the lowest eigenvalues of a huge generalized
eigenvalue problem with very dense clusters of eigenvalues.
I use slepc and superlu as external direct solver with the following
options
-eps_ncv 300 -eps_nev 220 -eps_tol 1e-10
-st_ksp_rtol 1e-14 -st_ksp_type preonly
-st_pc_type lu -st_pc_factor_mat_solver_package superlu_dist
Without shift-and-invert, this simply takes way too long, even on 48 CPUs
it runs for hours.
If I use a shift-and-invert technique additionally invoking
-st_type sinvert -st_shift -0.41,
it converges very fast and also
parallelizes well, but I most likely don't get the lowest eigenvalues if
st_shift is slightly too high. If it's slightly too low, it doesn't seem
to converge.
Can anybody give me some hints on how to tweak the options?
If a 100MB tar ball is not too much for you, the matrix is here:
www.phys.ethz.ch/~cmay/binaryoutput.tgz
Thanks in advance
Christian
