cast PetscScalar to double
Fredrik Bengzon fredrik.bengzon at math.umu.se
Wed Aug 19 04:53:07 CDT 2009
Hi
I'm using a Petsc 3 installation compiled with support for complex
numbers. However, in the code I have made frequent use of the stl
library and the standard type double. This now gives a compilation error
since PetscScalar can not be casted into double. Do you know of a quick
workaround or do I have to replace every instance of double with
PetscScalar?
Fredrik Bengzon
