How to get information about the off-diagonal submatrix
    Thomas Witkowski
    thomas.witkowski at tu-dresden.de
    Mon Aug 10 10:46:09 CDT 2009
Thank you for all the hints, this will help me to debug my application!!!
Thomas
Satish Balay wrote:
> On Mon, 10 Aug 2009, Thomas Witkowski wrote:
>> Satish Balay wrote:
>>> Its also possible that some values are set on other procs and
>>> commuincated..
>> That's the reason, I've forgotten to check it. Thanks for the hint! Is there
>> any way to get information from petsc to check how many matrix entries had to
>> be communicated during assembling?
> You can run the code with '-info' - and look for 'stash' - that gives
> the message lenghts that got commuicated for matrix assembly.
> Also - you can use MatSetOption(MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE).
> This will cause MatSetValues() to ignore off-proc entries during
> assembly. After this - you can check if the assembled matrix is what
> you expect..
> Satish
>> Thomas
>>> Note: I should have mentioned earlier: mpiaij->B is an internal
>>> datastructure - so the column indices don't directly correspond to the
>>> original matrix. [there is a cmap in there that stores this map]
>>> Satish
>>>> Thanks, that works fine! In my test case (yes, just for debugging!) I've
>>>> expected to have an empty off-diagonal matrix. But the matrix is not
>>>> empty.
>>>> But how is it possible, when all entries, which are inserted to the matrix
>>>> via
>>>> MatSetValues, have indices for row and col within the ownership range of
>>>> the
>>>> processors matrix?
>>>> Thomas
>>>> Satish Balay wrote:
>>>>> alternatively - just access the private datastructe and print..
>>>>> #include "../src/mat/impls/aij/mpi/mpiaij.h"
>>>>> Mat_MPIAIJ     *mpiaij = (Mat_MPIAIJ*)mat->data;
>>>>> MatView(mpiaij->B,...);
>>>>> Satish
>>>>> On Mon, 10 Aug 2009, Matthew Knepley wrote:
>>>>>> If this is just for debugging, the easiest way I think is to call
>>>>>> MatGetSubmatrix() with
>>>>>> a column IS that omits the local columns.
>>>>>>   Matt
>>>>>> On Mon, Aug 10, 2009 at 8:28 AM, Thomas Witkowski <
>>>>>> thomas.witkowski at tu-dresden.de> wrote:
>>>>>>> Hi,
>>>>>>> how is it possible to print just the off-diagonal submatrix of one
>>>>>>> process
>>>>>>> of a parallel mpiaij matrix?
>>>>>>> Thomas
