efficient matrix block assignment
Umut Tabak
u.tabak at tudelft.nl
Thu Aug 6 08:55:31 CDT 2009
Matthew Knepley wrote:
> On Thu, Aug 6, 2009 at 8:18 AM, Umut Tabak <u.tabak at tudelft.nl
> <mailto:u.tabak at tudelft.nl>> wrote:
> Dear all,
> I am trying some block matrix assembly in Petsc, so far, I was
> puzzling with the right calling and set up of MatSetValuesBlocked.
> Matthew Knepley confirmed my previous post. I guess it is the
> function I should use. But it accepts the values as a 1D array,
> which is represented in row major order(by default). So the
> burden on this approach is to convert my Matrix into a 1D array,
> this seemed as the only solution for the moment. If I would like
> to use this function.
> I need to understand what you mean here. The 1D array we accept here
> is the input values. It is physically 1D, but conceptually
> 2D, and by default is in row-major order. This has nothing to do with
> your larger Mat object.
Precisely, what i meant, there is a 2d array which is conceptually a
matrix in my case(where I read from a Finite element code). So I must
represent it as a 1D array.
> BTW, some blocks are square and some are rectangular, with block
> size type operations, I guess it is not possible to assign
> rectangular matrices to some part of a larger square matrix.
> Not true. You can have any mxn dimension to the input values. I think
> there is some underlying confusion here
> that I do not understand. I would suggest you look at the example in
> the manual.
> Matt
This is also confusing for me for the moment. But there is only one
parameter, for operation MatSetBlockSize(Mat, blocksize), this was what
I meant by "block size" above. I should check the docs more, I guess.
Hope made it clear.
Thanks
Umut
