PETSC_LIB
irfan.khan at gatech.edu
Sun Aug 9 17:33:19 CDT 2009
Thank for your reply Matt. I have tried to compile the src/dm/ao/examples/tutorials/ex2.c using the makefile provided in same directory. However I received the same error, i.e.
ld: cannot find -llapack
make: [ex2] Error 1 (ignored)
Please note that I was able to compile and run this example successfully before the an update was done on the system.
I wanted to get some idea as to the cause of this link error. This way I have something to ask the team at Purdue to look into.
Thank you
Irfan
----- Original Message -----
To: "PETSc users list" <petsc-users at mcs.anl.gov>
Sent: Friday, August 7, 2009 7:37:06 PM GMT -05:00 US/Canada Eastern
Subject: Re: PETSC_LIB
The easiest way to link correctly is to use the PETSc makefile format:
prog: file1.o file2.o
${CLINKER} -o prog file1.o file2.o ${PETSC_SNES_LIB}
Matt
On Fri, Aug 7, 2009 at 6:17 PM, < irfan.khan at gatech.edu > wrote:
Hi
I have been compiling and running my Petsc code on a TERAGRID cluster (Steele - Purdue) for sometime now. Recently they made changes to their operating system and also installed a clean version of Petsc (it now makes use of MPICH-2 instead of MPICH).
However my make file is not successfully linking anymore. The error message I get is as follows.
make: *** [te] Error 1
I see that the blaslapack package is not available under "externalpackages" directory. I presume the link error is because the lapack library is included in the PETSC_LIB command and this library may not have been installed during PETSc installation. I say this because the make file works fine on my laptop where I have installed blas-lapack during PETSc installation. Please correct me if I am wrong.
How can I resolve this link error? Kindly suggest.
Thank you
Irfan
PhD Candidate
G.W. Woodruff School of Mechanical Engineering
Georgia Institute of Technology
Atlanta, GA (30332)
-- Norbert Wiener
PhD Candidate
Atlanta, GA (30332)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090809/6b186c37/attachment.htm>
