Off topic - Some advice on solving Navier-Stokes with FiniteDifference
Stephen Wornom stephen.wornom at sophia.inria.fr
Thu Aug 13 02:02:18 CDT 2009
Matthew Knepley wrote:
> On Wed, Aug 12, 2009 at 10:39 AM, Stephen Wornom
> <stephen.wornom at sophia.inria.fr
>         1) You should really handle this by creating the constant
>         vector on the pressure
>             space and using MatNullSpaceCreate()
>         2) You can also easily handle this by fixing the pressure at
>         one point
>     At what indices or location does one fix the pressure? What value
>     is it set. Usually pressure is part of the solution. It would seem
>     to introduce an inconsistency.
>     I would like to understand how to do it.
> It does not matter where you fix it or to what value. The absolute
> value of the pressure is not physically
> relevant, only pressure differences (which is why only grad p appears).
Thanks for clarification on this point which is confusing to many of us.
So why is it necessary to fix a value at a point since as you point out
that only the grad p appears? If the pressure is not set in the
numerical eqns, will you agree that the initial pressure sets the value
for the numerical pressure at least in  time accurate solutions.
> Fixing the pressure at any point
> to any value just sets the scale. There is no inconsistency. This is
> in many many elementary fluid mechanics
> books.
Pass along a reference for myself and students.
Thanks again,
Stephen
> To do this mechanically. Change one row in the operator div (from the
> div u = 0 equation) to the identity.
>    Matt
>     Stephen
>          Matt
>         On Wed, Aug 12, 2009 at 10:19 AM, William A. Perkins
>         <william.perkins at pnl.gov <mailto:william.perkins at pnl.gov>
>         <mailto:william.perkins at pnl.gov>>> wrote:
>            Stephen,
>            There are two ways that I know of to deal with pressure checker
>            boarding: staggered grids or some form of Rhie-Chow
>         interpolation.
>            IMO, these are simple only for uniform, Cartesian grids.
>          For grids
>            that are curvilinear, unstructured, non-uniform, and/or
>            non-orthogonal, things get real complicated. There may be other
>            methods, but something is required.
>            Regarding boundary conditions, I would suggest this text book:
>               H. K. Versteeg and W. Malalasekera. An Introduction to
>               Computational Fluid Dynamics, the Finite Volume Method. 2nd
>               edition. Prentice-Hall. 2007
>            While this book uses the finite volume method, the
>         explanation of
>            boundary conditions and staggered grids is very good and
>         relatively
>            easy to interpret for finite difference.  I would also
>         recommend
>               Joel H. Ferziger and Milovan Peric. Computational
>         Methods for
>               Fluid Dynamics. Springer-Verlag, 3rd edition, 2002.
>            This is a little more general with regard to method
>         discussing finite
>            difference and finite volume, but still settling on finite
>         volume.
>            My $0.02: I question the use of finite difference.  For
>         Navier-Stokes,
>            the use of finite volume is much more prevalent in
>         commercial and
>            research codes.  If your student follows Versteeg and
>         Malalasekera a
>            simple, working, staggered grid FV code could be built in a
>         very short
>            time.  If something more complicated is needed, it's probably
>            explained in Ferziger and Peric.
>            Also My $0.02: Unless the point of your student's work is to
>            experience building her own code, why not download
>         something like
>            OpenFOAM (http://www.opencfd.co.uk/openfoam/) and just use
>         it?  I
>            expect the effort to learn something like OpenFOAM for a simple
>            application will be much less than writing a new code.
>            Hope this helps.
>            Bill
>            >>>>> "Stephen" == Stephen Wornom
>         <mailto:stephen.wornom at sophia.inria.fr>>> writes:
>               Stephen> Shengyong wrote:
>               >> Hi, Farshid
>               >> Maybe she should use the staggered grid method which
>         is very
>            simple to
>               >> implement.
>               Stephen> Does it remain simple for curvilinear meshes?
>               Stephen> Stephen
>               >> On Tue, Aug 11, 2009 at 5:16 AM, Farshid Mossaiby
>            <mossaiby at yahoo.com <mailto:mossaiby at yahoo.com>
>         <mailto:mossaiby at yahoo.com <mailto:mossaiby at yahoo.com>>
>         <mailto:mossaiby at yahoo.com> <mailto:mossaiby at yahoo.com
>         <mailto:mossaiby at yahoo.com>>>> wrote:
>               >> Hi all,
>               >> Sorry for this off-topic post.
>               >> I am helping a master studnet which is working on solving
>               >> Navier-Stokes equation with Finite Difference method.
>         She is
>               >> trying to eliminate spourious pressure modes from the
>         solution.
>               >> She needs to know some details that are not usually
>         found in the
>               >> papers but important when programming, e.g. boundary
>            condition for
>               >> pressure. If someone has expertise on this or know a
>         *simple* FD
>               >> code, I would be thankful to let me know.
>               >> Best regards,
>               >> Farshid Mossaiby
>               >> Pang Shengyong
>               >> Solidification  Simulation Lab,
>               >> State Key Lab of  Mould & Die Technology,
>               >> Huazhong Univ. of Sci. & Tech. China
>            Bill Perkins
>            Research Engineer
>            Hydrology Group
>            Pacific Northwest National Laboratory
>            902 Battelle Boulevard
>            P.O. Box 999, MSIN K9-36
>            Richland, WA  99352 USA
>            Tel:  509-372-6131
>            Fax: 509-372-6089
>         <mailto:william.perkins at pnl.gov <mailto:william.perkins at pnl.gov>>
>            www.pnl.gov <http://www.pnl.gov> <http://www.pnl.gov>
>         What most experimenters take for granted before they begin
>         their experiments is infinitely more interesting than any
>         results to which their experiments lead.
>         -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
