linear elliptic vector equation
Barry Smith
bsmith at mcs.anl.gov
Tue Aug 18 21:41:54 CDT 2009
On Aug 18, 2009, at 11:42 AM, nicolas aunai wrote:
> Hello,
> Yes it is a bit overkill indeed :-) I was looking at ex29 actually...
> which is still linear and with DA's but scalar.
> But I'd rather like not use multigrids, however I have not seen an
> example of a code that uses DA's and KSP solvers.
> Every example use multigrids.
Multigrid is the way to go for this problem, it will be faster
than some generic preconditioned CG.
> When you have a multicomponent linear equation to solve on a
> rectangular uniform grid such as mine, is it good to :
> 1/ use DA's to represent your grid
> 2/ create the matrix corresponding to your operator once and for all
> (the operator neve changes).( In fact there are 2 matrices because two
> cases possibles (Neumann/periodic or Dirichlet/Periodic, depending on
> the component). but never minds)
> 3/ Call KSPSolve() 3 times (for each vector component associated
> with the DA) ?
Yes. You can do all this using the DMMG object.
Note that the DMMG object in your linear case just manages a KSP
and the meshes for you. In the end it is a KSPSolve() that actually
does the solve and you have full control over the solve including
using -pc_type icc or something else that does not use multigrid.
Though multigrid will be faster.
Barry
> Thx
> Nico
> 2009/8/18 Aron Ahmadia <aron.ahmadia at kaust.edu.sa>:
>> ex19 comes to mind, though it's a bit overkill for what you're
>> doing...
>> http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/src/snes/examples/tutorials/ex19.c.html
>> ex19 uses DAs and DMMG, which is kind of like a meta-DA for using
>> multigrid-style solvers. Both work well with structured grids.
>> You may also want to review the PETSc manual section on DA.
>> A
>> On Tue, Aug 18, 2009 at 3:30 AM, nicolas aunai <nicolas.aunai at gmail.com
>> wrote:
>>> Dear all,
>>> I have a simulation code (particle in cell) in which I have to
>>> solve a
>>> linear vector equation 4 times per time step. A typical run consists
>>> of 50 000 time steps. The grid is rectangular and uniform of size
>>> Lx,
>>> Ly, with nx+1 and ny+1 points in the x and y direction
>>> respectively.,
>>> (nx, ny) could be at max (1024,1024).
>>> The vector equation is the following :
>>> B(x,y) - a*Laplacian(B(x,y)) = S(x,y)
>>> Where B and S are 2D vector fields with 3 components (Bx, By, Bz and
>>> Sx, Sy, Sz), each depending on the x and y coordinates.
>>> 'a' is a positive constant, smaller than one, typically a= 0.02
>>> Boundary conditions may depend on for which B component we are
>>> solving
>>> the equation. On the x=cst borders, the boundary is always periodic,
>>> no matter what component is solved, but on y=cst borders, the
>>> boundary
>>> condition can be either Neumann or Dirichlet.
>>> So far, I have written a small code that creates a vector
>>> solution, a
>>> vector RHS and the matrix operator, and solve a scalar equation of
>>> this type. Solving my vector equation would then just call 3 times
>>> this kind of code... but I believe there is another way to deal with
>>> vector fields and linear systems with Petsc, using DAs no ? Could
>>> someone explain me how solve this the proper way and/or show me some
>>> code solving linear system with vector fields ? (is there an example
>>> in the exercices that I would not have seen ?)
>>> Thanks a lot
>>> Nico
>> Aron Jamil Ahmadia
>> Assistant Research Scientist
>> King Abdullah University of Science and Technology
